Just joined - guitar synths
2001-11-27 by Mark Smart
Hi all. I am a guitarist and engineer from Champaign, IL with an interest in analog and guitar synths. My main interest is in the old Roland GR-300 analog guitar synth which tracks faster than any other guitar synth out there. Over the past five years or so, I have gone through periods of interest and activity concerning this synth, figuring out why it works so well and designing circuits for interfacing it to external analog equipment and getting more sounds out of it. I worked on this a bit last year, when I bought my first (and so far only) MOTM module, an ADSR. The stuff has been sitting untouched for quite a while, but I'm starting to get excited about working on it again, especially in light of the appearance on the synthtech web site of CEM 3391 dynamic waveform processor chips, which can greatly aid in designing a hugely souped-up GR-300. Since building all the analog stuff, I have also figured out that the same scheme can be implemented quite a bit better using the Reaktor software synth (please, no boos from the diehard analog-heads!), but it is a processor hog and needs a computer. I still want to finish an analog version because I already have the thing partially built. Some of the interface circuits I have designed are as follows: 1. Log(1/x) converter to turn the GR-300's linear pitch (actually PERIOD) control voltages into 1 volt/octave CV's that other analog gear can use. I based this on a circuit from Electronotes and added temperature regulation with a heated 3046 (Paul HATES this, as I found out when I talked to him last year.). 2. Comparator with envelope-controlled threshold to turn GR-300's envelope follower outputs into triggers to fire an ADSR. The envelope helps with note retriggering without reducing sustain. 3. Circuit to turn the GR-300's weird sawtooth waves (whose amplitude is proportional to the period of the guitar string) into a pulse wave with the same duty cycle no matter what note you play. 4. Loudest-string-priority circuit to produce a monophonic output for diving an aanlog synth like my ARP Axxe. This one needs some work. Anyway, my idea now is to use the CEM chips to add separate filtering and envelopes to each string without building insane amounts of analog hardware. I am interested in hearing from other guitar synth experimenters out there. I've been somewhat secretive in the past about this stuff, but what the heck. Mark
