Studio Cabling Advice
2003-02-16 by alt-mode
Since this group seems to be very keen on cables, I have a few studio
wiring questions to ask.  Any advice is welcome, either publicly or privately.
I'm just finishing off a room in my basement for my studio.  The floor has
been raised and there are channels in the floor so I can run wires under
the floor fairly easily.  I like to organize my studio around different
work areas, mostly based around different synths.  Each area has a submixer
and Neutrik patchbay with 8 balanced trunk lines running to the console
area.  This allows me to route things easily to various parts of the studio
as needed.  When recording, I run the source into a direct box or preamp
near the work area and run balanced lines to an A/D converter so the
submixers are only used to keep things available for playing around or
composing.
In the past, I have used Hosa 8-channel snakes for most of this wiring.  My
results have been mostly good but I wonder if I could do better.  Most of
the runs will be under 20'.  Should I:
- Stick with the Hosa snakes
- Make my own snakes out of multiple cables using nice cable and connectors
- cable recommendations welcome.
- Make snakes out of multi-conductor cable, again suggestions welcome.
Finally, has anyone used balanced power systems and have any information
good or bad about them?
	Eric
Re: Studio Cabling Advice
2003-02-17 by paulhaneberg <phaneber@one.net>
It sounds like your studio is laid out very well.  I have some of my
synths in my control room and some in the studio.  If the studio
were strictly for my own use I would probably keep them all in the
control room, but as it is now I'm constantly running back and forth
and often moveing them about as well.  My MOTM is in the studio
rather than the control room (it is too big to move.)  Luckily I can
remote control ProTools to some degree from the studio.
Anyway, I have used the HOSA snakes as well as a number of other
brands.  In my experience the HOSAs work just fine and I cannot tell
any difference between the HOSAs and the more expensive cabling.  I
also have tried a number of different patch bays.  The biggest
complaint I have with the patch bays is that although they seem to
work fine with audio signals, they do not like phantom power.  Since
I have several very expensive mike preamps and I like the
versatility of having them wired through the patchbay, I am now
considering an outboard source of Phantom power which I could place
near the mics before the signals go into the patchbays at all.  But
getting back to your question, there are a lot of cable fanatics who
will say that there is a huge audible difference between cables.  I
cannot tell the difference with the exception of the very cheapest,
(Radio Shack quality made in China.)  There are some mechanical
differences though.  If you plan on moving connections around a lot
I'd go with better quality cable and jacks.
On the subject of balanced power, I have built my own balanced power
system for my entire studio with a capacity of 10KW.  I have noticed
a big improvement using balanced power.  With very few exceptions
hum is nonexistent and noise seems to be lower as well.  My
transformers are not toroidal, but they are in an area where there
is no audio present.  I would strongly recommend using balanced
power, but I would also strongly recommend buying an off the shelf
unit rather than taking the do it yourself approach.  The only
exceptions I have found are that occasionally some single coil
pickup guitars will pickup hum from my lighting (which is not
balanced power, but I do use variacs for dimmers.)  At some point I
may add another large transformer and run my lighting balanced power
as well.  The other exception is that Samson mixers do not like
balanced power and always hum like crazy for some reason.  I have
not had this problem with any other brand of equipment, but have had
4 different Samson mixers that all hum.
Hope this helps.  I really like your idea of creating work areas.  I
may think about doing something like that myself.
Paul Haneberg
2003-02-17 by Eric Frampton
Hi Eric
> wiring.  My
> of
> connectors
While the Hosa snakes aren't the most durable cabling in the world,
where they always seem to fail is around those molded end connectors,
and once those go it's not really worth fixing them. Sonically they're
fine but not amazing, but it doesn't sound like you're building Real
World in your basement.
Since it sounds like you've already got plenty of them already, why
don't you wire up as much as you can with those, then as they fail
one-by-one start replacing with home-built patch cables made from the
better stuff? In my case, as my old mic cables are failing, I'm
building Mogami quad ones to replace them.
I hate building snakes. It's a PITA. But that's a personal preference
thing.
