Interest in a MOTM-102 module?
2005-12-29 by Paul Schreiber
Thinking of a 1U wide, new noise/S&H module.
Bad news: not a full kit, the pcb would be pre-soldered (teeny SMT parts). Still
have to wire it up, though :)
Good news: check these features!
a) White/Pink out, digitally generated (Pink is analog filtered).
b) the S&H is a cascaded, 4-channel "shift register" type with *infinite* hold
time/zero droop (it's 12-bit digitized). There is a switch to either be 'Normal'
(each int/ext clock samples the Input and passes it to the 4 outputs at once) or
'Shift' (each clock shifts the previous stage down to the next stage, and In
always goes to Out #1).
Like I said, not a full kit but a nifty module. And same price as current '101
kit.
Discuss.
Re: [motm] Interest in a MOTM-102 module?
2005-12-29 by Richard Brewster
Yay!  I'll take two.  Now to discuss...
Digital noise and digital sampling is perfect.  Great idea.
Not sure of the value of a normal/shift switch.  Why would we want 4
identical outputs (normal mode)?
I find that a clock polarity switch is very useful to choose whether the
new sample is acquired on the rising or falling clock.  Center-off and
you have infinite hold, which is perfect with this digital design.
The internal clock in the MOTM-101 is limited by a small range (it
doesn't go very slowly), a lack of voltage control, and it is not
available as an output (important for synchronizing other events to the
new sample).  For these reasons I tend to use a MOTM-390 LFO to clock
the 101.  I would like the internal clock to have some of these
features, especially a larger range and an output jack.  VC would be cool.
This may be asking for a lot, but could it have a scale quantizer?  It
is digital to begin with.  How much extra would adding a major/minor
scale be?  How about a 3-position toggle switch:  major/minor/off.
Output correlation.  A nice feature of the Oakley S&H is the output
"restriction".   It's a classic sample and hold feature that's done by
mixing some of the output back with the input being sampled.  The more
of the ouput mixed in, the closer the next sample will be to the current
value.  With noise input this makes for nice meandering sequences
without sharp jumps.
Panel thoughts.
2 Pots:  Input Level *or* Correlation, Clock Rate
2 Switches:  Quantizing, Clock Polarity
10 Jacks:  Input, Ext Clock Input, Int Clock VC input, Int Clock Output,
Out 1, Out 2, Out 3, Out 4, White out, Pink out
Too many jacks!  Eight is all that will fit.  Let's lose the Int Clock
VC input and the White out.  (Maybe provide a jumper option for the
noise output to be white or pink.)
Ok, discuss!
-Richard Brewster
>kit.
>Discuss.
>Paul S.
Maybe Richard's ideas into *just* a S&H module? (no noise generation). then you
can fit 2 pots and 8 jacks for the S&H features.
2005-12-29 by Paul Haneberg
Why not make it 2U and include everything?
I'm up for 2.
Paul H.
To: "Richard Brewster" <pugix@...>
Cc: "MOTM litserv" <motm@yahoogroups.com>
Sent: Thursday, December 29, 2005 10:20 AM
Subject: Re: [motm] Interest in a MOTM-102 module?
> then you
> Paul S.
2005-12-29 by jwbarlow@aol.com
I like S/H units and think every modular should have several.
I can see the need for more than one *type* of noise in a modular (ie,
white, pink, brown, very slow random), but I can't see the need in any modular  for
more than one noise source.
(Am I wrong about this?)
So you shouldn't have to waste panel space and money for additional noise
sources when you really want S/H modules.
Maybe an idea would be to make the 102 a much better (higher quality more
diverse) dual S/H module but keep the 101 in stock for a while. That would
encourage everyone to buy a 101 first, followed by several 102s.
JB
In a message dated 12/29/2005 7:21:54 A.M. Pacific Standard Time,
synth1@... writes:
you
Re: Interest in a MOTM-102 module?
2005-12-29 by mate_stubb
I'd like to see an ASR type module combined with a "SOU" type module
in 2U. If I had to choose between ASR (or DSR I guess), LFO control
feature, and SOU features, the two I would pick would be ASR and SOU.
(SOU = Source of Uncertainty, fancy name for random outputs with more
or less correlation, often clocked.
Moe
> I'm up for 2.
> Paul H.
RE: [motm] Interest in a MOTM-102 module?
2005-12-29 by Adam Schabtach
> then you
That's what I'd vote for. I already have a CGS Digital Noise generator and a
MOTM 101. That seems to be enough noise for me.
--Adam
> hold
Is that adequate for digitizing pitch-control voltages?
