Envelope Follower
Envelope Follower
2003-03-02 by coyoteous <satori@telepath.com>
I'd like to see the envelope follower this year and of course, the
130(?) dual vca/panner.
Also, why isn't the 910 available as a kit?
>After that, I guess JH, Crow and I will have to cook up some new
>stuff for the remainder of the year. SEM filter, anybody? :)
> Paul S.
Envelope Follower
2003-07-19 by groovyshaman@snet.net
It may be a ways off, but there is a MOTM Envelope Follower in our future,
yes?  I did some searching of the archives to see if I could determine any
info on this "elusive" device. :)  Not much luck, I'm afraid.  All I could
find was, that Paul indicated he was either going to go with a more
"standard" design, or a totally "over-the-top" design.  I sure what ever he
chooses, it will kick a@@.  In any case, I am wondering, what functions
should this module include?
Obvious features would include rudimentary preamp, signal input, input gain,
gate output, gate threshold control, response time control, envelope out and
envelope level.
Some addl. potential features might be:
mic vs line level input
separate attack and decay response settings
trigger out
gate led
clip led
preamp out
FWR out
peak-correction circuitry (to enhance performance for even-harmonic signals)
multiple FWR/peak-correction AC-coupled stages
Any thoughts out there?
George
Re: [motm] Envelope Follower
2003-07-20 by jwbarlow@aol.com
In a message dated 7/19/2003 4:24:52 PM Pacific Daylight Time, groovyshaman@... writes:
envelope level.
trigger out
gate led
clip led
preamp out
FWR out
I've got some out there thoughts all right!
This is one of the least "standardized" modules around. In the ARP 2600, there is an input section (left-hand side) which has three modules:
1) Preamp -- with two level controls (a knob and a switch for "X 10 -- X 100 -- X 1000").
2) Envelope Follower -- one level control.
3) Ring Modulator -- two level controls (one for each input) and a switch for AC/DC coupling of the inputs -- not really part of the Preamp/Envelope Follower scheme.
Other useful modules are the Lag Processor and the Inverter (located in the lower Voltage Processors section).
So note that there is no way to generate a trigger or gate signal (and therefore, no way to use the EGs) from an external device (actually I think if you use the RM as a DC coupled VCA you might be able to get a gate out, but I haven't tried it yet and it's a poor use of a lot of good hardware for something so simple). But it does provide you with a few useful features.
Contrast that with the Serge Preamp Detector module:
1) Preamp section -- HI Z and LO Z inputs and one level knob and an output.
2) Detector section -- Input, LED (indicating level) and an output. Also, a coupler switch so that the detector input comes from the preamp output.
If you want to process the CV output of the detector (and you will!) you run that into one half of a Dual Slope Generator (for limited VC Lag control). If you want to generate a gate to fire an EG, you run it through a comparator (remember, the ARP has no comparator available).
I have ordered a Preamp module from Tony A. but I can't remember what features his has, though I seem to recall it as being a good selection of controls.
I bring up these examples (since they are the ones I've had the most experience with) to show that there are different ways to look at these input modules. Do you have the full featured external input module with a hundred knobs, or have a hundred micro sized modules each with one input one output and one knob. I would choose some middle ground -- I can imagine a single input module which would have the following features:
1) Preamp -- multi level capable (mic, guitar, line level) with some sort of level indicators to indicate 90% to 100% and over 100% levels (maybe one of those three color LEDs), and a gain control, and an output.
2) Gate (and maybe Trigger) extractor -- I'd prefer this to be a simple one knob (comparator) affair, but I recall some discussion about having differing on and off levels. I think that would be confusing to the user and not terribly useful. Maybe a gate LED would be fun.
3) Envelope Follower -- have a single voltage which follows the envelope generated from the preamp output. Maybe it would have a single level control. But also have a second processed output which would take that output run it through a lag processor with separate up and down lag controls (if only so you could get simple backwards envelope sounds). Maybe an output LED on this second output would be fun as well.
So that would be one or two inputs, five outputs, maybe five knobs, maybe three LEDs -- seems like it could all fit on a 2U panel.
