newbie
newbie
2001-05-09 by Bob
hi all,
I just thought I'd introduce myself.
I received my *first* (out of hopefully many) package of MOTM modules in the mail on Monday (power supply, envelope generator, and VCF) and am waiting for my soldering iron station to come in the mail so I can begin construction of these modules.
I'm stationed in glorious Arlington, VA, and decided to purchase some modules in order to gain more functionality to my Moog Opus-3 and Juno Alpha-1.
My band is making it's live debut performance in two weeks and I can't wait to assemble the modules, run them through my synths, and show everyone what these things can do.
-Bob
Re: [motm] newbie
2001-05-09 by J. Larry Hendry
> From: Bob <bob@...>
> hi all, I just thought I'd introduce myself.
Welcome to the list Bob.  It has been a little quiet lately, but this list
is full of a bunch of great guys.  Congratulations on your first MOTM
purchase.  You will be addicted just like the rest of us.  :)
Super.  One word or caution -- Don't rush your assembly.  Certainly, the
most common causes of non-working modules is very simple mistakes with
improperly placed components.  While Paul's instructions are VERY detailed,
this is an easy mistake to make (I speak from personal experience).  Seems
these things tend to be more likely if one is either in a hurry or overly
tired.
Good luck with your first MOTM modules.
Larry Hendry
Re: [motm] newbie
2001-05-09 by mark@indole.net
Good advice.
While I'm not done building this first batch of modules (I plan to buy the
second batch at the end of the Summer, after they come out), the only
problem I had was with the 410.  I sent it back to Paul S. for repair.  He
couldn't find anything wrong with it, and sent it back.  The turnaround was
very quick.  As it turns out it was merely homesick, Paul took it out for a
night of longnecks and line-dancing, and now it works fine :)  Actually, it
turns out it was the power supply.  I erroneously assumed it was the 410
because it was my only audio module.
Anyway, here's some advice for new builders like ourselves:
1) Follow the directions, and sort out your parts before you begin
assembly.  Go through the checklist, and check off each and every part.  I
can't stress this enough. I use egg cartons and a magic marker to sort
resistors.
2) If you haven't already, memorize the color codes.
3) Resistor color codes are not painted on by interior decorators who think
"eggshell" and "coconut" are two distinct colors.  Brown can often look
like red or orange, and vice versa.  If you have any doubt, use a DVM.
4) Get a magnifying glass to read IC's and capacitors.
5) Double check your IC's before soldering.  Switching around a cap or
diode is one thing, but unsoldering an IC is a royal pain.
6) Don't assume the red wires attach to #2, because red is two, and right
is red, which is channel two.  As counterintuitive as that might be, take a
few deep breaths and force your brain to solder the wires in the right
place.
7) Use a device to hold the PCB.  A Panavise is excellent, but expensive. I
was going to buy one, but if you get the "helping hands" from Radio Shack
($10) and remove the alligator clips, it will hold a PCB just fine if you
put a pieces of cardboard under each screw.
8) Use decent hand tools.  Read the advice at the website.  The
instructions recommend using dikes, however I recommend a pair of miniature
angled "end cutters" for clipping the leads off the PCB.  They're about $25.
9) I recommend using a plastic driver to attach the pot nuts so that you
cannot scratch the panel.  I use the large handle that slips over a set of
miniature nut drivers -- these sets are often inexpensive.
10) You can buy whatever drivers you need from Sears or an auto-parts
store.  You don't need a whole set -- just these sizes: 5/16" nut driver, a
5/16" open end wrench (if any of your kits use switches), a 1/2" deep
socket for the pots, and an 1/8" hex (allen) key for the knobs.  Do not use
an adjustable wrench -- adjustable wrenches are for plumbers, who have to
deal with a variety of corroded and encrusted fasteners.  Whatever you do,
do not use pliers to tighten the nuts -- you might as well use a hammer.
11) Clear your work area.  Put away any tools you are not using.  Put away
any other diy projects.  Get organized.
12) Please, take your time.  Larry has a MOTM system that looks like half
the World Trade Center at night.  If he can afford to take his time, you
can too.
If you need any more advice, folks around here are just full of it :)
Re: [motm] newbie
2001-05-09 by George Kisslak
Hi Bob - welcome to MOTM madness!
Be careful, as this usually starts slow, but then begins to take on a life
of it's own as it wipes out your bank account. ;-)
Part of the enjoyment, I believe, comes from actually building the modules.
If you take your time and follow Paul's excellent directions, you will be
rewarded.  Hopefully you picked up a nice 700 degree temp-controlled iron -
it's the single most important tool to own.
Good luck with your debut!  There are others among us that also use our MOTM
in the pursuit of better music.  (Sometimes it works, sometimes not, but
it's always interesting!)
Cheers,
George Kisslak
To: <motm@yahoogroups.com>
Sent: Wednesday, May 09, 2001 1:06 AM
Subject: [motm] newbie
hi all,
Alpha-1.
-Bob
