Re: [motm] algorithmic composition software
2000-04-02 by Paul & Alleyne
>one i didn`t see mentioned was "tangent"
>see :
>http://www.randomtunes.com
>my friend, jack deckard ( programmer of "s.a.c." from the old c64 days, a
>former amiga user and now "on the dark side" using wintel ), recommended it
>to me highly.
hello all
i just got around to do
_))))            ///////////////// (and that would be hello from thomas the
cat)
i just got around to downloading Tangent, unfortunately, as i also found
with Koan, i haven't the faintest idea what i'm doing. Koan was more
instantaneous, while Tangent kind of lurks then suddenly blurts a pile of
notes at you - this was with the MOTM & MC202 hooked up. i routed Tangent
through the GM module on my soundcard (as a last resort) - there's some
pretty good stuff going on - however it seemed so easy to sound like a
teenage classical muso - so i set all the controls to random, and then was
forced to give up
i think both programs have a great deal of potential for MOTM users, but
they take an awfull lot of setting up to work with monophonic instruments
anyone else had a go with either of these programs..?
cheers
paul b
> Here's a link to FractMus, a fractal music generator.
>It can work in mono,(up to 16 chan. if you want) so if
>you have a MIDI to CV converter and a PC, your set.
>http://www.geocities.com/SiliconValley/Haven/4386/
>There is a link section on this site with many other
>generators out there.
hello all
that Fractmus is pretty good - i was still making a terrible racket, but i
printed the manual this time
cheers
paul b
(#440 due for touchdown middle of next week - whoopee)
2000-04-03 by davevosh@aol.com
In a message dated 00-04-02 11:40:01 EDT, you write:
<< Anyone remember the Muse? >>
terry,
yeah ! from tridex.....little box with some sliders and buttons that
"composed' music.....haven`t thought about that one in a long time ! an
emulator for it might be cool !
best,
dave v.
<< http://www.geocities.com/SiliconValley/Haven/4386/ >>
terry,
thanks for the url, i`ll most certainly have to take a look even if my pc
lacks a midi interface. one day, i`ll get a more modern computer and will be
able to put some of this stuff to good use !
have you seen :
http://geneticmusic.com/software/index.htm
they also look to have some interesting stuff available.
best,
dave v.
RE: [motm] algorithmic composition software
2000-04-03 by Tkacs, Ken
I used to use a program called "Sound Globs" ages ago. It was a DOS program
that addressed the MPU-401 (or compatible) directly, so I doubt it would
behave well under Windows, otherwise I'd drag it out and try it again.
The key to using these kinds of programs is lots of editing. I did some neat
pieces with Globs, but you kind of have to tinker with it for a long time to
get the right feel, then record an hour of MIDI data, then use your
sequencer to edit the hell out of it.
