OMS-820 module
2001-09-24 by Tony Allgood
Hi all, I have put some preliminary information about the upcoming OMS-820 module. This is a companion module to the MOTM-820 VC lag module. More details are at the link below. But put simply, it will allow you to use your VC-lag as a flexible voltage controlled contour (envelope) generator and variable waveshape LFO. www.oakleysound.com/oms-820.htm Pictures of the prototype to follow. Regards, Tony
