650 OS Update?
2008-12-01 by James Elliott
Paul, is there any news on the 650 OS update to resolve outstanding issues?
Jim
To: motm@yahoogroups.com
Sent: Wednesday, June 18, 2008 12:56:03 AM
Subject: Re: [motm] 650 OS Update Status....
Here's the details of a bug that I turned in last year which causes my 650 to "crash".
Hopefully this gets addressed in the next update as it is frustrating to no end.
-Jim
Paul, you've asked the list to send you any errors / descriptions of funky behavior that we encounter. I've already sent you a general description of these problems on 10/13, and I will go into more detail here.
General Problem: My 650 quits responding to midi when I send midi cc's to control aux1. When I say quit responding I mean that the output jacks do not transmit a signal - the midi LED still responds to midi. One of two things happens once the 650 is in this state.
1) If I perform the following actions, then the 650 begins to respond to midi again (however it will lock up again if I send midi cc's to aux1)
-Press "ESC"
-Scroll to, and then select, "Module Actions"
-Scroll to, and then select, "Load Patch"
-and finally, load a patch
2) If I don't follow the steps above, I get various assert errors depending on different buttons that I press
-L612: I get this error when I press "Enter" after a lockup
-L2039: When I press "Inc" after a lockup
-L2167: When I press "dec" after a lockup
-L548: First I press "ESC", which allows me to scroll through the top level menu, then press "Enter" on any of the second level menu items
My 650 is setup as follows:
-Global options:
1) Voice Type - 1/1/1/1
2) CtrlMidi Chan - 1
3) Trig PWM - 10ms
4) VelScale - 8 Volts
5) Backlight - Auto
6) TunTable - 12 Tone
7) Note Inv - Off
8) Priority - LastNote
9) Clock - Internal
10) IClk BPM - 120.0
11) Midi Clk - Transmit
12) Patch Rx - Disabled (I also tried enabled, whatever that does?)
13) SysexSys ID=Global
-VoiceGroup 1 Settings:
1) VG1 Midi Chan - 1
2) VG1 Allc - Solo
3) VG1Glide - Off
4) VG1PBend - 24
5) VG1GType - Normal
6) VG1 V/T - Velocity
7) VG1 Aux - CC12 (Tried others as well with the same issue resulting)
8) VG1AuxSc - 8 Volts
-VoiceGroups 2 - 4 are set up exactly like group 1 except that the PBends are set to 0, and the Aux Midi CC's are set to different values (13, 14, 15).
-Both Arps are turned off.
**This also happens in other other voice modes as well 4/poly1, 4/poly2, 2/2/poly1, etc.......
I really hope this gets fixed in the next patch release because having one of the 4 aux outs messed up sucks. Other than this problem, the 650 is a pretty cool module.
-Jim
-Jim
-Press "ESC"
-Global options:
3) Trig PWM - 10ms
5) Backlight - Auto
7) Note Inv - Off
9) Clock - Internal
2) VG1 Allc - Solo
3) VG1Glide - Off
4) VG1PBend - 24
-Jim
----- Original Message ----
To: motm@yahoogroups.com; James Elliott <johans121@...>
Sent: Wednesday, June 18, 2008 12:20:53 AM
Hopefully Jeffrey will step in and give us an update. I have not heard from
him in a while.
Meanwhile: the majority of the issues are using external clock to drive the
arpeggiators and using Voice Group 1/1/1/1 (4 independent MIDI channels).
The Voice Group
bug seems to be if you change from/into 1/1/1/1 mode. I think if you *start*
there (the default patch) you are OK.
I have not heard of any other bugs/crashes except in these 2 cases. If
anyone has other bug to report, please do so.
----- Forwarded Message ----
Sent: Saturday, October 13, 2007 12:13:47 AM
Subject: [motm] 650 Aux 1 Bug?
I am encountering a very frustrating issue with my new 650.
It seems as if I control aux 1 with a midi cc (as anyone would) my 650 becomes unresponsive to midi until I reload a patch. If I press enter on global options while in this state, I get an "Assert LXXXX" error message (they have been different each time, depending on what buttons I hit after this happens - the one I am starring at right now is L2028). When I get the error message, I have to power off my 650 completely to get it to work again. can't quite figure out what is causing this to happen. The only thing I am doing is sending cc information to control aux 1.
This does not happen with aux2, 3, or 4.
I am in 1/1/1/1 mode with all voices receiving on channel 1.
Help!
Any ideas!!??!!
-Jim
Help!
Any ideas!!??!!
-Jim
