Has this happened to anyone?
2004-08-25 by David
Sometimes when I'm creating a pattern everything is normal. Then,
after a certain amount of time, every part contains some major
unintentional effects. For instance, today, I was just messing around
with it and everything sounded good. Then I left. When I returned,
everything had this major delay effect. This has also happened in the
middle of playing a pattern. What could be wrong? Could there be a
bug, or could it just be settings? Thank you for your help in advance.
Re: Has this happened to anyone?
2004-08-25 by mbracement
I usually only encounter a crash on my MP7 when I clog it up with too
much MIDI data at one time. (note sticking) I try to do a pattern
save after each event I change or part I add so I can revert to saved
pattern if I don't like it. Sort of like an undo function.
