Drilling question
Drilling question
2003-02-05 by Adam Schabtach
Question for those of you who have drilled Stoge panels with a drill press:
is it still advisable to center-punch the hole locations when using a drill
press, or is the bit not likely to walk? I guess it depends on how good my
drill press is, eh? :-)
Thanks--
--Adam
Adam Schabtach
adam@...
http://www.studionebula.com
Re: [motm] Drilling question
2003-02-05 by Kevin B
I just wanted to throw my $00.02 in here about drilling.� If you are getting ready to drill your Stooge panels (or any panel really), and you just so happen to have access to a machine shop equipped with a milling machine, use that instead of the drill press.� I found that a milling machine will make�a nice, perfectly round, clean hole with�almost no flash on the back side.� Also, they are usually more�precise than�most drill presses, and I have not yet needed to use a�center punch.� Another benefit is that the flash from the hole generally travels up the bit, away from what you are drilling, so you don't risk scratching your beautiful panel finish.� I'm not knocking drill presses, just if you happen to have a choice between the two, use the milling machine!� If you don't, then listen to Larry Hendry.
Kevin
Protect your PC - Click here for McAfee.com VirusScan Online
2003-02-05 by J. Larry Hendry
I always center punch.  I use the Sears automatic punch with the red ball on
top.  MUCH easier and more accurate than the hammer method.
LH
To: MOTM List <motm@yahoogroups.com>
Sent: Tuesday, February 04, 2003 6:32 PM
Subject: [motm] Drilling question
Thanks--
--Adam
Adam Schabtach
adam@...
2003-02-05 by Dave Hylander
Definitely use a center punch.  After punching the locations, I put some
masking tape on the face of the panel to protect it from the chips.  Then
pilot drill with a 3/16" or so bit followed by finish size.  Use a cutting
fluid if you have it.  A dab of liquid soap will work ok on aluminium.
Dave
2003-02-05 by ixqy@aol.com
Hello,
 When I was drilling my Miniwave panel, I couldn't center the punch on the
light bar holes. The LED holes were too small to see what I was doing. I got
around this problem by using a large nail. Since the tip of the nail had a
sharp point, I was able to make a small hole dead center at each LED
position. The nail only makes a small hole in the panel surface, but it's
just big enough to help center the punch afterwards.
 Andrew
In a message dated 2/4/03 7:49:00 PM Central Standard Time,
david@... writes:
press:
drill
Kevin brings up some great points about the hazards of drilling.
Here are some drillin' tips I use (your mileage may vary)
I cover the front with masking tape. Don't mash it on hard, just enough to cover. It has saved me from scratching may circles around the hole from flash traveling up the bit.
After I finish a hole (say 1/4') I take a 3/8 bit and clean the burrs from the front and back of the hole. That's easy with a press, hard with a hand drill. Those of you who use my drilling services will notice this (especially on the backs where I often go deeper than required.
And I agree with Kevin, IF I had me one of them fancy milling machines, I'd probably never leave the garage.
Sent: Tuesday, February 04, 2003 7:06 PM
Subject: Re: [motm] Drilling question
I just wanted to throw my $00.02 in here about drilling. If you are getting ready to drill your Stooge panels (or any panel really), and you just so happen to have access to a machine shop equipped with a milling machine, use that instead of the drill press. I found that a milling machine will make a nice, perfectly round, clean hole with almost no flash on the back side. Also, they are usually more precise than most drill presses, and I have not yet needed to use a center punch. Another benefit is that the flash from the hole generally travels up the bit, away from what you are drilling, so you don't risk scratching your beautiful panel finish. I'm not knocking drill presses, just if you happen to have a choice between the two, use the milling machine! If you don't, then listen to Larry Hendry.
Kevin
2003-02-05 by mate_stubb <mate_stubb@yahoo.com>
I'm probably too anal about it, but when I drill panels for folks I
start with a center punch, then progress up through 5 bit sizes to
keep the amount of metal being removed at any one time to a minimum.
That way I don't have to tape the front.
When drilling MiniWave LED rows, I cheat - I had a steel template
made that I can just clamp over the panel to ensure that the holes
are lined up.
Moe
the light bar holes. The LED holes were too small to see what I was
doing.
Thanks, everyone, for the drilling advice.
> are lined up.
That's a good cheat. Getting those eight holes done is going to be
interesting. I figure I can use a fence to make sure that they're all in a
line, but getting them evenly spaced is going to be a delicate task.
All of this is a moot point for awhile, though. It's snowing here in
Colorado and the garage is too cold for operating a drill press. :-)
--Adam
Adam Schabtach
adam@...
Re: Drilling question
2003-02-05 by echophazer <echophazer@aol.com>
--- In motm@yahoogroups.com, "mate_stubb <mate_stubb@y...>"
minimum.
> are lined up.
> Moe
If you want a good center punch check out this cool product:
http://www.ezlok.com/center.htm
You pop in a magnification lens with crosshairs. Line it up with your
center. Pull out the lens, slide in the punch which shares the same
centerline as the crosshairs and give it a tap with a hammer.
Unfortunately since I work in a metrology lab my standards of anal go
well beyond .002" though.
Peter
Re: [motm] Re: Drilling question
Wow !!  Now there something nice to have.   Are they expensive?  Of course,
if I used that on each of the 200+ panel holes I drilled Sunday, it might
have taken a little longer.  I like that part about "no skill required."  :)
Stooge Larry
Peter
2003-02-06 by echophazer <echophazer@aol.com>
course,
might
required."  :)
> Stooge Larry
This is another nice one:
http://www.precisionmeasure.com/tool9.htm
They cost anywhere between $50 to $90.
I kind of like this DIY optical center punch though:
http://www.nucleus.com/~harlan/punch.html
btw... the panels look great! Thank you.
Peter