--Adam
2005-12-29 by Greg Amann
I agree with Richard's suggestion and Paul's.  I have noise, I need
more S/H!  Would buy 2 S/H immediately.  And an envelope follower.
PLL, BFG
> Paul S.
You could really do all that!?  Wow.  I don't need more noise sources.
-Richard Brewster
>Paul S.
I use a Wiard/Blacet Miniwave for quantizing.  It is 8-bit but it works
fine for 12-note chromatic scales.  That's all we're talking about here
with the quantizer choices limited to major/minor.  You would need more
bits for microtonal scales I suppose.  If you're talking about
non-quantized outputs, it doesn't matter unless your input is already
quantized, which would not be the usual case.
-Richard Brewster
>>hold
>--Adam
2005-12-29 by Mike Marsh
Yes, please absolutely!  This would be killer, just what I was
thinking about with some cool additions...
Yeah!
parts). Still
*infinite* hold
be 'Normal'
at once) or
stage, and In
current '101
> kit.
> Discuss.
> Paul S.
2005-12-29 by Scott Juskiw
I'm very interested in a sophisticated MOTM-quality S&H. I like
Richard's suggestions, particularly the clock edge selector (I'm
always having to invert a clock into the 101 because it samples on
the falling edge). I don't need more noise sources, but I can
definately use more S&H. 1U preferred. Infinite hold? FABULOUS! This
has a very high drool factor (slurp).
>at once) or
I agree with Richard in that having the same output on all 4 outputs
at once would not be all that useful (in NORMAL mode), since we can
do that with a multiple. Would it be possible to get 4 different
outputs at once on each clock (in NORMAL mode)?
2005-12-30 by groovyshaman
Yes S&H only please.
This is MOTM -> 6 stages with ASR design.
ASR Mode switch:
    position 1 = 1->3->5 and 2->4->6, position 2 = 1->2->3->4->5->6
VC Ring switch:
    logic 1 connects 6->1 (or 5->1 and 6->2) and disconnects inputs, logic 0
is normal
Randomizer pot.
VC LFO rate.
VC output correlation.
Clock polarity switch.
Support clocking at audio rates! :)
I would buy two.
George
then you
> Paul S.
2005-12-30 by Adam Schabtach
I use microtonal scales, so yes, my input would be pre-quantized. It would
be fun to feed it pitch voltages so you could clock them through to create
canon-like effects.
--Adam
(one of those non-equal-tempered weirdos. Blame Robert Rich--he corrupted
me.)
> -Richard Brewster
> *infinite*
> >>hold
> >--Adam
2005-12-30 by Jason Proctor
i can see the need for multiple S&Hs within a system, but not
multiple noise generators. my vote would be for an extensive S&H in
1U.
>ASR Mode switch:
>VC Ring switch:
>is normal
>Randomizer pot.
>VC LFO rate.
>I would buy two.
>George
2005-12-30 by John Loffink
With a little more intelligence this could be turned into an arpeggiator.
Have a switch for Sample On/Off, when On the module has the normal S&H/ASR
type function, when off it recirculates what is in the queue.
John Loffink
> -----Original Message-----
> From: motm@yahoogroups.com [mailto:motm@...m] On Behalf Of Adam
> Schabtach
> Sent: Thursday, December 29, 2005 10:53 PM
> To: 'MOTM litserv'
> Subject: RE: [motm] Interest in a MOTM-102 module?
> canon-like effects.
> --Adam
> me.)
Yes! And make the switch voltage controlled.  Very cool.  This is what I was
hinting at with my VC Ring switch suggestion.  One could accomplish this
with a 700 switch and a 910 mult but it would be nice to have this feature
integrated.
-George
To: "'Adam Schabtach'" <adam@...>; "'MOTM litserv'"
Sent: Friday, December 30, 2005 9:40 AM
> John Loffink
2005-12-30 by mate_stubb
Multiple noise sources in a system can be useful. For one thing, two
noise sources feeding different audio chains sound different than one
feeding both.
They are also useful as sources of randomness - if you need multiple
random sources at the same time, you need different seeds - without a
second noise source, I end up having to tie up a couple of high speed
cross modulating oscillators.
FWIW.
Moe
> 1U.
Re: [motm] Re: Interest in a MOTM-102 module?
2005-12-30 by ac
> feeding both.
Interesting. I don't understand why. Care to explain Moe?
I realise that theoritically they are different, but why would they
sound different?
Could we really descern, audibly or otherwise, any difference?
I'm struggling to think of a patch or situation where 2 distinct noise
sources would be required?
