Digital out problems
2002-01-21 by erik_magrini@Baxter.com
Hey all, ran into a problem trying to use my XL-7's S/PDIF port this
weekend.  I'm sure it's not Emu related, but was wondering if anyone had
any ideas that might help me out.  Basically, I had recorded all of my
MIDI for a new track into Cubase, and next I needed to transfer all of the
tracks as audio into Cubase.  On my last track where I did this, I
completely forgot about the SPDIF port on the back of the XL-7 (one of the
reasons I got it too, doh!) so I did all the transferring via the analog
outs.  This time I wanted to keep it all as clean as possible, so I
attempted to use the digital out.  I hooked the XL-7 up to my Layla24 via
a Monster Cable digital cable I had previously used to transfer samples to
my Akai S3000Xl from a CD player.  After changing  all the right settings
for my Layla to be working via SPDIf, I set about trying to record the
audio into Cubase.
The problem, was that although I could hear my XL-7's audio, there was
alot of digital noise randomly interlaced with it too.  It was that
annoying crackling variety that would max out my inputs everytime it
cracked, and basically made using the digital outs impossible as I
couldn't get a clean signal for the life of me. I thought it might be a
bad cable, so I swapped it with a regular RCA cable (non-digital, I know
not ideal) I knew was good.  The same thing happened only the crackling
was much worse.  So I'm guessing it might be a bad cable, and I ordered a
new one this AM.  Anyone got any other ideas on what it might be?  I know
someone used the XL-7 with an Echo Mia ok, anyone used it successfully
this way with a Layla24?
Re: Digital out problems.........is it working yet?
2002-02-08 by tommy_trance
I got my spdif to work.  I am using a Mia card by Echo and had to
set the outs to Mia's Virtual 3/4 instead of 1/2.  No more static.
It sounds really clean via spdif.
this
anyone had
of my
all of the
(one of the
analog
I
Layla24 via
samples to
settings
> audio into Cubase.
was
that
it
be a
I know
crackling
ordered a
I know
successfully
> rEalm
Re: [xl7] Re: Digital out problems.........is it working yet?
2002-02-11 by erik_magrini@Baxter.com
Thanx, I'll try that!  Still no luck, and Echo can't figure it out either!
"tommy_trance" <tommy_trance@...>
02/07/02 06:11 PM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Re: Digital out problems.........is it working yet?
this
anyone had
of my
all of the
(one of the
analog
I
Layla24 via
samples to
settings
> audio into Cubase.
was
that
it
be a
I know
crackling
ordered a
I know
successfully
> rEalm
