--- In xl7@yahoogroups.com, "t1prod" <t1prod@y...> wrote:
> what does polyrhythms mean and how does it work?
What is a poly rhythm?
The prefix poly- means many and I take it you know what a rhythm is ,
hence:
A Polyrhythm is the result of different rhythms performed
simultaneously,:
First definition:
To qualify as a poly rhythm, the contributing rhythms should be chosen
such that the numbers denoting their rhythmic relation, are relatively
prime to each other.
Second definition:
If the sum of two (or more) simultaneously sounding rhythms results in
a subdivision of the beat that is not present in either of the
constituting rhythms, we call this resultant rhythm poly rhythmic.
Third definition:
Two different rhythmic patterns do not result in a poly rhythm (when
played simultaneously), when one of those rhythms can be contained in
the subdivision of the beat that is implied by the other rhythm.
3 3 3 3
<-------> <-------> <-------> <-------> < - etc
o o o o o o o o o o o o o - etc
1 1 1 1 1 1 1 1 1 - etc
somehow a bit like that if your screen´s big enough.
hope this helps
:Paul