But unless you sample a noise source at exactly the same billisecond
the chances of getting the same result are pretty slim, surely? (yeh,
i know, stop calling you Shirley)
Would not a single noise source to multiple S&H sound the same as
multiple noise sources into multiple S&H? The very analogness of a S&H
means they are highly unlikely
to sample the same point in time as a parallel S&H on the same source
- although I haven't actually tested this, i'm just assuming....
Cheers,
ac
2005-12-30 by jwbarlow@aol.com
In a message dated 12/30/2005 11:13:58 A.M. Pacific Standard Time,
analoghell@... writes:
>  feeding both.
I agree (as I stated in my post yesterday). I don't understand why  different
noise sources would be better than a single noise source. Unless, by  your
statement, "at the same time" you mean at the same *instant* and are  sampling
the noise with the same clock. (in that way sampling different noise  sources
with the same clock should always give you non-correlated results)
Also, (given that I don't know anything about electronics) doesn't your  term
"seed" imply a digital (pseudo-random) noise source and not an analog noise
source (which I guess is also pseudo-random though in a different way).
Am I wrong?
JB
> sound different?
Noise is just a weighted probability distribution of voltage over
time. Two different sources will have the same distribution over a
period of time, but not the same at any given moment of time. So, they
mix differently and more powerfully than just adding a single signal
with itself - turning up the volume so to speak.
Polyphonic patches, for one.
Yes. But when that's exactly what I want to do (obtain multiple random
values on the same clock edge, nothing else will do. Multiple S&H
modules sampling the same noise source will give me all the same
values, or values very close to each other given component variations.
I have white/pink noise in my MOTM 100, digital clocked noise in my
Dark Star, and shift register clocked noise/white noise in my Noise
Ring. I find them all to be useful, and use them quite often in the
same patch.
Your mileage and needs may vary, of course.
Moe
2005-12-30 by ac
Very interesting!!
So if I feed two S&H from a single noise source and clock them from
the same gate/LFO (or whatever) i'll more-than-likely get the same
held CV value?
I didn't think that analog was *that* accurate! I'll be trying this
out first chance i get.
In which case, i *can* see why you'd need more than one noise source
of the same type.
In my more arrogant moments I sometimes fool myself into thinking I
have this whole analog thing "licked" (as you Americans like to say),
so it's always nice to learn something new like this. Thanks!
ac
> > sound different?
> same patch.
> Moe
2005-12-30 by Mike Marsh
What Moe said but add an Improbability Drive. I have enough noise
sources, too, so the S&H functionality only would get my vote.  But
only because I have all those other noise sources.  If I didn't, I
would vote differently.
Mike
> > sound different?
> same patch.
> Moe
2005-12-31 by Oakley Sound
Also Stereo patches. Try it for extra wide wind/surf effects and a
wicked snare drum.
Tony
www.oakleysound.com
2005-12-31 by Koos Fockens
Whatever you come up with Paul, a 1 unit module would have my preference, I have limited
space but would like to put as much high quality modules in that space that I can.
Although I must say, that if you need to drop features to gain quality and keeping the price
reasonable, then by all means do so. That would suit me best.
A redesigned 101 in a 1 unit space perhaps? :-)
Koos
Happy New Year everyone!
2006-01-02 by jfm3
I've been thinking a lot about how to do pitch CV quantizing.  Being as
it is the case that I'm new to the analog modular, and far more trained
in software engineering than hardware, I probably have some of this
wrong, so I ask that you forgive me for that, and take what I say
without much authority.
For my purposes, pre-programmed scales would be useless.  The long
duration accuracy being discussed deeper in this thread turns me off
too.  What I've decided I really want is a VC sequencer that steps
through it's stages not once every time a square CV drops, but smoothly
as a saw shaped CV goes from zero all the way up.  A triangle CV would
make the sequencer go back and forth, etc..  With one of these, you
could quantize pitch CVs into whatever other arbitrary set of pitch CVs
you wanted.
I think the Milton sequencer can do this.  I'm not sure how stable a
Milton can hold it's output CV over time.  It also seems like the CV out
of the Milton is digital, and it's not clear to me what resolution that
has.  I have some Milton boards and preprogrammed PICs, but getting
front panels and stuffing the boards properly is a little daunting given
that I don't really completely know what I'm doing.
What's the output CV resolution on the Miniwave, and can you still get
them?
(jfm3)
2006-01-02 by Paul Haneberg
A lot of this discussion seems to center on the idea of using a VCO
generated sawtooth wave, putting it into an A to D converter and using the
output essentially as a counter.  The accuracy of this particular scheme is
highly dependent on the sawtooth ramp being a perfectly straight line.  Any
curvature in the ramp would cause the counter to count faster at some times
and slower at others as the slope varies.
A better way would be to start with the triangle wave, run it through a
series of rectifiers followed by capacitors to eliminate the DC component.
