My '120 has gas!
2000-03-09 by Paul Schreiber
> From: mark scetta <n0nspaz@...> > > ah. so i will try to trigger my arp omni ii's gate along with my original > audio source at the same time in order to get the envelope i need. but, if > my audio has a fast attack, and i preamp'd it, wouldn't that create a large > enough voltage to open the gate on the EG? Perhaps. But that's not the proper use of the GATE input. > ah, but then i'd have to close it.....i think i am getting this. What goes up, must come down. Spinnin' wheel, got to go 'round...... > > when i insert a signal into my '120 it returns a harsh, LF beating, like > it's got major intestinal gas or something :) This is correct! Ain't it great! *Exactly* what were you expecting? Again, READ the manual. This circuit generates SQUARE WAVES. The ultimate clipping device. The module is *designed for VCOs/LFOs as the input, NOT audio*. If you DO put audio in there, it will clip the bejezus out of it. Bivins thinks this is a good thing! Paul S.
