My hair is falling out just fine on it's own, thanks.
2003-08-06 by erik_magrini@Baxter.com
Also, if you have more than one rom installed, make sure you select a
Preset on that ROM before randomizing.  As near as I can tell, the
Randomize function only work on the current ROM, not on all of them at
once.
P.S: Thanks again for Randomizing advice ! Not a day without trying
it..... (1/100 I get extraordinary sounds !!!!)
Re: Randomize
2003-08-06 by xromxx7
a
at
> once.
> rEalm
I have one randomized preset that get XROM in some layers (but it's
set to none !) and BEAT GARDEN in another (with a valid instrument on
it).......I don't know , maybe I tweaked it and don't remember maybe
because I'm overusing this function , I'll check this out a little
better in near future....
XROM
Re: [xl7] Re: Randomize
No, that could be, I'm not sure exactly.  The few times I tried to check
this out, it always came up with the same ROM for all layers.  But, since
it's random, we may never really know :)
XROM
Re: Randomize
2003-08-06 by steve_the_composer
The few times I tried to check this out, it always came up with the
same ROM for all layers.  But, since it's random, we may never really
know :)
on it).......I don't know , maybe I tweaked it and don't remember
maybe because I'm overusing this function , I'll check this out a
little better in near future....
XROM
>>  These are some of the reasons I want to develop the parametizer
software.  I've been working on it as time permits.  I've been
testing a number of possibilities, including a short cut using sysex
commaands.
>> Unfortunately, I cannot trigger randomize via sysex EXCEPT to
automate simulated front panel button presses.  Its a far cry from
what I have in mind for the parametizer, but I could create a midi
file that would automate, for example, 127 presses of the randomize
button, storing each result in User bank 0.  Let me know if this
would be helpful as a start.
>>BTW, to minimize the chance of an accidental/unwanted erasure of an
entire bank of presets, I would set the mid file to operate on an
upper device ID--eg 120.
>> I'm also getting "random" presets with the same ROM instrument in
all 4 layers.
>> To address an earlier suggestion, part of my goal is to have
namable randomizer configurations.  EG, you may want to save a
configuration file to generate "randomized" presets that use 1 or 2
layers, each with a different ROM instrument selected from a
customized list of instruments, where certain parameters selected
from a customized list are "randomized," while others are left
untouched, etc.
Dr. Steve
Re: Randomizer
I used to think (with other synths) that EVERYTHING was possible thru
SYSEX , not only front panel commands but many other hidden
operations not doable by any other means than sysexes....(Maybe
because these synths had very limited front panel commands....Anyway
Mega Kudos for KORG X5dr, TR Rack etc...)Obviously (unfortunately)
Sysex implementation seems to be one of the weak point of our beloved
command stations...(BTW why P2500 understand some sysex functions
that our XX7 just ignore , are'nt they supposed to be very similar ?)
> Its a far cry from what I have in mind for the parametizer, but I
>could create a midi file that would automate, for example, 127
>presses of the randomize button, storing each result in User bank
>0.  Let me know if this would be helpful as a start.
Automated generation of whole banks of randomized presets ! Sure it
could be usefull ...though it would be cool we had some way to choose
the target user bank (to avoid erasing the one where our most used
presets are stored : in my case banks 0 & 3 )...But if it's not
possible I can go with bank 0.......
in all 4 layers.
After discussing with rEalm I tried many times randomizing presets
today and always had the same rom on all layers too, so .....
> untouched, etc.
If you could manage to do this it would make me very very happy !!!!
Best Regards
XROM
2003-08-07 by erik_magrini@Baxter.com
>>>Any chance the User Bank could be specified?  I personally have Banks 0
and 1 full already, so for me personally, bank 3 would be the best.  Also,
from a writing standpoint, when I work on music I like to hear what I'm
doing while playing with Randomize.  So even though I could get around the
problem by just doing a sysex back up of my Bank 0, I then wouldn't be
able to hear my patterns that needed those Presets, and thus I wouldn't
know which Randomized Presets I might want to end up using.  I'm tired,
did that make sense?  :) <<<
Re: Randomizer
2003-08-07 by steve_the_composer
> choose the target user bank (to avoid erasing the one where our
> most used presets are stored : in my case banks 0 & 3 )...But if
> it's not possible I can go with bank 0.......
