Wiardgroup
Index last updated: 2026-04-28 23:41 UTC
Two questions about module layout
2008-06-01 by Mark Griffiths
hi there,
I've been looking at the patch sheet on the Wiard site. It shows the Classic VCO, next to the Sequantizer, which is next to Envelator, then comes the Waveform City, Filter and Mixolator. I was suprised to see the Sequantizer and Envelator between the two oscillators, does anyone know why?
Second question which might be redundant deping on the reply to the above. I have the Wiard rack frame which will take 6 modules. I have 7. I have 2 Osc, 1 Borg, 1 Sequantizer, 1 envelator and 1 mixolator configuration, plus I have a Wooglebug. I was thinking of leaving the Wogglebug as a "free module" partly because it feels complete in itself, partly because I'm also using it on the Blacet/Wiard/Banalogue Frac rack. But I guess you could give similar arguments about the Sequantizer. What would you do?
regards, Mark
Re: [wiardgroup] Two questions about module layout
2008-06-02 by kwote uno
get another rack. put the wogglebug in there and fill it up with 5 more 300 modules. :)
On Sun, Jun 1, 2008 at 11:47 AM, Mark Griffiths <mark@inspiringsounds.com> wrote:
hi there,
Second question which might be redundant deping on the reply to the above. I have the Wiard rack frame which will take 6 modules. I have 7. I have 2 Osc, 1 Borg, 1 Sequantizer, 1 envelator and 1 mixolator configuration, plus I have a Wooglebug. I was thinking of leaving the Wogglebug as a ";free module" partly because it feels complete in itself, partly because I'm also using it on the Blacet/Wiard/Banalogue Frac rack. But I guess you could give similar arguments about the Sequantizer. What would you do?
regards, Mark
http://www.kwotemusic.com
http://www.kwotemusic.com/store.html
Re: Two questions about module layout
2008-06-02 by drmabuce
Hi Mark
   all of the 300 series modules have a 'stand-alone voice' but if i
place myself, arbitrarily, in the situation you describe, i'd be
inclined to isolate the Wogglebug.
(i'd also remount it in a lucite dome and bend it photoresistors but
that's another story altogether!)
tgim,
-doc
--- In wiardgroup@yahoogroups.com, Mark Griffiths <mark@...> wrote:
> hi there,
know why?
> regards, Mark
2008-06-02 by Grant Richter
If you use the Classic VCO in low mode as a clock source, then all the waveforms from the
Classic VCO, Sequantizer and Envelators will be in phase and make musical sense.
The timing of the pulse is taken from the sawtooth so only the back edge modulates with
PWM, this makes sense musically. The random output from the Classic VCO updates on
the raising edge of the pulse output, like a sample and hold module would.
> hi there,
> regards, Mark
