MOTM-450 Layout Winner
2002-04-18 by rogerpellegrini
In view of the obvious fact that my ideas are not shared by the majority, I take up the mantle of the irritant in the oyster that (hopes) to contribute to the pearl and dutifully point out the various peculiarities of the winning design: (1) Whereas the "band" knobs increase in cutoff frequency as one goes from the top to the bottom of the panel, the lowpass knob (presumably with the lowest cutoff freq) is at the bottom and the highpass knob is at the top! (2) The highpass knob's cutoff freq is close to that of band 8, but is diagonally across the panel from it (as far as you can get). (3) The lowpass knob's cutoff freq is close to that of band 1, but is a panel's height (far) away from it. In any case, as I'm not even a potential customer for this module, I'll shut up...I use the old Moog 907 (not the "A", but the original R.A. Moog filterbank) which has a horizontal layout over a vast expanse of wasted panel space! yippee Best regards, Roger