> information
Can't answer that one, but all of these questions have been discussed
at length on the rec.audio.pro newsgroup. Point Google to Groups and
start poking around there. The general consensus on the balanced power
is, yes, it makes a difference, but you're going to have to balance the
fairly subtle difference (in Digital world) with a fairly expensive
installation. Folks have said that it makes a much more noticeable
difference with things like guitar amplifiers.
e
Re: [motm] Re: Studio Cabling Advice
2003-02-17 by alt-mode
Paul,
Thanks for the thoughtful reply.  I have a feeling that I'll use the Hosa
snakes that I have and if I need some odd lengths, I'll make them
myself.  The cabling doesn't move once it is set up.
I use a Keyspan Digital Media Remote for controlling Logic Audio from
places away from my computer.  This is  a little infrared remote control,
much like a TV remote control but the base plugs into a USB port.  You can
customize the buttons for any application.  It seems to work better on Macs
than on PCs.
To solve the mic preamp problem, I have mounted my preamps in a small SKB
case with a small patch bay.  The preamps then can move close to the source
and drive balanced lines back to the converters.
Thanks for the advice on balanced power.  I'm planning to get an Equi-Tech
unit to power the studio.  I may, gulp, have to get a second one if I don't
get enough power out of the first.  The problem with these things is that
they are dog gone expensive!  You don't think about paying that much for
power...
I found the work area setup necessary once the setup had become too large
to arrange everything around me.  Funny how modular synths can cause this
;)  Oh, for a glimpse at how Vince Clarke organizes his synths (dust and
all), for those who haven't seen this on the AH list, see
http://www.garethjones.com/erasure_stuff/erasureindex.html
	Eric
Vince Clark and his MOTM?
2003-02-18 by Tentochi
Eric--
I didn't see any MOTM in Vince's studio or at the
session.  What gives????
Did you talk to Vince about MOTM at all?
It looks like it was a great gig!
Cheers!
Shemp
> list, see
Do you Yahoo!?
Yahoo! Shopping - Send Flowers for Valentine's Day
http://shopping.yahoo.com
RE: [motm] Vince Clark and his MOTM?
2003-02-18 by Les Mizzell
> his synths (dust and all),
There should REALLY be a law preventing things like this:
http://www.garethjones.com/erasure_stuff/synths/images/116-1603_IMG_JPG.jpg
Makes me want to just cry or something.
Re: [motm] Vince Clark and his MOTM?
2003-02-18 by Paul Schreiber
My Xpander has been on the floor behind a chair for 3 years. The chair hasn't been sat in in 3
years, either: it's where my bag of packing peanuts rests. Somewhere under THAT is an Eventide
DSP7000 (I *think*). Sigh.
To: <motm@yahoogroups.com>
Sent: Monday, February 17, 2003 11:05 PM
Subject: RE: [motm] Vince Clark and his MOTM?
Re: Vince Clark and his MOTM?
2003-02-18 by strohs56k <strohs@eskimo.com>
Its obviously seen some use - maybe even gone on tour?  Not
necessarily a bad thing...
I actually own two of those!  (Neither one in bad shape - though one
of them does have a failing encoder.)
Seth
[motm] Re: Vince Clark and his MOTM?
2003-02-18 by Jason Proctor
I saw it once on The Tube or Later With Jools Holland back in England
so it's probably been around a bit.....
Re: [motm] Re: Vince Clark and his MOTM?
2003-02-18 by Neil Bradley
Yup - it has. Vince mentioned it in a magazine article somewhere that the
Xpander was used in the Chorus tour.
Though I must admit I never have had the urge to get naked or go shirtless
in the studio with my fellow composers...
-->Neil
Neil Bradley            In the land of the blind, the one eyed man is not
Synthcom Systems, Inc.  king - he's a prisoner.
ICQ #29402898
2003-02-19 by alt-mode
Ummm, I don't know Vince but I'd love to watch him work in his studio
sometime.  I'm sure I'd learn a lot!
         Eric
At 08:59 PM 2/17/2003 -0800, Tentochi wrote:
>Eric--
>Cheers!
>Shemp
> > list, see
>Do you Yahoo!?