As far as your last three things on you list, George, I don't know what they are. If they FWR is used for fuzzbox like timbres, I would prefer to see a separate module for half and full wave rectification. If it is part of the EF output, I'm not sure what you mean to do there. I have the same thoughts about the other things you mention (like peak detection) -- isn't that why you are taking the input, so you can processes it through inverters and VCAs etc?
And after I wrote all that, I decided to look here:
http://www.oakleysound.com/follower.htm
And John Blacet has a nice input module too, though I can only get his tech notes page at the moment. http://www.blacet.com/
JB
RE: [motm] Envelope Follower
2003-07-20 by Paul Haneberg
It seems to me I read something once about using multiple FWRs as
frequency doublers in envelope followers.  This is supposed to improve
the response time.  I may have read this somewhere in ElectroNotes, I'm
not sure.  I'm out of town at the present time and unable to verify the
source.  It might be interesting to have outputs from multiple FWRs on a
module such as this.
Sent: Saturday, July 19, 2003 7:29 PM
To: motm group
Subject: [motm] Envelope Follower
future, yes?  I did some searching of the archives to see if I could
determine any info on this "elusive" device. :)  Not much luck, I'm
afraid.  All I could find was, that Paul indicated he was either going
to go with a more "standard" design, or a totally "over-the-top" design.
I sure what ever he chooses, it will kick a@@.  In any case, I am
wondering, what functions should this module include?
gain, gate output, gate threshold control, response time control,
envelope out and envelope level.
trigger out
gate led
clip led
preamp out
FWR out
signals) multiple FWR/peak-correction AC-coupled stages
George
Your use of Yahoo! Groups is subject to
2003-07-20 by groovyshaman@snet.net
Yes, this is my understanding.  And yes, Electronotes #60, #86, #88 & #89 -
good memory!  There is a trade off when determining the time constant of the
filter between being able to detect snappy envelopes and reducing the amount
of voltage ripple on the detected envelope for lower frequencies.  Obviously
fast envelopes at low frequencies is the biggest problem.
So by adding say two additional FWR sections, this would quadruple the
frequency of the signal (in theory) thereby allowing the low-pass filter
cutoff frequency to be increased, which in turn improves the speed (response
time) of the envelope detection.  From what I understand however, FWR does
not work properly for sine waves (or other predominantly even-harmonic
waveforms), as the subsequent waveforms are not symmetrical about the x axis
and do not frequency double.  An AC-coupled peak-correction circuit can be
used in conjunction with each FWR section, to add in the appropriate amt of
offset voltage to the FWR section to make up for the non-symmetry in the
waveform.  (I think I've got that right :)
Anyway, I have yet another crazy feature that may be nice.  I think I
remember reading about it somewhere, the MAM filter or something?  Have
three envelope follower sections, each tracking a separate frequency range,
say low, mid and high.  Then the envelope output of each of those could be
sent to the three inputs on the OMS-410 filter companion module.  Woah -
sounds like fun!
One more thought (like beads of water on the forehead, eh? :) .. until a
MOTM equivalent is available, if one has a Wavefolder and a MOTM-820, a
simple envelope follower could be patched up.
Cheers,
George
2003-07-20 by Thomas Hudson
Another interesting implementation (especially for guitarists) is from
an article by Harry Bissell:
http://go.cadwire.net/?3572,3,1
It uses three peak detectors which are continuously reset. I did a
digital implementation as a Mac Audio Unit, and the responsiveness for
guitar is quite nice.
I don't have the wavefolder, but I patched up a rudimentary EF by
sending an amplified guitar signal to both inputs of the 110 ring mod
followed by an 820. Lot's of ripple but still fun.
Tomy
>> I'm
>> the
>> on a
> #89 -
> of the
> amount
> Obviously
> filter
> (response
> does
> x axis
> can be
> amt of
> the
> range,
> could be
> sounds like fun!
