Analogue Delays
Analogue Delays
2003-12-07 by jagooher
Hi MOTMers
I am looking for an analogue delay unit to use with my MOTM system
and wondered if you guys had any recommendations.
I have looked at the Moogerfooger (now deleted) and Analogue Systems
unit (RS290) but the AS is the wrong format and a pain to integrate
into my current setup.
I am also thinking of building (re-engineering) the delay circuitry
into the MOTM format to integrate into the modular.  I will consider
vintage or modern but not Tape.
I have a number of  DSP outboards but digital delays are not
particular user friendly so I wanted the analogue sound with real-
time control options.
Any suggestions or pearls of wisdom are welcome.
Many thanks
Jagooher.
RE: [motm] Analogue Delays
2003-12-07 by John Loffink
The Blacet Time Machine appears to be available from the Blacet web site:
http://www.blacet.com/TM2050.html.  You can get an MOTM "Stooge" panel for
this on the next run of panels and marry this with the basic kit from
Blacet, buying your own knobs, pots, jacks, etc.
For a digital delay with better user interface and much better sonic quality
you could either use an Electrix MO-FX (very recent vintage) or Ibanez
DM2000 (older vintage).  These are both rack units.  Paul has started
working on a digital delay but you know how long the delay can be (pun
intended).
John Loffink
> -----Original Message-----
> From: jagooher [mailto:rslawson@...]
> Hi MOTMers
Re: [motm] Analogue Delays
2003-12-07 by J. Larry Hendry
I agree that the Blacet TM is a good choice.  It is certainly not going to
be clean like a nice digital delay.  But, if analog is what you want, this
is the one from our friend John Blacet.
Once you get one you have 3 very good options to use it in the MOTM size
format.  If you build yourself, you can buy a Stooge or Schaeffer panel and
a Stooge mounting bracket and build it into the large format.  If you buy
your stuff built, buy one of John Blacet's neat conversion panels that holds
his modules in the MOTM space and gives you a spot at the bottom to wire up
the extra 1/4" jacks.
Larry Hendry (1 of 2 Stooges in the synth parts business)
www.wiseguysynth.com
To: 'jagooher' <rslawson@...>; <motm@yahoogroups.com>
Sent: Sunday, December 07, 2003 11:03 AM
Subject: RE: [motm] Analogue Delays
intended).
John Loffink
> Hi MOTMers
2003-12-08 by Mark
I have a half dozen analogue electronic and mechanical delays, and
four digital delays (I had more but I sold them).  It sounds like you
want a BBD, although some of the early non-DSP digital delays (such
as the Korg SDD-2000) can produce similar effects (eg. the sampling
rate changes as the delay time is modulated).
The problem with analogue delays is that, afaik, BBD chips are no
longer made. If the Blacet Time Machine is still available, that is
probably your best choice.  I know nothing about the AS.   Other than
those, you can get a used delay, but I wouldn't recommend hacking it
up to fit MOTM format.  Not only could you run into all sorts of
problems with adapting the power supply, getting the pots to fit,
etc., but it would lower its resale value.
On 12/7/03, jagooher put forth:
>Hi MOTMers
>Many thanks
>Jagooher.
2003-12-08 by rslawson
Many thanks for all your responses to my question - much appreciated
Jagooher
Sent: 08 December 2003 19:34
To: motm@yahoogroups.com
Cc: jagooher
Subject: Re: [motm] Analogue Delays
>Hi MOTMers
>Many thanks
>Jagooher.
