Re: [motm] 410 HELP!!!
2000-04-28 by Paul Schreiber
IT'S IN BACKWARDS!!!!
To: MOTM Newsgroup <motm@egroups.com>
Sent: Thursday, April 27, 2000 10:57 PM
Subject: [motm] 410 HELP!!!
> I just finished the 410 tonight, the filters work fine as do the depth &
> sweep controls however, I cannot get the internal LFOs to work. My rate
> knob does nothing and upon further investigation I found that the TL074
> op amp is getting VERY hot. Any ideas? I double checked all my
> connections and solder joints, everything is in the right place and
> facing the right way. I cannot figure it out, any help would be
> appreciated. Thanks -Nate
> Was the salesman clueless? Productopia has the answers.
> http://click.egroups.com/1/3019/3/_/529958/_/956894148/
2000-04-28 by Nathan Hunsicker
You're absolutely right!!! Why do they have to confuse me by putting a dot
and a notch on the case? I must have checked it 10 times before noticing.
-Nate
>Paul S.
>----- Original Message -----
>From: Nathan Alan Hunsicker <nate@...>
>><http://click.egroups.com/1/3019/3/_/529958/_/956894148/>http://click.egroups.co
Also, could I have done any damage to the op amp by running it backwards?
(it was only for 2 or so minutes) If I damaged it, is it any different
thana standard off-the-shelf TL074? And just a curiosity question, what are
the vactrol units actally designed to do? some sort of LED driver? -Nate
>-Nate
>>Paul S.
>>><<http://click.egroups.com/1/3019/3/_/529958/_/956894148/>http://click.egroup
>>>s.com/1/3019/3/_/529958/_/956894148/><http://click.egroups.co>http://click.egrou
>>>ps.co
2000-04-28 by J. Larry Hendry
> Paul S.
>From: Nathan Hunsicker <nate@...>
> me by putting a dot and a notch on the case? I must
> -Nate
That is an easy mistake to make, and easy one to avoid.  I did the same
thing myself because of confusion on ICs marked with the dot instead of the
notch (different IC though).  That was the only time for me having a MOTM
module not work perfect on first try.  Something Paul told me (another
thing obvious) that I never even realized is that the writing on the chips
are all the same direction too.  So, another last check before smoking your
favorite op amp is are they all facing the same so you can read the numbers
(as a last "did I screw anything up" before power up re-check).  So far, on
MOTM, Paul has made them all face the same way.
Larry H.
ALWAYS compare the orientation of the writing on the top with the other ICs
if there is any question.
To: <motm@egroups.com>
Sent: Friday, April 28, 2000 7:41 AM
Subject: Re: [motm] 410 HELP!!!
-Nate
>Paul S.
ups.co
Get paid for the stuff you know!
Get answers for the stuff you don't. And get $10 to spend on the site!
http://click.egroups.com/1/2200/3/_/529958/_/956925768/
I would replace it. It's off-the shelf, nothing special.
The vactrol is a combination LED and photocell. It's a variable resistor!
Sent: Friday, April 28, 2000 7:52 AM
are
dot
> >-Nate
> >>Paul S.
rate
TL074
roup
k.egrou
> >>>ps.co
> Earn free CDs from Amazon & CDNow? True!  New site needs
> music fans of Rock, Soul, HipHop, Jazz, Country & Dance.
> Get paid to listen to music you love.  JABOOM.com
> http://click.egroups.com/1/3760/3/_/529958/_/956926630/
If I understand this correctly, the vactrol is a variable resistor who's
value is set by the brightness of an internal led. Wouldn't this be a
somewhat easy solution to those of us looking to add cv control over an
existing pot? Of course, I don't even know if these pieces are still in
production, readily available, or what the specs are. (value, tollerance,
current) -Nate
>Paul S.
>are
>dot
>> >-Nate
>> >>Paul S.
>rate
>TL074
>>>><<<http://click.egroups.com/1/3019/3/_/529958/_/956894148/>http://click.egro
>>>>ups.com/1/3019/3/_/529958/_/956894148/><http://click.eg>http://click.eg
>roup
>>>>s.com/1/3019/3/_/529958/_/956894148/><<http://click.egroups.co>http://click.
>>>>egroups.co><http://clic>http://clic
>k.egrou
>> >>>ps.co
>><http://click.egroups.com/1/3760/3/_/529958/_/956926630/>http://click.egroups.co
Remember, it's a *resistance*, not a pot with a wiper! In some cases, you
can do it
but in most you can't.
Sent: Friday, April 28, 2000 8:59 AM
> current) -Nate
> >Paul S.
backwards?
> >are
driver? -Nate
> >dot
noticing.
> >> >-Nate
> >> >>Paul S.
depth
> >rate
> >TL074
egro
> >roup
ick.
> >k.egrou
> >> >>>ps.co
ups.co
> Make music with anyone, anywhere, through FREE Internet
> recording studio software. FREE software download!
> http://click.egroups.com/1/3729/3/_/529958/_/956930425/
