Piano samples
Piano samples
2003-09-17 by erik_magrini@Baxter.com
Yeah, I've heard good things about that one too.  One thing to keep in
mind if you're going to go the samples route, is that you HAVE to make
sure the format is 100% supported by your sampler.  These gigantic sample
libraries are NOT something you want to set up manually by hand, even if
the sample data itself imports correctly.  Doing all of the velocity and
key crossfades could take you weeks to get right.
I think there is a Miroslav Vitous sample CD that has huge acoustic
pianos, you might search for that....
