Re: [xl7] OT Laptops
2004-08-17 by erik_magrini@Baxter.com
Yeah, I use a laptop and SX, and you'll have NO problems recording 4
tracks at once, the 5400RPM can definitely handle that and probably a lot
more too.  I wouldn't recommend a USB interface for that many tracks
though, probably better of going with firewire for that (M-Audio Firewire
410?).  I think 4 tracks at 24bit/44.1 is probably pushing the limits of
the USB bandwidth, doable, but right on the edge.
"||||* *||||" <trabantmusic@...>
08/17/2004 07:30 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] OT Laptops
Anybody recording with a Laptop and Cubase/Sonar? Im thinking of getting
one
and id like to know if its possible to use a mobile system to record en
multitrack mode [4 tracks, m-audio usb], the worry is about the hard disc
in
the first place, are 5200 rpm enough or is there a possibility to get
external hard disks with higher velocity, maybe with 1394 connector? Id
appreciate any help.
STOP MORE SPAM with the new MSN 8 and get 2 months FREE*
http://join.msn.com/?page=features/junkmail
Yahoo! Groups Links
material from any computer.
For Translation:
OT Laptops
2004-08-17 by ||||* *||||
Anybody recording with a Laptop and Cubase/Sonar? Im thinking of getting one
multitrack mode [4 tracks, m-audio usb], the worry is about the hard disc in
2004-08-18 by ||||* *||||
Thanks so far Eric....
i saw the delta audiophile firewire, looks nice.
i thought of an Asus Notebook, always made good experiences with their
mothers, what do you think? what brands do you recomend?
T
The new MSN 8: advanced junk mail protection and 2 months FREE*
2004-08-19 by erik_magrini@Baxter.com
To be honest, you really can't just go by the brand name when choosing
laptops for music.  You'll find that there's really only a few
manufacturers making laptop, and all the big name companies buy these and
simple slap their names on them, maybe change a few small parts.  Knowing
this,  you can sometimes find the exact same physical laptop being sold by
different manufacturers.  They'll have different model numbers of course,
but if you look at the cases and specs, probably identical.
You're going to have to spend a lot of time researching this one, getting
the wrong laptop can mean having all sorts of unsolveable audio issues,
much more so than with desktops.  An unlike desktops, most of the time you
can't replace the component that's giving you issues.  Here's some things
I would look for:
- NO SHARED GRAPHICS MEMORY!!!  This is big one, and can really eat into
your laptops performance.  The laptop should have a dedicated graphics
card and memory, at least 32MB.  A lot of times you'll find a deal on a
Laptop with a fast CPU, but it means nothing if the CPU has to dedicated a
lot of it's resources to the graphics side of things.
- 512MB RAM.  If you can get it included with the laptop, great, if not,
plan on adding this asap.
- Battery life.  This may or may not be important to you, but I bet if you
get a laptop you're going to want to make music while out and about (it's
fun as hell).  In "general" Athon based CPUs will have shorter battery
life than other CPUs, particularly the Intel Centrino systems.  I'm a big
proponent of Athlon's for desktops, but comparing the battery life of
those in laptops versus the Intels, I decided to get a Centrino based
system (1.5gHz).  These are geared towards preserving battery life, I can
use Reason for about 3.5 - 4 hours, or run Live with VSTi's (more CPU
intensive) for about 3 hours.
- Hard drive speed. If you're mostly doing midi work, and 4200RPM drive
will be fine, but if you plan on doing any audio work, try to find a
5400RPM drive.
- Screen size and RESOLUTION.  Bigger screens are not always better, so be
sure to check the specs!  A big screen with low resolution kinda of misses
the point, and this is another one of those things that gets hidden in the
fine print sometimes.  Mine is 15.4" with I believe a 1280x800 resolution,
though I'm going by memory so that could be wrong.  More than big enough
for Reason, and I can see about 16 tracks in Live.
- Compatibiltiy with your soundcard of choice.  Before you buy a laptop,
decide how many ins and outs you're going want, and choose a sound card.
Then research to make sure that there's no known driver of chipset
incompatibility issues you should be aware of.  I use an Echo Indigo IO
right now, and had to deal with troubleshooting some annoying issues it
had with the PCMCIA slots drivers in my laptop.  Luckily, Echo had a
utility to correct the problem.
To be honest, picking a laptop for live use has been probably the hardest
gear choice I've had to make.  There's a lot of variables to pay attention
to, and prices can vary a lot depending where you go.  Doesn't help the
fact that most places charge a restocking fee for returns, so if you make
a mistake and need to return your laptop, it can cost you $250 or so as
well.
If it helps at all, I use a HP ZT3010US that I got at Best Buy for about
$1200 after rebates (I got lucky, there were 4 different rebates I could
apply towards this machine at once).  They no longer carry this laptop,
but it has been replaced by the almost identical HP ZT3350US.  The only
issues I've had are the above mentioned PCMCIA driver conflict, which is
fixed now thanks to Echo tech support.
T
Yahoo! Groups Links
use of, or taking of any action in reliance upon, this information by
For Translation:
Re: [xl7] Re: OT Laptops
2004-08-20 by erik_magrini@Baxter.com
Yeah, and some of the larger screen laptops are just too big!  I had a
chance to pick up a 17" model too, but it was just too large IMO, wouldn't
want to carry that around or try to fit it under seat on an airplane.
Just to add a word about screens:
a 15 inch laptop screen can vary from 1024 x 768 up to 1600 x 1200
resolution.  Definitely check this spec before you buy.  Also, since the
physical screen is one of the most expensive parts of a laptop, the price
is
often a good marker of screen resolution.  A $1500 laptop is likely to
have
a 10x7 screen, while a $3000 laptop is likely to have a much larger
resolution.
I happen to like the 14 inch screens that do 1400 x 1050, myself.  Smaller
physical space, but more pixels than even a 19 inch desktop LCD.
     ~Chris
Yahoo! Groups Links
For Translation:
Re: OT Laptops
2004-08-20 by Christopher Oates
physical screen is one of the most expensive parts of a laptop, the price is
often a good marker of screen resolution.  A $1500 laptop is likely to have
resolution.
     ~Chris
