Logic module (was: gate delays)
2001-09-18 by jhaible@t-online.de
> >> apart from the EFM boolean logic module, does anyone > know of any > other synth manufactuer who makes a similar thing (Emu > excepted) I'm not a synth manufacturer, but here's a little "VariLogic" circuit of mine: http://home.t-online.de/home/jhaible/hjvarlog.gif It can be switched to AND, OR, XOR, NAND, NOR and XNOR with one on/off/on switch and one on/on switch. A simple INV fuction is possible, too, as the inputs are normalized. Input A is normalized to "High", and you can connect a simple footswitch here to provide one of the input signals. The circuit works without a separate 5V supply, and it's quite sturdy when it comes to overvoltage, ESD and so on (no CMOS chips). LEDs for inputs and outputs, of course. JH.