This would get you a frequency multiplied triangle wave.  If you then
generate a pulse from the frequency multiplied triangle you can drive a
counter directly.  The result should be more linear than the sawtooth
driving the A to D and you don't need a converter.
I would think you could run at least 8 rectifier/capacitor units in series.
That would get you a 256x pulse.  You'd probably want to use high speed ops.
I'd like to see a frequency multiplied module using this idea.  You could
probably get some strange outputs by running complex waveforms in the input
in place of a triangle.
Paul H.
To: "MOTM litserv" <motm@yahoogroups.com>
Sent: Monday, January 02, 2006 12:31 AM
> you wanted.
> them?
> (jfm3)
2006-01-02 by ach_gott@yahoo.com
Well, what you're looking for and what is being discussed here are two totally separate things.  This is a shift register and you want a sequencer.
The Milton does what you're looking for.  I'm not sure what you mean by your milton vc out question... Its a voltage divider circuit, not a s&h.  I also don't understand what you mean by the output being digital.  Either way, these are inquiries best put to the Milton discussion group.
The miniwave is still available at blacet.com.  Having said that, a synth tech quantizer module that accepts multiple inputs and outputs would be a dreamy addition to the 600 series (and would probably reuse the midi cvter software in part).
Cheers,
Eric f
Sent from my BlackBerry wireless handheld.
Date: Mon, 02 Jan 2006 00:31:12
To:MOTM litserv <motm@yahoogroups.com>
 you wanted.
 them?
 (jfm3)
 SPONSORED LINKS
 Label: <http://groups.yahoo.com/gads?t=ms&k=Label&w1=Label&w2=Cd+music+label&w3=Independent+music+label&c=3&s=60&.sig=6Ue5iYG1cB-4-PxKoePVpw> Cd music label: <http://groups.yahoo.com/gads?t=ms&k=Cd+music+label&w1=Label&w2=Cd+music+label&w3=Independent+music+label&c=3&s=60&.sig=HcQO9bFYletC1PmCSbcMNA> Independent music label: <http://groups.yahoo.com/gads?t=ms&k=Independent+music+label&w1=Label&w2=Cd+music+label&w3=Independent+music+label&c=3&s=60&.sig=4zI39fYigTJ8RURahZcwuw>
 YAHOO! GROUPS LINKS
*  Visit your group "motm: <http://groups.yahoo.com/group/motm> " on the web.
*  To unsubscribe from this group, send an email to:
 motm-unsubscribe@yahoogroups.com: <mailto:motm-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service: <http://docs.yahoo.com/info/terms/> .
No, I'm not looking for a sequencer.
I have several, BTW.  I also have two Miniwaves.
What I'm talking about is a method of driving a counter from a VCO with
better accuracy than using the method which is used in the MiniWave, which
is deriving a count from a VCO sawtooth driving an A to D.
I also think a frequency multiplier could be musically useful in its own
right, especially when used with a divider module.
A frequency multiplier could also provide the clocking for any number of
digital based modules such as a Fourier series generator, a Walsh function
generator, or a cloud generator.
I'm not sure if this would be more accurate than driving a digital based
module with a DCO, but frequency transitions would be smooth, not stepped.
To: "jfm3" <jfm3@...>; <motm@yahoogroups.com>
Sent: Monday, January 02, 2006 12:58 AM
> sequencer.
> software in part).
> Cheers,
> Eric f
> From: jfm3 <jfm3@...>
> you wanted.
> them?
> (jfm3)
> SPONSORED LINKS
> Label:
> Cd music label:
> YAHOO! GROUPS LINKS
> web.
2006-01-02 by mate_stubb
> out of the Milton is digital, and it's not clear to me what
> resolution that has.
This is incorrect. A true analog sequencer such as the Milton, has
100% analog signal path, and its output is in fact an analog voltage
with infinite resolution, or at least the resolution of the windings
on the pot.
All you are doing with an analog step sequencer is using a bunch of
digital logic to connect a series of pots acting as voltage dividers
to the output. It can hold that voltage indefinitely - there are no
droop problems.
> get them?
A Miniwave is an 8 bit ROM addressable via voltage control. There are
16 banks of 16 wavetables, and each wavetable is I think 256 bytes
long. You choose which of the 256 memory locations in a table is
connected to the output via a DAC by the input control voltage.
So this device has an 8 bit output resolution, and also has no droop
problems. Scanning the tables via various waveforms (saw, tri, reverse
saw) allows you to control the direction of playback as you mentioned.
Hope this helps clear things up!
