Paging Barry Stramp.
2003-06-03 by robert taylor
Sorry for the bandwidth, but I need to contact listmember Barry Stramp about using the companion panel to the�JLH 822.� I was told it was just wiring and ?
Please contact me.
Thanx, robert
Add photos to your e-mail with MSN 8. Get 2 months FREE*.
Re: Paging Barry
2003-06-03 by coyoteous
Robert,
Yes, just wiring and passive components. It's just two passive attenuators (that
could be used for anything), two additional outputs for the 822 (tap from 822
outs), plus and minus bias outs (tap from PS with a current limiting resistor
[very important or you'll smoke your supply] and a voltage divider, if you want
lower voltages). Now that leaves two jacks: MOD A and MOD B, these are
really what the panel was designed for, the rest is functional filler. To use
these your 822 will have to be modified. Larry designed the 822 with the
capability of having an extra input for each channel which is summed to the
output along with the main IN and the switched offset, I'll defer to him for the
implementation. Mr. Hendry also advised using a trimmer to calibrate for 1V/
oct usage from the MOD input (i.e. transposition), though I haven't
implemented this. The basic idea is to be able to route an LFO (or other
modulation source) to multiple VCOs at the same level of modulation. Anyone
is welcome to use the panel.
Barry
Re: [motm] Re: Paging Barry
2003-06-04 by J. Larry Hendry
To take up where Barry left off -- The only modification to the 822 is to
install 2 additional resistors in the summing input circuits.  There are
already places on the PCB to add these resistors.  However, you have to
either land them on one end only or make a small cut in the PCB traces on
the bottom. I can provide details for anyone interested in implementing
Barry's panel.  So far, it is a one of a kind.
To: <motm@yahoogroups.com>
Now that leaves two jacks: MOD A and MOD B, these are really what the panel
was designed for, the rest is functional filler. To use these your 822 will
have to be modified. Larry designed the 822 with the capability of having an
extra input for each channel which is summed to the output along with the
main IN and the switched offset, I'll defer to him for the implementation.
Mr. Hendry also advised using a trimmer to calibrate for 1V/oct usage from
the MOD input (i.e. transposition), though I haven't implemented this. The
basic idea is to be able to route an LFO (or other modulation source) to
multiple VCOs at the same level of modulation. Anyone is welcome to use the
panel.
