Overvoltage Protection, et al
2002-04-26 by mbedtom@aol.com
Shemp posed a couple of questions to which I will attempt a response:
Power line filters...  Power line filters are usually an integral part of the
power entry module on a power supply.  They serve two main functions: 1)
Power line filters help to oppose the entry of radio frequency energy that
might have some negative impact on the instrument operation.  2)  Power line
filters help to contain any generated radio frequency energy that might
"leak" out and interfere with the operation of other instruments in close
proximity.
Modular analog synthesizers don't generate a whole lot of radio frequency
energy.  But a synth is composed of many circuits connected in series that
amplify signals.  To achieve good fidelity, many of these circuits are quite
happy to amplify radio frequencies.  If unwanted radio signals enter through
the power cord (because it acts like an antenna), those signals can be
coupled into the various amplifiers used in a synth.  And anytime you have a
junction of dissimilar metals, you have formed a crude diode detector.  A
diode can demodulate AM radio signals, leaving the raw audio to blend into
your synth audio.  That isn't a good thing!  I can look out my den window and
see the antenna of a 5 kilowatt AM transmitter.  My telephone wiring
comprises a wonderful antenna for receiving this radio station.  Sometimes
this unwanted audio is so loud it drowns out the caller's audio.  Have you
guessed yet that there is a bad-ass filter on my synth's power supply?  You
might not live in as hostile an area as I do, but if you gig with your gear,
can you guarantee that you'll never be near a transmitter that can cause
interference?  A filter can be helpful.
Overvoltage protection...  This too, is a required item in my opinion.  The
basic operation of an overvoltage protection circuit is pretty
straightforward:  A small circuit sits between the +15 and -15 output rails
of the regulated supply.  The overvoltage protection circuit contains a
voltage sensor and a high-current "electric switch" (an SCR, actually).  When
the applied voltage rises above a preset level, the "electric switch" is
closed and shorts out the power supply output pins... on purpose!  The
rationale is this: if the voltage rises beyond the preset threshold,
something has gone disastrously wrong in the power supply itself.  This extra
voltage could easily damage the circuits connected to it.  So it shorts out
the power supply which will cause a heavy current to flow in both the primary
and secondary side.  In a moment or two, the fuse on the primary of the power
supply will blow as a consequence of this extra current draw.  When the fuse
pops, the supply goes dead and the possibility of damage to other circuits is
minimized.  (You don't use a larger fuse than you're supposed to... right!?)
The reason a synth power supply can produce a voltage dangerous enough to
damage circuits, is related to how the power supply regulates voltage in the
first place.  Most power supplies are rated to provide the specified output
voltage with as little as 105 volts AC input (in the United States).  In
order to regulate the output to +/- 15V, the input voltage to the regulator
circuit must be higher than the desired output by about 2 volts.  When the
input AC mains voltage is 105 volts, the input to the regulator circuit (on
either polarity) will be at least 17 volts (probably more).  But these
supplies are also required to deliver the same regulated voltage at 130 volts
on the AC mains.  That means the input voltage to the regulator circuit will
rise to over 21 volts (again, probably more).  The main power handling
component of the regulator is a pass-transistor.  If this pass transistor
were to develop a collector-to-emitter short, the full unregulated voltage
will be sent to the output.  Therein lies the problem.  A single component
failure (the pass-transistor) could cause your expensive synth modules to be
damaged.  (Or they can be stressed to the point that their expected life is
much shorter than if  they weren't stressed.)  It's one thing to zap a 60
cent opamp, but quite another to blowout a CEM chip like that used on the
MOTM-110.
Did that answer your question or did I just make your eyes glaze over?  (I do
that quite often it seems!)
Cheers!
Tom Farrand
[OT] EVOS & Studiomaster Studiofex
2002-04-26 by Tentochi
Does anyone know if any EVOS modules were ever produced and sold???
Does anyone on the list have any Studiomaster Studiofex modules? Does anyone have documentation for them?
Thanks!!!
Pmehs
Re: [motm] [OT] EVOS & Studiomaster Studiofex
2002-04-26 by Josue Arias
I have some of the studiofex LFOs/Envellope followers. I got a some of them for my modular system and I have the docs if you are interested.
Josue.
Sent: Friday, April 26, 2002 7:57 PM
Subject: [motm] [OT] EVOS & Studiomaster Studiofex
Thanks!!!
Pmehs
RE: [motm] [OT] EVOS & Studiomaster Studiofex
2002-04-26 by John Loffink
No, Evos never produced or sold any systems.  Too bad, they looked
promising.  I exchanged emails with the guy last year.  He was
predicting modules last summer.   I never saw a thing.
And we complain about Paul being slow!  I have this Evos guy's brochures
(very professionally done) from 1997, showing complete systems.
John Loffink
jloffink@...
Sent: Friday, April 26, 2002 3:24 PM
To: tentochi@...; motm@yahoogroups.com
Subject: Re: [motm] [OT] EVOS & Studiomaster Studiofex
Josue.
To: motm@yahoogroups.com
Thanks!!!
Pmehs
<http://docs.yahoo.com/info/terms/> .