Moe
http://www.hotrodmotm.com
http://www.wisegusynth.com
2006-01-02 by Oakley Sound
Whilst this is true, the linearity of the charge/discharge is actually
pretty linear. The biggest problem is normally maximum peak level, this
is normally deliberately reduced as the VCO frequency gets higher to
compensate for discharge timing. Failure to arrive at the correct peak
level means certain output codes missing.
Any oddities at the peak caused by the discharge circuit can be
problematic for the ADC too. The Oakley VCO would spike to +10V
momentarily and this would may cause some problem to any level detecting
circuit.
One method, used by Grant Richter, is to incorporate the ADC in the VCO
core itself. Thus discharge is controlled by the ADC and not a
comparator. Another method of high frequency compensation would need to
be used of course, but this can be done in the expo and/or CV summer.
This method is actually harder to do. Whilst the number of pulses
derived per cycle of the input frequency is correct, the spacing between
the pulses is entirely dependant on the accuracy of the full wave
rectifiers. The FWR circuits will become less accurate as the frequency
of operation increases.
Both active methods, that is; FET switches or diodes in feedback loops
do have problems with the speed at which they operate. ie. the time it
takes for them to conduct in each direction is limited by the switch
speed or slew rate of the op-amp. Odd things happen to the output at the
point of phase reversal.
Also, noise is a problem, since each folding of the wave requires a gain
change of 6dB to bring it back up to the same level as the input, or a
resultant increase in sensitivity of the final pulse generator. Noise
from the switching of the diodes or FET switches may then be amplified
sufficiently to produce erroneous glitches in the ADC output.
I looked at both systems when I was making my WalshBank digital VCO and
revisited them when designing the 'two up two down' module. This former
relies on a high frequency clock which is them decoded down by binary
counters. In the end I settled for a very fast triangle based VCO. This
would operate at 32 times the normal frequencies of a musical VCO.
However, I never really got much further than breadboarding this one.
Another thought is a tracking sync slave VCO. Slaved to the master CV,
it would operate at 32 times to a master VCO. A hard sync connection
would then keep it effectively locked in.
Tony
www.oakleysound.com
2006-01-02 by jfm3
I've generated some confusion and remain confused myself, so I'll try to
undo that...
Paul H. replied to ach_gott@...:
Paul H, I don't think he was talking to you, he was correcting me.  I
think the point at which I became confused (and remain confused) is when
> It
Really, all I wanted to add to the conversation was that I thought
major/minor/off was too limiting.  I probably wouldn't use it, at
least.
What follows is more of what I've figured out so far, you should only
read it if you're feeling charitable :)
I think that a "scale quantizer" here is: 1) CV meant to represent a
pitch comes in, then 2) nearest allowable pitch CV comes out, where
allowable pitches are selected from a ROM table, or something.  I'm not
even sure what this has to do with a S&H, other than perhaps that the
circuitry for the S&H may be easily extended to provide this "scale
quantizer" functionality (perhaps because there is a digital section
which can be programmed more or less arbitrarily?).
I do want some way to take a CV meant to represent a pitch and feed it
to a machine which produces one of N CVs, each decided upon by a knob.
It turns out this is what I'm terming a "VC sequencer" -- my jargon may
be off.  At this point I'll resort to cheap math to display my ignorance
of electronics :)  Imagine the incoming CV as a real value in [0 1].
Normally, this is interpreted by a VCO as a pitch.  A four step "VC
sequencer" would act like a function:
f(x) = a if x < .25
       b if x >= .25 and x < .50
       c if x >= .50 and x < .75
       d if x >= .75
a, b, c, and d, are controllable with knobs.  Now if the real values of
a, b, c, and d, were the notes in a maj7 chord, we'd have something like
a "scale quantizer".  If instead x is a value that changes over time,
such as a saw tooth wave which rises from 0 to 1 every 4 seconds, then
we have a sequencer.  Of course an ideal sequencer would have more
possible values, and other features, I'm just trying to get the model in
my head correctly.
It seems like the miniwave is like the function above except there are
256 possible function values (a, b, c, d, e, f, ...), that these values
are relatively low resolution, preset in a ROM, and not as accurate
("droopy") as some would like for the purposes of CVs that represent
pitches.
How am I doing?
If I've got it right so far, then I'd say having a scale quantizer in my
S&H module was ... strange.
> > get them?
This very much helps to clear things up. Thank you very much!
(jfm3)
I think the point of the scale quantizer is the ability to confine the
output voltages of a Sample Hold to specific voltages deemed to be musically
useful, such as a major or minor scale.
I think a chromatic scale makes some sense as the intervals are equal.  You
would be quantizing to the nearest 1/12 volt.  Major or minor scales are
more problematic as the intervals are not equal.  If the inputs to the scale
quantizer are truly random and the interals of the quantizer are not equal
some note would play more than others since the probability of the random
voltage input falling into a samller interval is less than falling into a
greater one.
