Simple PCB idea - any interest ?
2003-10-06 by J. Larry Hendry
I have had this idea for quite some time for a useful PCB for add-ons and
modifications.  I "borrowed" the idea from Thomas Henry from a PCB I got
from him one time called "utility knife" or something like that.  But, he no
longer sells them.
So, here is the idea.  I would appreciate hearing from you if:
a - you have comments or ideas to improve on mine.
b - you think you might like to have some of these PCBs.
I plan to call this a Muub PCB (Pronounced like the wrong way to pronounce
"Moog")
Muub is the acronym for "Multiple Use Utility Buffer"
This PCB would be very small.  Maybe about 1" to 1.5" square (whatever it
takes).  It could be mounted in two ways -- a single hole for a stand-off,
and a way to mount it from the back of the pot. The back of the pot method
would probably follow the Oakley method using the very small pot mounting
brackets.
The PCB would have space for a single 8 pin DIP op amp and the supporting
resistors / caps to configure as:
dual inverting amps / summing amps
dual non-inverting amps / non-inverting buffers
dual reversing attenuator
dual differential amps
dual LED drivers
support 8 pin DIP comparators
The configuration would be determined by how you installed the resistors and
small number of jumpers on the PCB.  To me this would be very useful for
adding onto and/or modifying existing modules and it is not intended to be a
stand alone circuit.  every time I add a small proto board to a project, I
think how nice one of these might be.
If there is sufficient interest, I will look into having these made or share
design ideas with one of the other guys here that makes PCBs to get these
made.
2003-10-06 by Roger Rossen
Larry,
I think this is a great idea!  So you know (and may already) Radio
Shack (yuck/hurl/barf) makes a pretty cool little board like you
described.
I can post some pix if its needed and wanted...I recently purchased a
bunch at a blowout sale.
Just trying to save you some time...so we can all reap the already
established benefits of stooge-land!
However, if you do pursue this endeavor, I'd like to contribute as I
tend to want to 'mod' everything myself also! (This is just some sort
of maniacal electronic engineering ego - if there is such a thing...I
mean its nothing as UGLY as a 'musician/rock-star ego' !!!)
Rog
Re: Simple PCB idea - any interest ?
2003-10-06 by elle_webb
pronounce
> "Moog")
A swiss-knife knife board would be good. A swiss-army knife module
would be great, though.
I'd generally prefer having a few utility modules over modding the
MOTM modules. A MUUB module might serve that need. Richard Brewster
did something along these lines last year. Would it make sense to
consider something along these lines?
