Re: New Guy from the desert of Arizona (was Re: What's the deal with the list)
2003-02-06 by groovyshaman@snet.net
Hello Markk (is that with two k's?)
...and welcome to MOTM-dom!
MOTM is a great group to be a part of.  This is a very creative and intelligent
group of individuals.  Don't worry about asking questions, even if they seem a
bit "out there"; there's always someone willing to be helpful.  There's also
usually a lot of passionate viewpoints!  Don't confuse passion with arrogance
or bad feelings - most everyone means well (we all have our bad days, though).
Some of us have only a few modules, while others have nearer to 100 (I'm in the
middle).  It doesn't matter, everyone's given a fair shake; that's one of the
great things about this list.  And there's always something for everyone to
learn, yes? :)
** We have Paul to thank for this excellent experience. **
I also have some of Larry's modules - not bad from a guy who often works with
1000's of volts.. MOTM is a real step-down, eh? <drum hit>  His "fingerprints"
are also all over the MOTM-850.  (btw, joystick control, Larry??)
With all of your purchases it sounds like you'll be into some serious DIY,
which is great fun!  If you search the list history (as well as some of the
MOTM user web sites) you'll find interesting mods for some of the MOTM modules.
On to ferrite beads...
The MOTM part is: muRata BL01RN1 (alliedelec.com #711-4101)
A good (improved?) alternate is: Fair-Rite 2743004112 (mouser.com
#623-2743004112)
Is this what you were looking for?
As for power supplies...
I started with a MOTM-900 but have outgrown it's capacity.  It can power about
20-25 modules "safely" (maintaining a safety margin).  Power-One makes plenty
of bigger +-15V supplies.  I'm going the "DIY route" as we speak and selected
the HCC15-3-A which gives 3 amps, which is about 75-90 modules.  Is this big
enough for you?  The HDD15-5-A gives 5 amps, which is about 125-150 modules.
Is that better? ;)  You'll also need a few MOTM-960 distribution PCBs if you go
this route.  More info on Power-One:
http://www.power-one.com/resources/products/datasheet/lin.pdf
The new 500 and 600 series modules require a +5V supply as well as +-15V, so
you might consider adding either a MOTM-950 just for those, or a DIY solution
such as the HBAA-40W-A (5V@3A, +-15V@.8A) which is "larger" than the MOTM-950,
along with the new MOTM-990 6-wire distribution PCB.  It's a good idea to keep
the supply for the digital modules separate from your analog to "keep the noise
out".  (Hope I'm not bothering you with information that is obvious to you.)
Good luck!
Cheers,
George Kisslak
To: <motm@yahoogroups.com>
Sent: Thursday, February 06, 2003 2:20 AM
Subject: [motm] Re: What's the deal with the list
> "New Guy from the desert of Arizona"
> As usual, "a thank you" is in order for Larry...  <I am tipping my
> hat> I am on the list... I have ordered 2 of Larry's 822's first
> ironically, and have been a spending fool in the last week buying all
> my bench tools to get going. (just ordered 3200 Xicon resistors
> alone !!!) Mouser is gonna know me by first name basis <chuckle> I
> just haven't decided which modules to order from Paul yet, I was
> going to get the power supply, but after reading Moe's comments about
> large systems, I "know" I will need more. I may start with the MOTM-
> 800 then an Ultra VCO... dive right in.
>   This is a great bunch of individuals... so I will first search the
> archives for some minor problems I am having... <ferrite beads> ???
> then I will ask questions later...
>  One question for Tony K. from Encore... any word on the new
> Expressionist... Zon had mentioned you were designing a new format,
> possible one already in a panel version so we don't have to build
> Moe's breakout panel?
<snip>
2003-02-06 by Moog <moog960seq@yahoo.com>
--- In motm@yahoogroups.com, <groovyshaman@s...> wrote:
> Hello Markk (is that with two k's?) *** yep it sure is ***
> ...and welcome to MOTM-dom!  ***ahhh thank you ****
yes indeed :-)
works with
His "fingerprints"
serious DIY,
***AB-SOOO-LUTE-LY !!!******  :-) somewhere between, 90-145 modules,
I am starting with 4) 20 space tall anvil flight cases. That's 10u
wide x 4 module rows high. ala:Christopher Franke's Moog he gave to
Hans... something along those lines... ****
some of the
MOTM modules.
> #623-2743004112)
> Is this what you were looking for? ***YES !!! ***  Thanks :-)
><snip>
More info on Power-One: ***again, many thanks ***
<snip>
you.)
***** no, not at all... keep sending! **** all info is good.
> Good luck! Thank you :-)
> Cheers,
> George Kisslak
Cheers back, Markk