Some feel that to be musical, sounds have to be confined to equally tempered
or other scales.  Others feel that this is confining.  I personally think
both approaches are musically useful and valid.
I would rather see a quantizer as a seperate module.
Also responding to Tony at Oakley ---
I had not thought about the lack of precision in the rectifiers affecting
the timing between pulses, thanks for pointing that out.
You are certainly correct about the noise level increasing with each stage.
I have played around with this on a breadboard and gone 32x without too much
difficulty, but had not considered what amounts to clock jitter.  Obviously
to maintain high factors of multiplication at increasing frequencies you
would need op amps with high bandwidth product.
Paul H.
To: "mate_stubb" <mate_stubb@...>
Cc: <motm@yahoogroups.com>
Sent: Monday, January 02, 2006 1:28 PM
Subject: Re: [motm] Re: Interest in a MOTM-102 module?
> undo that...
>> It
> least.
> f(x) = a if x < .25
>       d if x >= .75
> my head correctly.
> pitches.
> How am I doing?
>> > get them?
> (jfm3)
2006-01-02 by Scott Juskiw
Ditto. If the 102 has a chromatic scale quantizer built in, fine. I
may not use it. Once you start talking about quantizers you get into
the whole realm of different scales, modes, and intonation. Soon
we're getting into microtuning. (I'll step aside and let John L. take
over on this topic).
If there's going to be an MOTM quantizer, it should be a "no
compromise" quantizer, and not some single switch add-on to a S&H,
IMHO.
Doesn't the 650 support different intonations and micro-tuning? Would
this cover the needs of a quantizer (from the MIDI keyboard/sequencer
viewpoint)? I suppose there's still a need to quantize control
voltages.
2006-01-02 by Richard Brewster
Another ditto.  I am now convinced that a quantizer function is too rich
with possibilities to warrant inclusion in this simple S&H module.  Yes,
it was I who brought it up.  I was brainstorming.  This collaborative
design is great.  The best ideas stick and the more off-the-wall  ideas
shake out and maybe lead to other module design ideas.  A consensus is
converging that a MOTM-102 should not include noise or quantizing.  If
you take those out, we're left with the remaining good ideas and it is
simple enough to fit in 1U.  Agree?  Or do you still want noise or
quantizing in this little module?
-Richard Brewster
http://www.pugix.com
>IMHO.
>voltages.
Would like to have...
I like the output correlation. I like the positive/negative edge
trigger switch. I like the infinite hold. I like the shifting (ASR),
especially if it can cascade from one 102 to another 102. I would
also like to have all outputs be able to sample/hold a unique value
when not in ASR mode.
Would not object to having...
Additional white/pink/random outputs, but not at the expense of the
S&H capabilities.
Don't need...
Quantizing. A440 reference tone (just kidding).
Whither the MOTM-102 module
2006-07-09 by Scott Juskiw
Question for Paul S. posted to the group because I believe other
people will want to know this too.
Last December/January there was a lot of talk about a new digital S&H
module. Whatever became of this in light of the new AudioEngine
grande scheme? Is the 102 still on the "todo" list? It wasn't listed
in your "Status of discussed future modules list" message from July
3, 2006.
Replacement for MOTM-450
I was initially disappointed that the MOTM-450 Fixed Filter Bank was
shelved, but am now thinking maybe this is a good thing. The
disadvantage of the 450 is the "fixed" filters. More useful would be
a programmable parametric EQ with a variable number of bands where
each band's Fc, Q, and gain can be set, stored, and recalled. This
would be much more useful than a fixed filter bank for synthesizing
vocal formants and resonant cavities. Voltage control might be
difficult due to the large number of parameters involved (modulating
frequency, resonance, and gain for each band would require a whole
lotta jacks, but perhaps these could be controlled via MIDI CCs
instead).
Is this something that can be done with the new AudioEngine core? Or
would we be better off with some off the shelf EQ from some other
company?
[motm] Whither ANALOG? (was: Replacement for MOTM-450)
2006-07-09 by Scott K Warren
Ok, ScottJ's idea is a great one, and sure, I appreciate the
possibilities
of the AudioEngine about as well as anybody -- I'm a (digital) computer
scientist after all, three decades now. But the buzz on this list is
starting
to scare me.
I hope that Paul S doesn't abandon the great world of Analog Audio
entirely. That's why I got into this hobby and what I love about it.
Yes,
actually, I think here in the 21st century the most practical way to get
any desired audio result is by computing it digitally. But to me, that
just
is Not As Much Fun.
