Index last updated: 2026-04-28 23:27 UTC
parameter map/chart
parameter map/chart
2008-11-20 by David Mochen
Hi Mike,
I don't intend to get a definitive response to this, given the present state of development in the Hawk project, but I was wondering if it would be possible to create some layout for all the parameters of the Hawk 800 so that we could make a stenciled faceplate and glue it over the existing onenon the poly's right panel over the keyboard, for a quick reference... does the number of parameters make it look like a feasible task? we could get it properly designed for maximum readability...
thanks
dave
Sent: Thursday, November 20, 2008 3:36 PM
Subject: [korgpolyex] Sustain pedal
Hi Poly fans,
This new feature is one coming from out of the blue.
I have implemented a sustain pedal function. The original pedal jack is for incrementing the patch numbers. That is something that I NEVER used.
So I've implemented a new global parameter (17) that allows you to make the pedal jack into a sustain pedal.
At the moment, it only holds the notes at the sustain level. When you release the pedal the notes that you have let go are then released. The pedal is basically "holding" the notes.
Now I am going to try to implement a second sustain pedal mode that will not only hold the notes at sustain point but will also change the decay of the EG's. I will be trying to add an extended parameter that allows setting the decay offset for the sustain pedal. This offset would be added to the set decay. And then another mode will add the offset to the release too (maybe we need a second extended parameter to determine the release offset).
I'll let you all know how that works out.
Mike.
To: "korgpolyex@yahoogroups.com" ups.com>
Sent: Tuesday, November 18, 2008 10:38:41 AM
Subject: Re: [korgpolyex] AtomaHawk preorders!
I will be ordering both kits at the same time :)
On Nov 17, 2008, at 8:41 AM, "korgpolyex800" <korgpolyex800@ yahoo.com> wrote:
I am now ordering parts for the AtomaHawk kit.
But before I do, I would like to get an idea of...
How many of you would be about to order the HAWK-800 along with the
AtomaHawk when I announce the AtomaHawk is ready?
And how many of you that already have the HAWK-800 will be ordering
the AtomaHawk?
Mike
Re: [korgpolyex] parameter map/chart
2008-11-20 by Michael Hawkins
You know I have given some thought to this.
But I have no idea where to start looking to get something done like that.
Any suggestions?
Mike.
Sent: Thursday, November 20, 2008 3:35:06 PM
Subject: [korgpolyex] parameter map/chart
Hi Mike,
could get it properly designed for maximum readability. ..
thanks
dave
To: korgpolyex@yahoogro ups.com
Hi Poly fans,
Mike.
 From: "electrohead2000@ yahoo.com"  <electrohead2000@ yahoo.com>
To: "korgpolyex@ yahoogroups. com"  <korgpolyex@yahoogro ups.com>
the  AtomaHawk?
Mike
2008-11-20 by Alex Drinkwater
I think, with all the extra parameters, the text would have to be
pretty small. Having said that, there's a similar parameter matrix
printed on the front of the EX-8000, and that's perfectly readable,
and quite handy. I must admit, I do find myself reaching for the Hawk
manual quite a lot...
a|x
On 20 Nov 2008, at 20:35, David Mochen wrote:
> Hi Mike,
> thanks
> dave
> From: Michael Hawkins
> Hi Poly fans,
> NEVER used.
> Mike.
> From: "electrohead2000@..." <electrohead2000@...>
> To: "korgpolyex@yahoogroups.com" <korgpolyex@yahoogroups.com>
>> the AtomaHawk?
>> Mike
2008-11-20 by Atom Smasher
here's and old cheat-sheet i made, to help me get my head around the
matrix synth -
 	http://suspicious.org/~atom/m6/
 	http://suspicious.org/~atom/m6/m6block.pdf
i would think something of similar style could be used to make the
hawk-800 easier to grok.
> that.
> Any suggestions?
> From: David Mochen <davidmochen@...>
> readability. ..
         ...atom
  http://atom.smasher.org/
 	"We in the West must bear in mind that the poor countries
 	 are poor primarily because we have exploited them through
 	 political or economic colonialism."
 		-- Martin Luther King, Jr
As far as myself, I'm planning to give my Poly (once the Hawk and aTomaHawk mods are installed) a full make-up, having been already subject to various degrees of abuse (I actually painted the keys with a spray gun back in the day, so I had to sand-paper them, which gave them a horrible gritty look!). Im thinking of having it professionally painted in silver color, maybe the black keys in iridiscent black or dark blue, and other parts of it as well, so a brand-new parameter chart would give it a final sweet coating... :)
I'm also planning to keep the existing knobs from the original Atom mods, and of course, the VCF input.
dave
Sent: Thursday, November 20, 2008 6:03 PM
Subject: Re: [korgpolyex] parameter map/chart
Any suggestions?
Mike.
Hi Mike,
I don't intend to get a definitive response to this, given the present state of development in the Hawk project, but I was wondering if it would be possible to create some layout for all the parameters of the Hawk 800 so that we could make a stenciled faceplate and glue it over the existing onenon the poly's right panel over the keyboard, for a quick reference... does the number of parameters make it look like a feasible task? we could get it properly designed for maximum readability. .
thanks
dave
Hi Poly fans,
Mike.
To: "korgpolyex@ yahoogroups. com" ups.com>
the AtomaHawk?
Mike
