Re: [xl7] Need real time recording tips.....
2003-09-25 by erik_magrini@Baxter.com
What kind of problems are you having though?  Just not getting the timing
right?  Without knowing your exact problems, here's somethings I do
occasionally to help me with this:
- Slow the tempo down and record your parts, then speed it up to what you
want the tempo to be.
- Set your Pattern length to 32 measures, even if you only need a 8
measure pattern.  That way you have more time to get your groove on :)
ONce you get a measure (or however many you want) just right, then you can
cut and paste that voer the rest of the pattern.
- I don't like to quantize much either, but the swing settings in the XL-7
are VERY nice IMO.  Try setting a swing of 53-56% with an Amount of 65%,
use that on just the HH's or back beats.
- The pads work best after they've been hit for some time.  So if you box
is fairly new, or you haven't spent much time using the pads for note
entry, spend some time breaking them in.
I need some help programming my beats real time, I don't like to
quant.... I'm not that good step recording either.... I usually
either play the part  live and the work with a wave file or play live
and edit midi in logic. I'm really bad working with metronome
(usually get it right after a couple of bars and copy/pasting is
quite time consuming on the XL7) and I'm having problems banging my
drum parts on my xl7. I usually work with midi/wave loops so this has
never been much of a problem, but I'm trying to use more of the XL-7
to see if I could faze logic out... Do any of you have any tips or
advice that could help me out?
Re: Need real time recording tips.....
2003-09-25 by Greg
Slowing things down is probably the best advice you can get. Timing
issues usually require dedication and practice to work out. SInce you
are dealing with a machine, timing is going to be a lot more strict
than if you had a real drummer playing beats. I would recommend
picking up a basic drumming video or dvd to give you some exercises
in counting and feeling the beat. I actually started playing drums
just for that reason.
There is big difference in how things feel in more recent recordings
compared to my earlier ones where I was dropping things on the step
recorder.
Also using a midi controller keyboard such as the oxygen 8 has helped
as well.
Main thing is to count and practice. It will all come together in
time.
-Greg
timing
what you
on :)
you can
the XL-7
65%,
you box
note
> rEalm
live
has
7
RE: [xl7] Re: Need real time recording tips.....
2003-09-25 by Jonathan El-Bizri
Actually, I disagree. I'll slow things down a few bpm, but any more and
my 'feel' of the groove will start to go. Of course, this is as far
recording goes, not practicing.
You're better off getting very friendly with your 'erase track button'.
bIz
Sent: Thursday, September 25, 2003 9:23 AM
Subject: [xl7] Re: Need real time recording tips.....
recorder.
as well.
time.
-Greg
timing
what you
on :)
you can
the XL-7
65%,
you box
note
> rEalm
live
has
7
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=194081.3897168.5135684.1261774/D=egroupweb/S=1707
709865:HM/A=1732163/R=0/SIG=11n0nglqg/*http://www.ediets.com/start.cfm?c
ode=30510&media=zone> click here
<http://us.adserver.yahoo.com/l?M=194081.3897168.5135684.1261774/D=egrou
pmail/S=:HM/A=1732163/rand=522701958>
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<http://docs.yahoo.com/info/terms/> .
2003-09-25 by Greg
It is awkward at first for recording. You have to know what your
ultimate sound is going to be when recording it. It is a lot easier
to spin the bpm up and down than starting a riff from scratch every
time. But it is a matter of preference and if your results are good
in the end, then stick with the method that makes you the most
comfortable. I played guitar before using the XL7, so slowing down a
portion of a song to nail the part isn't so awkward anymore. In fact
in most I will start programming at less than 90 bpm, than do plus or
minus 10 bpm incerements to see the results. That is the beauty of
the box. No rules and freedom to experiment.
Anyway, these are merely suggestions. Everybody has there own way
doing things. It isn't like breathing where if you do it wrong you
are going to die ;)
-Greg
and
button'.
> bIz
> -----Original Message-----
> From: Greg [mailto:golerage@y...]
> To: xl7@yahoogroups.com
you
recordings
> recorder.
helped
> as well.
> time.
> -Greg
> timing
do
> what you
8
> on :)
then
> you can
> the XL-7
of
> 65%,
> you box
> note
> > rEalm
> live
my
> has
XL-
> 7
or
> ADVERTISEMENT
07
?c
2003-09-26 by david rodriguez
I would first of all recommend that you use some of the quantizing.
depending on what tempo you are using I would either go with the 16 beat at
120 to 160 or 32 beat quantizing for the 100 to 50 bpm. Then I would
recommend you just record some weak conventional bass or chords to start
your song off with then add a snare and kick drum maybe just to start the
tempo quantized of course. Then once you got a weak little song going on add
some high hats on a third track tweaked to your hearts content of course.
