Filtering out incoming patch change messages
2003-11-11 by InfidelsRe@aol.com
I am using Sonar 2.2XL to record some songs and on one midi track that a band
member emailed to me, the XL7 is receiving a patch change message that takes
me out of the desired preset sound that I wanted (an organ sound) and changing
it to some drum set.
For some reason, even if I remove the event from the midi track, the preset
changes anyway - to that same drum kit.  I am stumped.
To take a different tack, is there some way to filter out incoming preset
change events on the XL 7 so that it only obeys the note information and does not
change the preset sound I have chosen?
Gerry D
Re: [xl7] Filtering out incoming patch change messages
2003-11-11 by erik_magrini@Baxter.com
Does Sonar send out a reset message when you stop it?
InfidelsRe@...
11/11/2003 09:55 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Filtering out incoming patch change messages
band
takes
changing
preset
does not
Gerry D
Re: Filtering out incoming patch change messages
2003-11-12 by InfidelsRe@aol.com
In a message dated 11/12/2003 2:07:07 AM Eastern Standard Time,
xl7@yahoogroups.com writes:
> Message: 13
>   Date: Tue, 11 Nov 2003 10:03:22 -0600
>   From: erik_magrini@...
> Subject: Re: Filtering out incoming patch change messages
> rEalm
Not that I know of.  After I stop Sonar the preset is still the drum kit I do
not want.
Gerry D
_____________________________________________________________
ORIGINAL MESSAGE:
band
takes
changing
preset
does not
Gerry D
Re: [xl7] Re: Filtering out incoming patch change messages
2003-11-12 by erik_magrini@Baxter.com
Maybe check to see if you have another midi track assigned to that
channel?  Double check there's not another PC message too.
InfidelsRe@aol.com
11/12/2003 09:45 AM
        cc:
        Subject:        [xl7] Re: Filtering out incoming patch change messages
> Message: 13
> rEalm
do
not want.
Gerry D
ORIGINAL MESSAGE:
band
takes
changing
preset
does not
Gerry D