> a
> Cheers,
> George
> Buy Ink Cartridges or Refill Kits for Your HP, Epson, Canon or Lexmark
> Printer at Myinks.com. Free s/h on orders $50 or more to the US &
> Canada.
> http://www.c1tracking.com/l.asp?cid=5511
> http://us.click.yahoo.com/sOykFB/k9VGAA/ySSFAA/VpLolB/TM
Re: Envelope Follower
2003-07-22 by konkuro
Don't laugh, but one of my favorite envelope followers of all time
was the PAIA design. At certain settings it was a rather accurate
pitch follower. It was also excellent for processing audio. I used it
for very convincing thunder and for a a cello sound that would almost
shame Elhardt.
Sometimes simpler is better.
johnm
[motm] Re: Envelope Follower
2003-07-23 by elhardt@att.net
Johnm writes:
>>Don't laugh, but one of my favorite envelope followers of all time was the
PAIA design. At certain settings it was a rather accurate pitch follower. It
was also excellent for processing audio. I used it for very convincing thunder
and for a a cello sound that would almost shame Elhardt....Sometimes simpler is
better.<<
Such a ridiculous and physically impossible statement.  There isn't anything
about an envelope follower or its filtering capability that comes close to the
kind of complex freq response and sound I get from the processing I do. And
it's only going to get more complex when I upgrade the OS.  Simpler is only
better for simple sounds.
When I first got my Multimoog, I used to think I got a decent cello sound from
it when I played it through a Leslie speaker and used my right hand on the
ribbon controller to give it manual vibrato much like a real string player. I'm
sure if I heard it today it wouldn't sound very good.  Memory has a way of
altering the past.
-Elhardt
2003-07-24 by konkuro
anything
close to the
do.<
Thank you for the humble reply, but a synthesist of your caliber must
know that sometimes extremely simple patches yield extremely complex
results. Please note that I said the sound would *almost* shame your
cello. But that ain't bad, given that it didn't require 100 digital
filters.
I might have mentioned the patch in a (not very good) Polyphony
article called "The Sensuous Envelope Follower."
As I recall, the cello sound used a pulse wave (going from spikey to
fat), modulated by an ADSR.  When pulse waves start out very skinny,
they look like DC to the envelope follower because the spikes are
filtered out.  The PAIA design couldn't pass DC, so the sound would
start at zero, then become fuller. Complex stuff happened as this
transition occurred that gave a wonderful "bowing" effect--and the
timbre was just right.  Mind you, the effect was good only over an
octave or so, but it was very convincing.
johnm
2003-07-25 by elhardt@att.net
Konkuro writes:
>>Thank you for the humble reply, but a synthesist of your caliber must know
that sometimes extremely simple patches yield extremely complex results. Please
note that I said the sound would *almost* shame your cello. But that ain't bad,
given that it didn't require 100 digital filters.<<
Actually to say that something almost shames something else is to imply that it
is so much better that it would almost cause shame to the other.  Knowing that
an envelope follower set to the point where it might pass sound through it,
means it's probably nothing more than a full wave rectifier.  And that hardly
compares to the "100 digital filters" thing.  Afterall, if it were that simple,
MoogCE wouldn't be selling $1500 36 band string filters, but $20 rectifiers
instead.
And sure I know that simple patches can yield complex results (not for complex
wooden body resonance though).  I had a couple of people on the Nord list
amazingly wonder how I could have done that complex sounding piano slam patch.
After posting the patch it almost seemed as if one guy was disappointed at how
simple it was.
-Elhardt
2003-07-26 by grotechef
hello,
isn't it possible to use the lag processor as an enveloppe follower
(with up-pot set to minimum and down-pot set to slew so it 'rides'
the enveloppe?)
greetz,
chef!
RE: [motm] Re: Envelope Follower
2003-07-27 by John Loffink
Yes, this will work to a limited extent.  Up control should be at or
near zero and Down control should be about 5.
