[motm] Re: pre-amp
[motm] Re: pre-amp
2001-09-22 by nathan durham
I'm looking forward to the triple preamp.
My understanding is that the preamp will be 1 channel guitar input, 2
channels of line input, and gain to bring signals up to 10 volt
peak-to-peak to properly interface with MOTM signal level. We're not
talking about a mic preamp; the output of a mic preamp would go into the
line input of the triple preamp to be further boosted, and then maybe
used as a control voltage, or any kind of MODULAR craziness you want.
nathan
Re: pre-amp
2001-09-22 by endiendi@tin.it
I own a good mic preamp, still I'd prefer (if a preamp is in Paul's thoughts) that it has line, guitar and mic inputs. Maybe phantom would be a luxury item but a mic input would make the unit extremely versatile without external units to be connected and powered.
I would buy two of them right now.
Enrico
> nathan
Re: [motm] Re: pre-amp
2001-09-22 by mark@indole.net
I'm looking forward to having the patience to avoid this thread :)
You don't need a pre-amp to properly interface line input with MOTM signal
level.  10Vp-p is around 14dBu.  If anything, you might need an attenuator
to bring the level down to MOTM levels.
However, one use for a MOTM pre-amp would be to use it with synthesizers
and effects that produce a much lower output.
>We're not talking about a mic preamp; the output of a mic preamp would go
>>into the line input of the triple preamp to be further boosted, and then
>>maybe used as a control voltage, or any kind of MODULAR craziness you
>want.
Just for sake of argument, can you name a mic-pre or front-end that can't
produce 14dBu??  If you want to use audio as control voltage, then you
would use an envelope follower, pitch-to-CV converter, or some other device.
Re: pre-amp
2001-09-23 by endiendi@tin.it
OK... my Oscar and my Memorymoog with the volume knob fully clockwise can hardly drive a motm 120......
I used to consider these two machines having a rather hot signal, what else should we add to this evidence?
Enrico Italy
