Re: [motm] Re: pre-amp
2001-09-22 by jwbarlow@aol.com
I look forward to buying, assembling, and using MOTM envelope followers and
pre-amps to connect my guitar (and other devices) to my MOTM (and other
analog gear).
I hope the economic fluctuations will settle down so that MOTM (and EM in
general) will return to prominence (at least in my life). BTW, I really like
John Blacet's idea of a Red Cross sale! It's rational actions in the face of
irrational circumstances, and compassion in the face of heartlessness where
humanity truly shines.
JB
PS, I finally was able to listen to the Rich CD -- I absolutely love it. I
will write some thoughts down and send them to you Paul so you can send them
on to RR if you feel so inclined.
2001-09-22 by J. Larry Hendry
You don't need a pre-amp to properly interface
line input with MOTM signal level.  10Vp-p is
around 14dBu.  If anything, you might need an
attenuator to bring the level down to MOTM levels.
--LH--
Mark,
I think what people mean is that they want in interface their instruments
directly to their MOTM without having to go through a mixer or other board
to bring it up to "line" or "motm" levels.  I think the term "line" level is
where the source of confusions seems to be.  As you know the term "line
level" can represent a significant range of officially - 10 to +4 dB
with -10 being much more common outside of professional studios.
The bottom line is that the output of most electronic instruments is -10dB.
People want to jump that up to MOTM levels and therefore are asking for a
pre-amp.  Certainly, it can work without the additonal gain.  But. the
signal to noise ratio is much better through the system if you start with a
signal of appropriate level.
--MM--
However, one use for a MOTM pre-amp would be to use it with
synthesizers and effects that produce a much lower output.
--LH--
Exactly.  I think many of us are guilty of calling our synth outputs "line"
level, because they often fall into that range.
Larry H
2001-09-23 by mark@indole.net
At 12:59 PM -0500 09/22/01, J. Larry Hendry wrote:
>Mark,
>>is where the source of confusions seems to be.  As you know the term "line
While the line between consumer and professional is blurring, I see your
point.  It's not like the early 80's when folks producing synth pop and
industrial in their bedrooms were stuck with these crappy mixers of asian
origin -- +4 is much more common in today's home studios.  Anyway, the
difference between -10 and +4 as a voltage standard has more to do with the
inputs.  You'll notice on most gear with selectable switches on the back
for each standard, that the switch has no effect on the outputs. +4 almost
always implies a balanced output.
Many unbalanced "-10dBu" synths and effects can produce outputs over
+13dBu, and most +4 gear can output +22dBu, or even +28dBu.
This is true.
>--MM--
>--LH-
Which leads to...
At 1:30 AM +0000 09/23/01, endiendi@... wrote:
>OK... my Oscar and my Memorymoog with the volume knob fully clockwise
>can hardly drive a motm 120......I used to consider these two machines
>>having a rather hot signal, what else should we add to this evidence?
My Mini Moog has two output jacks -- one high, and one low.  Perhaps the
Memory Moog has the same.  I have no idea about the OSCar.  Nor do I have a
120.  Yet based on what you are saying, the output of these synths isn't
that hot, so in your case, you could make use of a pre-amp.
Perhaps most of my concern has to do with marketing.  Although it literally
isn't my business, I still wouldn't want to see Paul lose money on a
module.   I haven't had any trouble using my 110 or 410 (with the added 68K
resistor) directly with consumer gear like the TB-303, TR-909, MAM VF-11,
Lexicon Vortex, or Korg Prophecy.  Correct me if I'm wrong, but couldn't
the 830 6*2 mixer be used as a "double pre-amp"??  What about the 130??
I am curious how a the Triple Pre-Amp fits onto 2U, and why it isn't a 1U
double pre-amp or a 2U quadruple pre-amp.  What features does it have??
Does Moe have a panel layout??  Maybe if I saw the thing, its usefulness
would be more apparent.
Re: pre-amp
2001-09-24 by Eric Frampton
I'm just asking this for the sake of Paul's (and others') limited
development time:
What's the possibility of asking a third-party manufacturer (Grace and Great
River come immediately to mind) about re-packaging one of their existing
products to fit the MOTM dimensions?
Eric
Eric Frampton, keyboards     Atlanta, Georgia, USA
web: http://www.ericframpton.com/
email: eric@...
2001-09-24 by Paul Schreiber
For what? A mic pre?
To: <motm@yahoogroups.com>
Sent: Monday, September 24, 2001 3:50 PM
Subject: [motm] Re: pre-amp
> development time:
Great
> Eric
> email: eric@...