Ideally you would precede this with a full wave rectifier.  My DIY Diode
Waveform shaper module can do that, information located here:
http://www.wavemakers-synth.com/motm/dws.html .  Nothing immediately
comes to mind for accomplishing this with just MOTM modules, but somehow
I feel an MOTM-800 Dual VC Router patch coming on. :-)
John Loffink
jloffink@...
http://www.microtonal-synthesis.com/
The Wavemakers Modular and Integrated Synthesizer Web Site
> hello,
> the enveloppe?)
> greetz,
> chef!
2003-07-27 by Mike Marsh
And if you have Tony's WaveFolder, that'll do the trick, too...
or
Diode
immediately
somehow
> John Loffink
> jloffink@a...
> > hello,
follower
it 'rides'
> > the enveloppe?)
> > greetz,
> > chef!
That should be MOTM-700 Dual VC Router.
John Loffink
jloffink@...
> -----Original Message-----
> From: John Loffink [mailto:jloffink@...]
> Sent: Sunday, July 27, 2003 12:08 PM
> To: 'grotechef'; motm@yahoogroups.com
> Subject: RE: [motm] Re: Envelope Follower
Diode
somehow
> John Loffink
> jloffink@...
> > hello,
> > the enveloppe?)
> > greetz,
> > chef!
I could not get my Oakley Wavefolder to do the full wave rectification
by itself.  You would have to take the clamp and clip outputs and mix
them together, which indeed is another solution to the problem.
John Loffink
jloffink@...
> or
> Diode
> immediately
> somehow
Re: Envelope Follower (rectifier question)
2003-07-27 by grotechef
hello john,
excuse my ignorance - why would i want to full wave rectify the
signal before inputting it to the lag processor?
thanks for your feedback!
greetings,
chef!
Re: [motm] Re: Envelope Follower (rectifier question)
2003-07-27 by jwbarlow@aol.com
In a message dated 7/27/2003 1:03:14 PM Pacific Daylight Time, grotechef@... writes:
Because, if you put an AC signal into a lag processor it will act like a low pass filter (sound familiar). If you put the signal through the lag processor with no lag time you will hear (pretty much) the original signal (as far as harmonic content). As you increase the lag time you will hear the filtering effect -- sounding much like changing the cutoff frequency of a low pass filter.
By using a full wave rectifier you are moving all the negative going portions of the waveform to the positive side of 0 volts -- you are flipping those sections into positive territory so if you listen to the output from the FWR you will hear a very different waveform than at the input (weird harmonic content) since the wave shape has changed radically.
By making the waveform fall only on one side of 0 volts we are adding (surprise) a DC component to the input signal (as well as screwing around with the harmonic content). If we use a lag processor to filter out the AC (since it acts like a low pass filter), we will be able to derive an envelope which follows the input signal.
Best,
John (but not the one who first mentioned FWR)
2003-07-28 by Oakley Sound
by itself.
Try setting the WF to the following:
Gain set to around 2 o'clock.
Threshold set to mid point.
Fold set to around 10 o'clock.
Output to full.
Output signal taken from main output. Clamp polarity will set the
polarity of the output. Lower will give you positive only signals.
This will also act as octave doubler for triangle waves.
Tony
2003-07-28 by Mike Marsh
Yep, works for me.  COnfirmed it with a scope, too.
rectification
> by itself.
> Output to full.
> Tony
2003-08-01 by John Loffink
Okay, I finally had a chance to try this out.  I don't know why I
couldn't get this before.  However, my settings are more like Gain at 10
o'clock and Fold almost to 11 o'clock.
John Loffink
jloffink@...
> rectification
> > by itself.
> > Output to full.
> > Tony
2003-08-02 by Mike Marsh
Yes, my settings were not exactly TOny's either.  Damn this analog
imprecision!  But I do have a question: is the gain there
to 'saquare off' the waveform?
Mike
at 10
> John Loffink
> jloffink@a...
> > rectification
> > > by itself.
> > > Output to full.
signals.
> > > Tony
Or more precisely 'square off'...sheesh
> Mike
Gain
> at 10
> > John Loffink
> > jloffink@a...
> > > rectification
> > > > by itself.
> > > > Output to full.
set
> the
> signals.
> > > > Tony