Then get rid of the first bass or chords that you started off with because
you dont want that in your song. then with your make shift drum patten as
the only two existing tracks I want you to find that song youve always
wanted to write and then write it. I find this method to be great It really
challenges the unconcious to make something out of nothing and youll be
surprised by the results youve come up with. Then once you got something
started take the quantizing off and use another similar but completly
different drum kit to add some accents to your drum track or maybe now that
you got something going you want to completly get rid of the existing drums
and play something else. and maybe you can layer drum tracks by copying an
entire track and placing it in a new track afew times and use a different
kit. The emu is very flexible this way.. oh and by the way in the begining
you want to work with at first a 2 bar sequence at first then you should
extend that beat to 4 bars then you can come up with the high hats and
extend all tracks to 8 bars then you can begin adding accents with another
kit in the 8 bar sequence
>From: "sincultura13" <sincultura13@...>
>Reply-To: xl7@yahoogroups.com
>Subject: [xl7] Need real time recording tips.....
>Date: Wed, 24 Sep 2003 22:12:16 -0000
>Thanks in advance...
Add MSN 8 Internet Software to your existing Internet access and enjoy
patented spam protection and more.  Sign up now!
http://join.msn.com/?page=dept/byoa
2003-09-27 by Christoph Kluxen
I think its very useful to set a footswitch for Punch in and out, that gives
me a lot of freedom, besides the
erase button + track is a fast way to erase a track.
Christoph
NEU FÜR ALLE - GMX MediaCenter - für Fotos, Musik, Dateien...
Fotoalbum, File Sharing, MMS, Multimedia-Gruß, GMX FotoService
Jetzt kostenlos anmelden unter http://www.gmx.net
+++ GMX - die erste Adresse für Mail, Message, More! +++
2003-09-29 by sincultura13
Thanks to all for the tips. It looks like it's just a matter of
getting used to cut and pasting on the XL-7.... I have a couple of
footswtiches around that I'm going to give a try and I already slow
down the BPM a bit to bang beats down. The swing setting I'm also
going to look into. I take from Realm comment that it can be set for
each part... I always thought it was far all the tracks...
 Also I was reading the other day on recording magazine that you
could use the two effect boards for each preset, is that true?
thanks again...
--- In xl7@yahoogroups.com, "Christoph Kluxen" <pocketd@g...> wrote:
> Hi,
that gives
> Christoph
2003-09-29 by Stu
No this is not possible. You can send all the presets to the same 2 effects
but you can't have different effects on each preset.
Stu
Re: [xl7] Re: Need real time recording tips.....
2003-09-29 by erik_magrini@Baxter.com
The swing setting I'm also going to look into. I take from Realm comment
that it can be set for each part... I always thought it was far all the
tracks...
>>>Yeah, you can apply the quantize seperately to each part, but it's not
a real-time effect.  IE, you can't just change the parameters and have the
new settings be instantly applied to the selected part. After you change
the settings, you need to manually apply them only to the parts you want.
The manual should sort you out on the specifics of the proceedure, but
feel free to ask any questions if you're having problems. <<<
Also I was reading the other day on recording magazine that you could use
>>>Yes and no.  Here's a cut and paste from the FAQ on this:
There are two Effects processors available in the Command Stations at any
time, regardless of whether you're only playing a single Preset, or a
Pattern with 16 Tracks. You can use the Effects in one of two ways, each
selected from the Global menu. The first is where the Preset on the active
MIDI channel controls the Effects, and therefore all the Effects settings
are used as stored with that Preset. This way works best if you're only
playing a single Preset at a time.
The second method for using the Effects is in Master Effects mode. In this
case, all Presets share the same two Effects, and the Effects and their
settings are saved as a part of each Pattern. However being able to only
turn the Effects on or off for each part is not very flexible, so E-Mu
uses Effect Sends to increase your options. Just like there are only two
Effects for the entire Command Station, there are only four Sends for the
entire unit as well. The send amounts for each effect are freely
assignable in the Global menu. For instance, say your first effect is a
reverb, and your second is a delay. You can specify how much reverb you
want to be applied to Send 1, as well as how much Delay you want to be
applied to Send 1. Say you set your reverb amount to 5% on Send 1, and
your delay amount to 27% on Send 1. In this configuration, any Track you
route to Send 1, will have about 5% reverb on it, and then it has 27% of
the delay effect added to it. If you only wanted reverb for instance, you
would just set the delay amount for that Send to 0%, and now all Tracks
routed to Send 1 will only have reverb applied. You can assign more than
one Track to a Send, and you have 4 Sends to use for each whole Pattern,
giving you lots of ways to use only those two Effects processors.  <<<
2003-09-30 by sincultura13
Thanks! The swing on each track is really cool... BTW, I'm not much a
of a manual reader, but I might just have to start to read some...
Re: Effects... that was kinda what I though.... but didn't know how
flexible the Sends are. It's not quite as interesting as it could be
but being that the XX-7 has two additional pair of outs you can hook
some external effect units to its no biggie.
comment
> tracks...
it's not
have the
change
want.
but
could use
at any
a
each
active
settings
only
In this
their
only
Mu
only two
for the
is a
you
be
and
Track you
27% of
instance, you
Tracks
than
Pattern,
> rEalm