Paul, say it ain't so!
skw
>  instead).
>  company?
RE: [motm] Replacement for MOTM-450
2006-07-09 by John Loffink
Try the Moogerfooger MURF.  It is essentially an animated Filter Bank.
Sound quality and useability is superb.
As for a programmable parametric equalizer, here's a concept from about 26
years ago:  http://www.wavemakers-synth.com/328rpg1.html :-)
You can do anything with the AudioEngine core, but it won't be analog.  I'd
propose that its greatest value is in modules that are difficult to do with
analog:  Granular synthesis, low noise vocoder with 30+ bands, long
echos/delays/tape loops, etc.
John Loffink
> From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of
> Scott Juskiw
> Sent: Sunday, July 09, 2006 12:04 PM
> To: motm@yahoogroups.com
> Subject: [motm] Replacement for MOTM-450
> instead).
> company?
I was looking back at some of Kenneth Elhardt's patches and notes
where he uses 15 and 31 band equalizers to synthesize resonant
cavities. I figured an AudioEngine version of that would be much
smaller than it's analogue equivalent.
Thanks for reminding me about the MURF, I had forgotten about that
one. And thanks for the wavemakers link, that one's new to me.
Re: [motm] Replacement for MOTM-450
2006-07-09 by Jay
Oakley made a FFB too. Let's hope that's part of the new PCB run.
Re: [motm] Whither ANALOG? (was: Replacement for MOTM-450)
2006-07-09 by synth1@airmail.net
I will continue to use analog where it makes sense, and the AudioEngine
likewise.
Please don't get the impression I am "abandoning" analog design. I'm just
*adding* digital stuff. Few folks have complained about the digital
MOTM-650 :)
Filters will always sound better in analog.
Re: Whither the MOTM-102 module
2006-07-10 by Mike Marsh
I have been vocal in the past about a S&H module with cascading S&H's
and trigger delays, etc.  THis could be easily (I think) accomplished
with the Audio Engine and would make for some fun and varied CV
goodness.  COunt me in on at least one of these.
Mike
> 3, 2006.
2006-07-10 by David Cornutt
True, although sometimes digital makes possible response curves
that are difficult or expensive to do in analog.  For instance, how
about
a clone of the Xpander filter with voltage-controlled curve selection?
2006-07-10 by Craig Critchley
Actually, I like the idea of an analog parametric EQ module... I don't have
a mixer with a really good EQ on it but a couple channels of decent EQ could
come in handy, especially if there's no filter bank.
					...Craig
> Behalf Of Scott Juskiw
> Sent: Sunday, July 09, 2006 12:58 PM
> Subject: RE: [motm] Replacement for MOTM-450
> notes where he uses 15 and 31 band equalizers to synthesize
> resonant cavities. I figured an AudioEngine version of that
> would be much smaller than it's analogue equivalent.
> that one. And thanks for the wavemakers link, that one's new to me.
> Filter Bank.
> from about
> >26 years ago:  http://www.wavemakers-synth.com/328rpg1.html :-)
> be analog.
> >I'd propose that its greatest value is in modules that are
> difficult to
> >do with
2006-07-10 by Kenneth Elhardt
Scott Juskiw writes:
shelved, but am now thinking maybe this is a good thing....<<
Now is the time when I must yet again remind those involved in this thread
that everything you ever wanted already exists as long as you don't need it
to look like an motm module.  Analog Systems and Doepfer have all kinds of
stuff, from the AS Vocal Phase filter to the Trautonium filters.  Cynthia's
bandpass filters modules looks useful if you don't need VC.  Cwejman now has
a fully voltage controlled analog parametric EQ.  The EAR group that Peter
Grenader is involved in also has something similar.  Regular old graphic and
parametric EQs can be turned into filter banks with the invert one channel
and mix method.  And then if you really want to go wild, pick up a used Nord
Micro Modular dirt cheap, and you can patch up and create variable filter
banks and EQs with all parameters controllable from midi and with analog I/O
to patch into you motm.  There's your AudioEngine right there.
>>I was looking back at some of Kenneth Elhardt's patches and notes where he
uses 15 and 31 band equalizers to synthesize resonant cavities.<<
I usually use EQ within a patch, but I use lowpass and bandpass filters, and
parametric EQ to get resonant cavity type stuff since those allow strong
resonances to be set.  Even the motm 410 gets used at times in there.
David Cornutt writes:
>>True, although sometimes digital makes possible response curves that are
difficult or expensive to do in analog.<<
Or IMPOSSIBLE to do in analog.
