Also, if you are in a tool-aquisition mode, get a T-Handle Reamer:
http://www.tecratools.com/pages/service/punches.html
Second up from the bottom
Fantastic for cleaning up drill holes, enlarging them slightly, etc...
You will use this a _lot_
Other sources:
http://www.alvordpolk.com/catalog/dept.asp?id=84
expensive though - but they do have one that does up to 0.75"
These are not easy to find but worth the search...
Dave
> -----Original Message-----
> From: Richard Brewster [mailto:pugix@...]
> Sent: Friday, August 01, 2003 6:57 PM
> To: motm@yahoogroups.com
> Subject: Re: [motm] drilling holes
> Thanks. I am going to take a trip to Lowe's (and also to
> Sears) to see about this UniBit. I have hand-drilled some
> panels using the series-of-increasing-size-bits technique.
> If the UniBit lends itself to hand drilling, I will get one.
> The secret to hand drilling is to secure the panel very
> firmly on the bench, and get the starter hole centered right.
> I use a couple of grip-clamps I bought at Lowe's for one job
> and have never ceased to find new uses for them. They have
> rubber edges, perfect for holding panels without scratching.
> -Richard Brewster
> > Just so there is no confusion, I found the actual name of
> the type of
> > bit
> I
> > was talking about. It's a UniBit. Pictured here at Amazon:
> http://www.amazon.com/exec/obidos/tg/detail/-/B00004THZ0/qid=1
059768008/sr=1-
> 2/ref=sr_1_2_etk-tools/102-0259128-8936164?v=glance&s=hi&n=228013
> I believe I paid about half that price at Lowe's hardware. And it
self-deburs
> the front of your hole. Just turn your panel over and hit it lightly
> with the bit to debur the back of the hole.
> -Elhardt
Your use of Yahoo! Groups is subject to
