> -----Original Message-----
> From: Dave Bradley [mailto:daveb@...]
> Sent: Wednesday, March 01, 2000 10:35 AM
> To: motm@onelist.com
> Subject: RE: [motm] MOTM-120 Troubleshooting
> From: "Dave Bradley" <daveb@...>
> I don't have a schematic here at work, so my instructions may be a bit
> fuzzy. Also, I don't know your technical level, so I apologise if I
> inadvertantly insult you...
> Can you read a schematic well enough to find the opamp (triangle
> symbol with
> inputs marked + and -) that the B input feeds? If so, you want to
> listen to
> the output pin of the opamp to see if there is signal there.
> There will be 2
> amps on the same chip, so the output pin will probably be either pin 1 or
> pin 7. The easiest thing to do for me is to take a spare jack and solder a
> couple of wires to it. Tack the ground wire to ground someplace (another
> jack's ground is convenient), plug some headphones in and power the module
> up. Then VERY CAREFULLY touch the hot wire to the correct opamp output pin
> and listen for signal. Don't touch anything else!
> If you have a signal there, we'll have to dig further. I suspect
> you won't.
> If you don't have a signal, then something is messed up in your input
> circuit. It could be a short in the coax cable, or a bad opamp chip.
> If you have a multimeter, desolder the hot wire of the B input from the
> circuit board, unplug the B input jack, and test for resistance
> between the
> hot and ground wires of the B input coax. I have had shorts occur there.
> Dave Bradley
> Principal Software Engineer
> Engineering Animation, Inc.
> daveb@...
> > From: telepath@...
> > >If you put an audio signal into the B input and turn up the
> > input knob, can
> > >you hear it at the output?
> > No, I can't.
> > >Dave Bradley
> > >daveb@...
> > >> From: telepath@...
> > >> Finished putting together my first MOTM module, the 120 Sub-Octave
> > >> Multiplexer and power supply.
> > >> Input A works fine, no problems.
> > >> Input B doesn't seem to work in Cross Mode. I've checked the
> > wires to the
> > >> jack and there is continuity to the board.
> > >> Since Input B doesn't work when in Cross Mode I'm wondering if
> > anyone has
> > >> any advice on further troubleshooting this problem.
