Modules depth - future needs?
2000-02-28 by ivancu@aol.com
I'm ordering my cases and want to make sure that I'll be set for future
modules.  The  front/back depth of the case which modules can occupy is eight
inches.  Will this be enough for future modules such as the sequencer?
I am aware of the stability issue, but these will have lids on the back and
will sit tilted back on stands.
Ivan
Re: Modules depth - future needs?
2000-02-28 by alt-mode
Ivan,
I think Paul has been keeping the modules so they will always fit into those SKB 12
U cases that pop up so 8" should be plenty.  However...where are you planning to put
your power supply?   If you are planning to put it in the rear of your case, you
will need to plan a bit carefully to have enough clearance for the power supply and
the modules together.  Worst case, you would have to put multiple panels and EGs in
front of the power supply if the space is too tight.  I'm planning on 8.5" and I'll
need to mount the PowerOne supply sideways on the bottom of the case to make sure it
clears all the modules.
Eric
> Ivan
_________________________________________________________
Do You Yahoo!?
Get your free @... address at http://mail.yahoo.com
In a message dated 02/28/2000 4:53:32 PM, alt_mode@... writes:
<< However...where are you planning to put your power supply?   If you are
planning to put it in the rear of your case, you will need to plan a bit
carefully to have enough clearance for the power supply and the modules
together.... I'm planning on 8.5" and I'll need to mount the PowerOne supply
sideways on the bottom of the case to make sure it clears all the modules. >>
The power supply will bolt inside the 2.5" deep rear lid, so it will only
protrude slightly into the module space.  I just don't want rears of modules
poking out the back when I remove the rear lid.
Ivan
2000-02-29 by Paul Schreiber
I do not plan for the sequencer to be deeper than other modules. It will
use surface-mount technology (pre-assembled, like the '900 supply).
I *would* mount it on the lower half of a rack: it *will* be heavy!
To: <motm@onelist.com>
Sent: Monday, February 28, 2000 3:15 PM
Subject: [motm] Modules depth - future needs?
> From: ivancu@...
eight
and
> Ivan
> Free 100 Song CD!
> http://click.egroups.com/1/1992/2/_/529958/_/951772579/
RE: Modules depth - future needs?
2000-02-29 by Brousseau, Paul E (Paul)
What?  Pre-assembled?!?  Nooooooo!!!  How could you do this to us?!?  I was
looking forward to spending 24 straight hours with a solder gun in hand...
--PBr  :)
> -----Original Message-----
> From:	Paul Schreiber [SMTP:synth1@...]
> Sent:	Monday, February 28, 2000 6:37 PM
> To:	motm@onelist.com
> Subject:	Re: [motm] Modules depth - future needs?
Re: RE: Modules depth - future needs?
2000-02-29 by ivancu@aol.com
In a message dated 2/28/2000 9:45:12 PM, PaulBr@... writes:
<< I was looking forward to spending 24 straight hours with a solder gun in
hand... >>
I want to watch you use a solder gun with SMT devices!
Sorry, couldn't resist.  I do however wonder about the future of us hobbyist
types who enjoy picking up the soldering iron and clipping leads.  I've
played with SMT and it isn't fun... or practical to do at home.
Ivan
2000-02-29 by J. Larry Hendry
Heavy ??  What are we talkin'  here?  Tubes and electromechanical relays?
<snicker>
Larry Hendry
2000-03-01 by Paul Schreiber
I't not *all* assembled, just some of it.
Sheesh.
Sent: Monday, February 28, 2000 8:44 PM
Subject: RE: [motm] Modules depth - future needs?
> From: "Brousseau, Paul E (Paul)" <PaulBr@...>
was
> --PBr  :)
> Free Long Distance, Free CD, Free Headset!
> http://click.egroups.com/1/1993/2/_/529958/_/951792158/
