Emax
Emax HD eprom
Emax HD eprom
2013-02-02 by Gary
Has anyone dumped the eprom codes for a 2764 eprom for an emax hd?
Re: [emax] Emax HD eprom
2013-02-02 by Ted Summers
The Emax EPROM with HD support is easily copy-able.
Many Emaxes may have an EPROM that has the support in it already.
But that doesn't give you SCSI capability- The TIM PAL (locking chip) does when used in combination with the OS and of course having the SCSI controller.
Let me know if you want a SCSI chipset kit.
They are $60 USD.
Ted
ps- I take paypal�
paypal to:  djtbs1@...
Installing OLED screen in Emax II keyboard.
2013-02-09 by Daniel Baum
Hi all,
I am installing the OLED discplay in my Emax II keyboard.
I have watched Ted's video, which explains the process on the Emax I.
My Emax II has a large memory expansion board over the main board. Do I need to remove this separately or can it come out as one unit with the logic board?
Are there any other differences between the Emax I and Emax II that I should know about?
Tks,
Daniel
Re: [emax] Installing OLED screen in Emax II keyboard.
2013-02-09 by jammie
its the same screen board but you need to remove the the keyboard the mainboard and the ram board to get to the screen board
under neath you need to add some srews and nuts to hold the lcd screen in place as the pins for the efoil are removed so that the screen is only fixed one side
  To: emax@yahoogroups.com
  Sent: Saturday, February 09, 2013 8:29 AM
  Subject: [emax] Installing OLED screen in Emax II keyboard.
  Hi all,
  Tks,
  Daniel
Thanks.
RAM board and main board are out. Now removing keyboard.
It's worse than dismantling a Mac...
D.
> From: Daniel Baum
> Hi all,
> Tks,
> Daniel
Hi Jammie,
My display already had screws and nuts. Guess I was lucky :)
D.
On Feb 9, 2013, at 11:05 AM, Daniel Baum <daniel@...> wrote:
> Thanks.
> D.
>> From: Daniel Baum
>> Hi all,
>> Tks,
>> Daniel
> Emax and Emax II User's Group Website
> http://www.silveriafamily.comYahoo! Groups Links
It's all back together and working beautifully.
Thanks Ted for all his efforts, and to Jammie for the help.
D.
On Feb 9, 2013, at 11:35 AM, Daniel Baum <daniel@...> wrote:
> Hi Jammie,
> D.
> On Feb 9, 2013, at 11:05 AM, Daniel Baum daniel@...> wrote:
> > Thanks.
> > D.
> >> From: Daniel Baum
> >> Hi all,
> >> Tks,
> >> Daniel
Here are some pics from the screen replacement. I took most of them so I would know how to get it back together again, plus a couple for posterity:
https://picasaweb.google.com/108602450026684563488/EmaxIIScreenReplacement?authuser=0&feat=directlink
D.
> D.
> On Feb 9, 2013, at 11:35 AM, Daniel Baum <daniel@type34.info> wrote:
>> Hi Jammie,
>> D.
>>> Thanks.
>>> D.
>>>> From: Daniel Baum
>>>> Hi all,
>>>> Tks,
>>>> Daniel
2013-02-09 by Carl Lofgren
VERY nice :)
/C
>________________________________
> From: Daniel Baum <daniel@...>
>Sent: Saturday, February 9, 2013 1:07 PM
>Subject: Re: [emax] Installing OLED screen in Emax II keyboard.
>D.
>> D.
>> On Feb 9, 2013, at 11:35 AM, Daniel Baum daniel@...> wrote:
>>> Hi Jammie,
>>> D.
>>>> Thanks.
>>>> D.
>>>> On Feb 9, 2013, at 10:50 AM, "jammie" jammie.emma@blueyonder.co.uk> wrote:
>>>>> From: Daniel Baum
>>>>> Hi all,
>>>>> Tks,
>>>>> Daniel
