Thanks Aaron thought i was loosing my mind. :P
Can you give me some feeback on the cut off notes in external gear
problem? This is not new but it is bugging me again and again.
Any help or advice would be great. I am also thinking that the
current os for the comand station will be the last one as the new
Emulator X is hitting the shops. Am I wrong?
Take care
Mike G.
--- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote:
> I'd love to be proven wrong, but there's no way that the external
> controller can know what the controller values of the XL-7 are.
When
> you switch presets, the initial controller values get loaded but *do
> not get sent externally*. If you had a box that could query the XL-
7
> via custom sysex, you might be able to do it, but other than that,
no
> dice.
> -Aaron
> PS. I just read your post quoted here and you're exactly right. =)
> --- mike <curiousproductions@r...> wrote:
> > WOW!
> > Ok so it will not make changes till it meets the "actual" value
of
> > the controller. That is pretty sweet. Is this the case when
> > switching from preset to preset in the xl- and other synths?
> > Mike G.
> > --- In xl7@yahoogroups.com, "Stu" <routerman@z...> wrote:
> > > I used to have one and it does work.
> > > -----Original Message-----
> > > From: mike [mailto:curiousproductions@r...]
> > > Sent: 16 May 2004 17:07
> > > To: xl7@yahoogroups.com
> > > Subject: [xl7] Re: XX7 vs Doepfer Pocket Dial
> > > Have you tried this out? Do you know this will work for sure?
> > > I almost bought one of them things once. But did not due to
its
> > > price.
> > > > The Doepfer Regelwerk can do what you want. All it needs is
for
> > the
> > > XX7 to
> > > > send out the controller values. The Regelwek tracks the
> > controller
> > > values
> > > > then updates the corresponding fader on the Regelwerk and
won't
> > > output any
> > > > cc changes until you move the fader through that value.
> > > > Obviously, if you change the 'multisetup' on the Regelwerk,
it
> > > forgets all
> > > > previous tracked values and you're back to square one. Also,
> > > Regelwerk
> > > > is physically almost as big as an XX-7...
> > > > Sent: 15 May 2004 18:53
> > > > They explain it on the doepfer site very well. If you try it
out
> > > and
> > > > it works then please send me an email!!! as i wll run out and
buy
> > a
> > > > pocket dial in a second!!
> > > > In short from old memory, the xl would have to sent sysex
> > peramiters
> > > > to the pocket dial so it knows where the dials are and the xl
> > dont
> > > do
> > > > that. The second way it can work it if xl will respond to
simple
> > > > and - info but i dont think it do that either. This stuff is
old
> > in
> > > > my mind but i talked with Aaron about it here through the
board
> > and
> > > > in the end i did not buy a pocket dial.
> > > > Do a search for Dial and you may come up with the old posts.
> > > > Peace
> > > > Mike G
> > > > --- In xl7@yahoogroups.com, "Turby Schmidt"
<trabantmusic@h...>
> > > wrote:
> > > > > ups... why the pocket dial wont work with XX7 ????
> __________________________________
> Do you Yahoo!?
> SBC Yahoo! - Internet access at a great low price.
> http://promo.yahoo.com/sbc/
