Program Changes
Program Changes
2004-01-23 by williambithell
Can someone explain to a complete xl7 novice how to get the xl7 to
send program/bank changes for each seperate pattern to an external
synth or sampler? I just can't get me head round it, and either i'm
going blind or the manual doesn't cover this very well.
Cheers,
Will
Re: Program Changes to External Gear
2004-01-25 by steve_the_composer
--- In xl7@yahoogroups.com, "williambithell" <williambithell@y...>
> Cheers,
> Will
I seem to recall an explanation somewhere, perhaps in one of the OS
Upgrade Addenda.  Not sure, but perhaps this might work: If you set a
track to have an external only destination, you can view tick 0
info.  Try putting a program change for the external gear there.
Sorry, no time to test this; not sure it will do thew trick.  Try it
and report results back.  Try two conditions: (1) leaving track in
external destination only; (2) changing track to both internal and
external destinations.
Apologies if this is not right.
2004-01-25 by mike
The way I get this to work is to go into the event editor and put
your curser in the bottom row.  Hit repeat button and then select
program change.
this may be unclear sorry i just woke up.
hope it helps
Mike G.
--- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@p...>
to
external
i'm
> > Cheers,
> > Will
a
it
> program change.
Thanks for clarification of details, Mike.  I omitted those steps.
Also, placing data at tick 0 may or may not apply based on what you
are trying to do.
Re: [xl7] Program Changes
2004-01-26 by erik_magrini@Baxter.com
1. Go into Event List Edit, and select the track you want to put the PC
message on.
2. Press Repeat, and then immediately change the location to 00:00:001 or
00:00:000.
3. Change the Event type to Program Change, and then enter the appropriate
MSB, LSB and PC #.
4. Save.
Cheers,
Will
Yahoo! Groups Links
To visit your group on the web, go to:
Your use of Yahoo! Groups is subject to:
use of, or taking of any action in reliance upon, this information by
material from any computer.
For Translation:
Re: Program Changes
2004-01-27 by williambithell
Well, I can't seem to select 00.00.001 when pressing repeat, and
nothing happens when I put information on 01.01.001.
I'm trying to control a Supernova, where msb = 0 (but is not used
apparently) and lsb = 32, and trying to change bank (A,B,C,D), and
then bank number (0 to 127).
I know there's a way, but my megre brain obviously ain't quite up to
the job!
Can someone clarify please?
the PC
> message on.
00:00:001 or
> 00:00:000.
appropriate
> MSB, LSB and PC #.
> 4. Save.
> rEalm
i'm
> Cheers,
> Will
entity
legally
than
privilege
other
by
> For Translation:
Re: Program Changes
I still can't get anything working, and am a little confused about
msb/lsb and program change commands.
Also can't get repeat button to bring up tick 0 (using os ).
Can anyone clarify please?
the PC
> message on.
00:00:001 or
> 00:00:000.
appropriate
> MSB, LSB and PC #.
> 4. Save.
> rEalm
i'm
> Cheers,
> Will
entity
legally
than
privilege
other
by
> For Translation:
Re: [xl7] Re: Program Changes
2004-01-27 by erik_magrini@Baxter.com
I still can't get anything working, and am a little confused about msb/lsb
>>>IF you press the Audition button, you can see the MSB and LSB values
for the currently selected Preset.  If you're sequencing external gear,
you'll need to look in their manuals to see how they handle MSB and LSB
values.  They're basically bank select messages. <<<
>>>Sorry, I get that too sometimes.  You can only access tick 0 by
repeating an event already at that location.  Tick 1 will do the same
thing though, so just use that. <<<
For Translation:
>>>Press Repeat, and THEN change the start time maybe? <<<
and nothing happens when I put information on 01.01.001.
>>>Make sure you go into PAttern Edit and set that track to "EXT".  It's
the last screen. <<<
apparently) and lsb = 32, and trying to change bank (A,B,C,D), and then
>>>Well, at least you know those! >>>
Yahoo! Groups Links
For Translation:
Make sure the Supernova is set to receive external PC changes too, some
synths have a setting disabling that.  Just remembered.
williambithell <williambithell@...>
01/27/2004 10:04 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Re: Program Changes
the job!
the PC
> message on.
00:00:001 or
> 00:00:000.
appropriate
> MSB, LSB and PC #.
> 4. Save.
> rEalm
i'm
> Cheers,
> Will
entity
legally
than
privilege
other
by
> For Translation:
Yahoo! Groups Links
For Translation:
Re: Program Changes
thanks realm, and all others that helped, i've got it talking nicely
to the banks in my supernova, and will sort my sampler out too now i
know what i'm doin!
Cheers,
Will
msb/lsb
values
gear,
and LSB
same
> rEalm
entity
legally
than
privilege
other
by
> For Translation:
