Preamp?
Preamp?
2003-11-12 by Robert van der Kamp
Hi all.
Now that I have my 490 running, I want to hear the sound of
a slightly distorted moog filter.
What do you guys use to boost an external audio signal (like
an Andromeda voice) up to the MOTM level (or beyond)? Will
the 190 do the job? Alternatives?
Robert
Re: Preamp?
2003-11-12 by rreprobate
The best choice is a channel strip product of some sort with gobs of headroom and a
D.I. input. The best choice until the MOTM pre-amp comes out, of course..
The 190 probably has enough gain to get it into reasonable operating levels, but not
enough to distort it.
Max
--- In motm@yahoogroups.com, Robert van der Kamp <robnet@w...> wrote:
> Hi all.
> Thanks,
> Robert
Re: Preamp?
2003-11-13 by coyoteous
You might try multing your signal to two or all three 490 inputs, though the
Andy may need some additional boost from a mixer, external pre, etc. I don't
believe there are any stock MOTM modules that provide "flat" gain (greater
than unity) with one input.
B a r r y S t r a m p
> Hi all.
> Thanks,
> Robert
Re: [motm] Preamp?
2003-11-13 by Black_Man_Music@yahoo.com
I suggest running thru your mixer than use the direct
out... or the FMR RNP preamp. This is what I do since
I have had no synth (mono) throwing out enough gain to
drive a MOTM filter.
--- Robert van der Kamp <robnet@...> wrote:
> Hi all.
> sound of
> signal (like
> beyond)? Will
> Thanks,
> Robert
Do you Yahoo!?
Protect your identity with Yahoo! Mail AddressGuard
http://antispam.yahoo.com/whatsnewfree
Re: [motm] Re: Preamp?
2003-11-13 by Robert van der Kamp
> with gobs of headroom and a D.I. input. The best choice
Wasn't the MOTM pre-amp idea ditched? Or was that the
turntable preamp?
> reasonable operating levels, but not enough to distort
> it.
I see, too bad. I'll try to abuse one of my mixer strips
than, but I guess I need some better solution.
Will a preamp crank up the level to MOTM levels (10V pk-pk)
anyway? Isn't that way too hot, even for pro audio
environments?
(Don't hit me if I said something terribly dumb.)
- Robert
> inputs, though the Andy may need some additional boost
> from a mixer, external pre, etc. I don't believe there
> (greater than unity) with one input.
I remember reading a somewhere in the docs in one of my kits
about a knob having a scale of 0-2, where the '5' position
was unity gain. This was probably the 190 that I still have
to build. I'll have to check that.
Btw, I never would have thought that multing a singal into
the three 490 inputs would work. My gut feeling was that
the energy of the source signal would be distributed over
the 3 inputs. But I'll sure try.
Robert
Re: [motm] Preamp?
On Thursday 13 November 2003 15:27,
Thanks for the tip. How do you know the level is hot enough
to drive a MOTM filter? Did you measure the RNP's output?
- Robert
Re: Preamp?
2003-11-13 by rreprobate
10V is .... *eyes shut squints brain hurts for a second*
+22 db
I think.
You can check your equipment's specs to see how close you can get to that. Many pro
consoles run on 18 volt rails, and theoretically have better headroom than a MOTM. I
think Mackies poop out about right there.
That's all the log math I can handle for one day.
Max
> environments?
> - Robert
Re: Preamp?
2003-11-14 by coyoteous
You should get about 6 dB of gain for each doubling of the number of inputs -
works for CV ins, too.
> Thanks,
> Robert
Re: [motm] Preamp?
2003-11-14 by Jim Black
No... didn't measure, just hooked it up and it worked.
Any preamp will do, the RNP is just cleaner and pretty
cheap for the quality. As I am sure any pro or
semi-pro mixer will provide enough gain.
> enough
> output?
> - Robert
Do you Yahoo!?
Re: Preamp?
Correction re: MOTM modules that provide "flat" gain (greater than unity) with
one input -  the 420 has about 7dB. No doubt you get some nice character,
too. Anyone know of others?
> > Thanks,
> > Robert
