[motm] Driving a Miniwave - Was: I need a volunteer
2001-09-24 by George Kisslak
I don't have the Miniwave either (yet), but I bet driving it with a
MOTM-820/OMS-820 combo in LFO mode (to create a VC'd variable up/down saw
driver) would be very interesting.  I don't have the OMS-820 either, but I'm
gettin there.  :)
George
To: <motm@yahoogroups.com>
Sent: Monday, September 24, 2001 3:45 PM
Subject: [motm] I need a volunteer
> I have been tinkering around with ways to drive MiniWaves using PIC
> microcontrollers.  The thought I had was why tie up a perfectly good
> 300 or mini VCO when all you really need is a good steady sawtooth to
> do some basic driving.
> Then I had thoughts that it might be possible to produce PPG style
> timbre changes by doing some things to a basic sawtooth wave being
> used to drive the MiniWave.
> So I have some .wav files that have the proper output from this
> ?WaveDriver? module.  But I don?t have a MiniWave? Ok, I am a goof.
> Is there someone out there with a MiniWave that could play these sound
> files through enough of a Preamp to get them to the MiniWave drive
> voltage, and give me an idea if they are doing what I think they should?
> Thanks
> Bruce
