The hosa stuff is *ok,* but it's not great. They cetainly have what
we're looking for, but the cable is not very thick, and the jacks and
plugs are mediocre. I'm fairly certain that Switchcraft makes inline
jacks. We could probably make a batch of these cables fairly
easily. If you guys are OK with "Horizon" cables, I know they do
custom orders all the time, we could make a batch of 2 fem - 1 male,
6" (or even less) cables.
The shortcoming here is that my recollection of the ends is that
they're pretty large, for the heavier gague stuff, but I do recall
one that's not much larger than the regular switchcraft plugs.
(I work for a Horizon dealer, so if you folks want, I can find out
what retail on those cables would be, but don't feel that I should
sell them to you. I feel it's a conflict of interests to bring my
personal life to work.)
--- In motm@y..., "J. Larry Hendry" <jlarryh@i...> wrote:
> You know, as crazy as this sounds.... It does lend itself to another
> interesting question for something almost like you are discussing.
What
> about when you have a voltage you want to take only 2 different
places? How
> many times do we use a 4-square jack mult for 1IN - 2OUT? Instead
of
> stringing a cable to the mult and then back from the mult to the two
> separate destinations, how about one of these two ideas:
> 1. Have a handful of portable mults. These would be a VERY
short "Y" cable
> with one male and 2 females (flexible, not stiff). You plug it to
> source, plug the two cables tight into it and take them directly
where they
> go. You reduce cable clutter by one cable and don't string out of
your way
> to get to a mult. You would not use these for mults with many
cables. But
> how many times are we just going 2 places. Even 3 would work.
Think of
> them as highly portable 3 jack mults.
> --or--
> 2 - have a cable that has an the "Y" at one end, so you can always
piggy
> back on a second cable.
> --or--
> 3. Keep quite a few cables in your system, that have one 1/4 plug
at one
> end with 2 cables coming out the same length to separate 1/4" plugs.
> anytime you knew you were going to 2 separate locations, just use
pick up a
> "dual" cable.
> The issue is reliable 1/4 female jacks that go onto cable if you do
1 or 2.
> I have never found really good ones.
> Stooge Larry
> From: sucrosemusic <sucrosemusic@y...>
> To: <motm@y...>
> Sent: Friday, February 01, 2002 10:20 PM
> Subject: [motm] Stackable 1/4" Plugs?
> The idea just came upon me. I remember a discussion about bananna
> plugs vs. 1/4", and i don't remember if the concept of stackable
1/4"
> plugs came in. Granted, they'd stick out like mad, but I'm certain
> it's feasable. Does anybody make these? They'd have to be a bit
> longer than the 1/4" plug itself on the outside, but you could make
> the cable come out of the side at a diag. fairly easily without
> mucking up your modular too much.
> Does anybody know where we could find these?
> Your use of Yahoo! Groups is subject to
