A question
A question
2004-09-01 by David
I notice that when I turn up the Q amount, the sounds don't get very
squelchy at all. Is there a way to adjust that, or is that pretty
much it? In the menu screen, the Q is at 0% and so is the Cutoff.
Thank you very much for your time.
-DMN
Re: [xl7] A question
2004-09-02 by erik_magrini@Baxter.com
It really depends on the sound itself to be honest, not to mention the
filter type you use.  If you go into Preset Edit, you can select different
filters that may or may not give you more "squelch".  You can also change
the resonance max value for the filter in the Preset Edit patchcords menu
too (I believe it's set to 80 as max by default), though be careful not to
blow your speakers with heavy tweaking.
David <lost_one95340@...>
09/01/2004 03:15 PM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] A question
-DMN
Yahoo! Groups Links
material from any computer.
For Translation:
