Yes I do have things recorded in song mode playing throught the
external channels. I could reproduce something similar, but never
get the feel of the track back. The data recorded in the song is in
the very beginning and the very end and interspersed in between. The
odd thing about this is that I can shorten the track, but I cannot
get that one pattern to start after bar 74. And this is just in play
back. If I stop the play and scroll through the bars everything
shows ok, but as soon as I hit play it will switch steps at 74 or
earlier if I reduce the lenght of any previous tracks. I have tried
resaving to different spots. I keep thinking that there must be
something I can do to jar it into working correctly. Maybe I'll sit
on it and meditate...
Thanks for letting me know your out there,
Tom
--- In xl7@yahoogroups.com, "robotchas" <robotchas@y...> wrote:
> Sounds like a bug to me, or a corrupt file...is the song in
question too complex to just
> recreate it from scratch?
> Actually, that brings up another point: is there anything recorded
in the "song" track (ie,
> the linear track that overlays the pattern chain)? Is it possible
something in there is
> messing up the sequence (don't ask me how, just thinking out loud)?
> Does it behave like this when you lengthen *any* preceding step?
What if you delete the 8-
> bar step and then re-insert it?
> I haven't done a whole lot with song mode, so I've never run into
anything like this. I think
> you've just got everyone stumped, and it's not something that's
quick or easy to
> reproduce.
> --- In xl7@yahoogroups.com, "dj 61" <dj61@d...> wrote:
> > I am going to keep posting this until someone helps! Aaron?
> > I have a song that I sequenced out in step mode. At 1 point I
had
> > a 1 bar followed by a
> > 16 bar followed by an 8 bar (all the same pattern the 8 step
> > started on bar 74) Well I
> > needed to add a bar to the one step. I did so and everything
> > seemed fine, but in
> > p[layback the 8 bar step still comes in at 74 cutting off the
16
> > bar step. In sequence
> > step it shows up right and the 8 bar sequence starts on bar 75.
> > When I scroll throught
> > the bars while stopped it shows up right, but when I push play
it
> > always starts the 8
> > bar on 74. If I add more bars before it it still just cuts off
> > 16 bar step before it and
> > starts on 74. I can reduce the bars in other steps and have it
> > come in before 74, but I
> > cannot seem to push that step back. My song is not maxxed out
on Show quoted textHide quoted text
> > steps or bars. I
> > am running OS 2.0 can any thoughts?
> > Tom
