MOTM Power Cables
2000-12-05 by keithw@cix.compulink.co.uk
Hi Paul, List, does anyone happen to know the Farnell order code for the power cables used on the MOTM modules? (Between the MTA connectors) I am having trouble identifying it and my eyesight is rapidly decaying looking at the small print on the catalogue pages. TIA Keith http://home.freeuk.net/lowpass
2000-12-06 by Paul Schreiber
The cable is custom made. It uses AMP MTA-156 crimp connectors and 18ga wire. I sell the cables in the catalog. Paul S. ----- Original Message ----- From: <keithw@...> To: <motm@egroups.com> Cc: <keithw@...>
Sent: Tuesday, December 05, 2000 2:47 PM Subject: [motm] MOTM Power Cables > Hi Paul, List, > > does anyone happen to know the Farnell order code for the power > cables used on the MOTM modules? (Between the MTA connectors) > I am having trouble identifying it and my eyesight is rapidly decaying > looking at the small print on the catalogue pages. > > TIA > > Keith > > http://home.freeuk.net/lowpass > > > > >
2000-12-06 by weather
> > does anyone happen to know the Farnell order code for the power > > cables used on the MOTM modules? (Between the MTA connectors) > > I am having trouble identifying it and my eyesight is rapidly decaying > > looking at the small print on the catalogue pages. hello, i have them here, i had a minor problem not being able to get the correct wire guage, but: 0.156" four way housing - 588-910 (24awg) 0.156" four way header - 589-068 (24 awg / friction lock straight) 0.156" four way dust cover - 589-019 0.1" four way dust cover - 588-350 0.1" four way header - 588-593 (24awg / friction lock straight) - the bit on the board 0.1" four way housing - 588-179 (24awg) - the bit on the cable the 0.1" sizes are used on the earlier Oakley modules, sorry i don't have any sizes. important - please check when ordering that i've not dropped a digit here, i'd hate to have you ordering something bizarre i'd also highly recommend getting some kind of impact tool to assemble these, a tenner spent is well worth keeping all your fingers intact... cheers paul b
2000-12-06 by keithw@cix.compulink.co.uk
In-Reply-To: <002501c05f63$8ce9afa0$5e1ca6c3@pavilion> Hi Paul, I already have the correct MTA connectors, its the correct cable I was after many thanks for your trouble anyhow Keith http://home.freeuk.net/lowpass
> hello, > > i have them here, i had a minor problem not being able to get the correct > wire guage, but: > > 0.156" four way housing - 588-910 (24awg) > 0.156" four way header - 589-068 (24 awg / friction lock straight) > 0.156" four way dust cover - 589-019 > 0.1" four way dust cover - 588-350 > 0.1" four way header - 588-593 (24awg / friction lock straight) - the bit on > the board > 0.1" four way housing - 588-179 (24awg) - the bit on the cable > > the 0.1" sizes are used on the earlier Oakley modules, sorry i don't have > any sizes. important - please check when ordering that i've not dropped a > digit here, i'd hate to have you ordering something bizarre > i'd also highly recommend getting some kind of impact tool to assemble > these, a tenner spent is well worth keeping all your fingers intact...
2000-12-06 by Tony Allgood
> does anyone happen to know the Farnell order code for the power > cables used on the MOTM modules? (Between the MTA connectors) > I am having trouble identifying it and my eyesight is rapidly decaying > looking at the small print on the catalogue pages. I use the Molex 0.156" connectors or other Farnell equivalent. These are compatible with the MTA stuff, but they are crimp connections as opposed to IDC. IDC can be a fiddle without the right tool. You can also solder them too, and this is what I do. If you solder into crimp connectors, you can use pretty much any wire size you need. It takes a bit of practice, but it gives a very good finish. UK 13A mains cable provides nice and cheap wire for this very purpose if you strip the outer casing off. My main reason for doing this is that my system has only one end of the power cable wired to plugs. The other end is soldered to a four way bus bar that runs along the length of the cabinet. ( Its a bit sad to chop off one end of the MOTM cable... ) I use 22A twin and earth cable and strip the 2 copper wires from this to form the bus bars. Its not star earthing of course, but the bar thickness keeps the resistance to a minimum, and hasn't appeared to give any problems yet. Each 2U or 3U wide space has its own power connector dangling from the bars. The bars are held into place by small bits of wood screwed to back panel. The wood has four little holes through it to guide the wire. But what I would like to see is a long 8U wide PCB with 12 MTA headers on it all star connected to an input one. This could be used instead of the bus bar system for all those wooden cabinet people. Paul? Regards, Tony Allgood Penrith, Cumbria, England Oakley Modular Synth and TB3030: www.techrepairs.freeserve.co.uk/projects.htm My music: www.mp3.com/taklamakan
2000-12-07 by Tkacs, Ken
You could always get Paul's super-long cable and cut it in half to get two single-ended power cables. Just a thought. I thought there *was* an enlarged power distribution board in the works...? The current one has 11 connectors after power supply connection, which is far too little for us cabinet guys. You can gang multiple boards, but you lose one or two connectors on each every time you do this.
-----Original Message----- From: Tony Allgood [mailto:oakley@...] Sent: Wednesday, 06 December, 2000 3:20 PM To: motm@egroups.com Subject: Re: [motm] MOTM Power Cables ...Its a bit sad to chop off one end of the MOTM cable...
2000-12-07 by Nathan Hunsicker
You really shouldn't use the MTA connectors to gang multiple boards, try running a second set of wires from the power supply to the faston connectors on the power distribution board. This only gives you 24 connections, but it will keep you from running too much current through the first board and/or wires. -Nate --- In motm@egroups.com, "Tkacs, Ken" <ken.tkacs@j...> wrote:
> > You could always get Paul's super-long cable and cut it in half to get two > single-ended power cables. Just a thought. > > I thought there *was* an enlarged power distribution board in the works...? > The current one has 11 connectors after power supply connection, which is > far too little for us cabinet guys. You can gang multiple boards, but you > lose one or two connectors on each every time you do this. > > > -----Original Message----- > From: Tony Allgood [mailto:oakley@t...] > Sent: Wednesday, 06 December, 2000 3:20 PM > To: motm@egroups.com > Subject: Re: [motm] MOTM Power Cables > > ...Its a bit sad to chop off one end of the MOTM cable...
2000-12-07 by Paul Schreiber
There is a super-duper long one in the works. I'm ordering connectors for it today. Paul S.
how many connectors? approx what price? -Nate --- In motm@egroups.com, "Paul Schreiber" <synth1@a...> wrote:
> There is a super-duper long one in the works. I'm ordering connectors for it > today. > > Paul S.
2000-12-07 by Dave Bradley
Actually, to strictly maintain the star system, the best thing to do would be to attach the PS to a terminal strip, then run each power dist board directly back to the terminal strip instead of plugging them into each other. Then you don't lose 1 plug per board. Moe --- In motm@egroups.com, "Tkacs, Ken" <ken.tkacs@j...> wrote: > > I thought there *was* an enlarged power distribution board in the works...? > The current one has 11 connectors after power supply connection, which is > far too little for us cabinet guys. You can gang multiple boards, but you > lose one or two connectors on each every time you do this. >