The 450 fixed filter being shelved seems more to do with Paul S. adhering so
stubornly to those expensive pots and knobs and whatever else, to the point
where anything that uses more than just a few of them becomes so impractical
in terms of price that nobody wants to buy it anymore.  The original
estimated 450 kit price was $190, then it went to $260, then to $380, then
to over $400.  That's why there aren't many potential customers for it.
Maybe for something like the 450 it's time to drop the seeled pots and other
overpriced stuff (I still remember the thread about suppliers screwing MOTM
on part prices, which gets passed on to us) and do it in a practical way.
If you buy a 15 band Doepfer fixed filter bank for $160 assembled, but an
MOTM 8/10 filter bank would cost over $400 in kit form, something is wrong.
-Elhardt
Since Yahoo is losing my posts into some black hole, let me post this again.
-Elhardt
2006-07-10 by Matthew Hiscock
Perhaps something along the lines of the Cwejman module, but in MOTM format?
...but damn, $515 is a lot of coin....
I'd love a two-band version, if that would keep costs down. Then those who outgrow two could buy another for four bands.
instead).
company?
www.bodega-audio.com
www.myspace.com/bodegaaudio
www.distillerymastering.com
Bodega./Bootleg Sounds. Fat East Coast. Distillery Mastering.
2006-07-11 by Scott Juskiw
><http://www.bigcitymusic.com/product.asp?cat=new&pid=1000560>http://www.bigcitymusic.com/product.asp?cat=new&pid=1000560
Yeah, something like that, but with 15 or 31 bands, and less than
$400. I doubt you could do that in analogue, which is why I was
thinking this would be a good project for the AudioEngine.
2006-07-11 by Paul Schreiber
Re: [motm] Replacement for MOTM-450Yeah, something like that, but with 15 or 31
bands, and less than $400. I doubt you could do that in analogue, which is why I
was thinking this would be a good project for the AudioEngine.
That would require a lot of DSP power. There is no DSP in the AudioEngine per
se, although you can implement cetain DSP "structures" inside the Xilinx. But
one MOTM user also happens to be a Xilinx DSP guru :)
2006-07-12 by Mike Estee
That stuborness is one of the reasons I'm a motm customer. It's the
commitment to signal path quality. Sure, I could get the doepfer modules,
but sometimes I don't like hearing my clock line/powersupply/evening news
in my signal path.
I'd rather paul ditched a module than his principles, they're what I spend
the bucks for, if they weren't I'd still have a doepfer.
For all your low cost knob needs there's dotCom, they make a fine fixed
filter bank:
   http://synthesizers.com/q127.html
--mikest
Re: Replacement for MOTM-450
2006-07-13 by coyoteous
- what he said! I'd like to see a single space/single band MOTM parametric EQ - simulated
inductor/FDNR, etc. - SMT/assembled and not too expensive? :-) Like the L and H bands
on the Speck ASC:
http://www.speck.com/asc/asc_2.shtml
Barry S.
> in my signal path.
> filter bank: http://synthesizers.com/q127.html
> --mikest
2006-07-14 by Kenneth Elhardt
Mike Estee writes:
in my signal path. I'd rather paul ditched a module than his principles.<<
It's not the electronics part that I'm talking about.  As Paul said, that's
only about %25 of the cost.  It's expensive knobs and pots, or whatever is
pushing the thing to the point where people don't want to spend the money.
Tony from Encore Electronics for instance, puts 15 pots and knobs on the UEG
using a completely different system, and it seems like maybe a better way to
go for higher knobcount type stuff.  And a lot faster to build to boot.
Won't need to go 3U wide either even at 15 or more bands, which is what I
think the 450 should have been to begin with. (If the 450 was going to be
3U, can't remember).  Paul has already ditched some of his principles by
going fracrack, so let's maybe continue that trend a bit further. :-)
-Elhardt
2006-07-14 by John Laudicina
This is all MOOT,
Paul can do what ever he wants to do, it is his idea
and business.  I for one am on a budget for my modular
needs, this is why I went kits.  Even at kit prices
the dot com stuff is much cheaper... but so is the
quality.  Myself I prefer the MOTM and I will stay
Motm, if the prices get too steep for me I just will
have to buy less and be more choosey than I am now.
In my business (commercial Photographer) I get people
who say I am very expensive and I am compared to the
average shooter.  But you get what you pay for.  I am
an artist just like some of the musicians on this
list, dont you hate to be chisseled?  So why are you
busting Pauls Balls?????  oh that rhymed.
And Ken... what is going on with your patch book
series?????
I for one enjoyed it.
John
--- Kenneth Elhardt <elhardt@...> wrote:
> Mike Estee writes:
> customer. It's the
> bit further. :-)
> -Elhardt
Do You Yahoo!?
http://mail.yahoo.com
