Fwd: Re: Supermoe metamorphs yet again
2003-02-19 by dave bradley
I meant to send this to the list, but it went privately... Moe --------------------------------------------- Replies inline below... > Since the DAB-1084 Control Voltage Generator is > 8 U wide, I would believe most people would go > for at least 2 of them. This brings the total > to 16 U. If you put 2 of them in a row, you > could use the row below it for Address > Generation. Indeed. I plan to construct a sequencer capable of 16x4, 32x2, or 64x1 using two DAB-1084 modules. They will be mounted in one of my main cabinets on the bottom row. > Now if arrange the DAB-1018 Address Generator > Interface so that instead having in 2 rows in 7 > U, you make it a single row so it becomes 14 U. > This leaves plenty of room to put at least 2 of > the DAB-1044 Pulse/Gate Generators below. Above > you would put DAB-1017 Address Generator I/O. > This would make for a more ergonomic and fluid > design. My original design called for the interface to consist of 2 7U panels so that it could be laid out in a straight line, which I agree is the ideal layout. Here's a direct link to that design: http://www.hotrodmotm.com/images/addrgen.jpg It pulls the pulse switch matrix into the main module and is a more conventional design as a result. The downside is that I'm trying to fit everything BUT the pot matrices into a single row 16U wide. That leaves only 2U which would have to go to the counter module, with no room for clocks or a second counter module. Still, it's worth reconsidering. Thanks for the comments! Moe http://www.hotrodmotm.com __________________________________________________ Do you Yahoo!? Yahoo! Shopping - Send Flowers for Valentine's Day http://shopping.yahoo.com