Thanks for the feedback.  It may be possible to do this.  The current
(in progress) version has 5 basic sysex banks as follows:
     0 - Open Remote Control Session
     1 - Reset Current Preset to 000-0
     2 - Reset Save Preset to 000-0
     3 - Randomize & Save # 1
     4 - Randomize & Save # 2 +
     5 - Close Remote Control Session
The file "plays" sysex banks 0 -> 3 and then bank 4 126 times to
randomize and save a total of 127 presets.
I might be able to rewrite the banks so that if you omit one of the
sysex banks, the presets will be stored starting from whatever preset
you manually set up in the "save preeset to" menu.
Another option is to have a sysex bank that holds only the sysex
command for the starting preset.  This way, you could set it yourself
by editing the one sysex command and then save your customized file
for future use.
Part of the design allows users to decide how many consecutive
presets to create by editing the number of times sysex bank 4 (in the
above configuration) is "played."
Of course, all this presumes you have a sequencer that gives you
access to the sysex banks.
Not to get anyone's hopes up, but this is nothing more than
automating front panel button presses.  The really cool software
(parametizer) has a long way to go.
Question: Does using MIDI Sysex ID 120 make sense to you?  I see it
as a way to help minimize accidental overwriting of desired presets.
Dr. Steve
Re: Randomize
Thanks for the feedback. Some comments:
See reply to XROM on this issue
> Also, from a writing standpoint, when I work on music I like to
> hear what I'm doing while playing with Randomize.
I have several thoughts on this, but it would help if you could give
me a brief explanation of your "modus operandi" with regard to
testing out randomized presets.
Dr. Steve
Re: Randomizer
2003-08-08 by xromxx7
--- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@p...>
>preset you manually set up in the "save preset to" menu.
I was thinking about a bunch of sysex strings all in one midi track,
you hit play and there you go...Dividing it in five parts is so much
clever ! I like the idea of omiting sysex banks in order to manually
set up the starting preset (=bank to be overwritten : In my case it
would be preset 000Bnk1 or preset 000Bnk2!)
>yourself by editing the one sysex command and then save your
>customized file for future use.
This way is even better, but it could scare people unfamiliar to
sysex editing. It would be cool to have both options but if it's not
possible, last method with a detailed "How to" document could do the
trick !!
>the above configuration) is "played."
Haaaa sounds quite good to me !!!(BTW how would you do this ?)
My SONAR 2.2XL is awaiting for your file my friend !!!!
BTW rEalm said he likes to hear each randomized preset, this is not a
bad idea ! Could it be possible that after every randomized preset we
hear 2 or 3 notes played in sequencer or audition button or whatever ?
>presets.
Hmmmm...I do think that the easiest & safest way, is to do a sysex
dump of user banks BEFORE dealing with Parametizer ! If I use it
intensively, nothing will prevent me from doing wrong after I have
set up my machine ID to 120 !(after 2 or 3 beers for example !)
Best Regards
XROM
2003-08-08 by erik_magrini@Baxter.com
Typically, once my drums are more or less laid out, I just start jamming
on a free track.  I'll pu the Xl-7 so it's on the Randomize page (with the
knobs in Quick Edit mode) while my pattern plays, and just keep hitting
the Enter button while I play until I find something that catches my
interest.  Sometimes the randomized preset is good as is, sometimes I
think I can tweak it to get the desired result.  Once I get something I'm
happy with, I name it, disable any unused layers in the preset, and then
move on to the next track.  All while the patterns plays though.
Some randomized sound cool on their own, but more often than not it's how
it fits in the context of the song I'm working on that matters.
