RE: Gate Delay
2001-09-18 by mate_stubb@yahoo.com
>>>> Now, if you want to be able to set the delay time such that it is longer than the time between incoming gates, that looks like it's going be very difficult. It's an interesting problem and I'm going to look into it, but my intuition tells me that no matter how it's designed there is going to be a limit on the number of gates delayed (I'm thinking at least two flip-flops per gate). It might be easier to use some sort of PAL or uP, which is beyond my ability. <<<< In terms of traditional envelope generator-type gate delaying (which was the thrust of the initial conversation), you want to delay the incoming positive going transition (a timer, or just an RC/comparator arrangement). The incoming negative going transition is not delayed, but sends the envelope into final decay as always. There is typically no attempt to maintain the input gate's on state time. Moe
