Emax
Five top keys fault
Five top keys fault
2012-07-08 by jaumemod
Dear folks,
My Emax II top 5 range keys faults (from G#5 to C6) no sounds.
Playing on MIDI master keyboard there's no problem, all seems to be ok, all sounds.
I checked contact springs and seems to be ok. Only when I use a plastic stick to move spring over contact with a key previously played all sounds...until I back to turn sampler in upright position.
I cleaned all contact springs and contact base. I checked keyrange board and all contact ways on board. All seemed to de ok for me.
I checked all keyrange connectors to mother board: Ok
Maybe I need to know what parts of sampler are involved in keyrange operation to checked something else....I don't know....
Re: [emax] Five top keys fault
2012-07-08 by jammie
bad signal diode can take out all keys in that octave
as seeing your getting midi to trigger
the scanner cpu deals with the keyboard and  the buttons
youcould have a bad scanner chip
but check the contact board starting at the c#5 key trace the diode
for that key and test if its working
  To: emax@yahoogroups.com
  Sent: Sunday, July 08, 2012 10:14 PM
  Subject: [emax] Five top keys fault
  Dear folks,
Re: Five top keys fault
2012-07-09 by jaumemod
I just to check the diodes with tester and all 5 give right .
Where's the scanner cpu? ID number?
>   ----- Original Message -----
>   From: jaumemod
>   Dear folks,
2012-07-09 by emax_dx5
I won't go for the MPU Scanner (IM386). When it fails, no button or key usually work.
You said you sent midi to the Emax and it made sound. Did you check the MIDI OUT commands the emax is sending? you can do it both with a Midi analyzer on your computer or using the function MIDI Scope. Check if it sends Key ON and OFF commands or not. If any of those cases:
Go to the keyboard Printed Circuit Board. ONce you already checked diodes, Check continuity on the traces involved with those keys (a multimeter will do the job). If a common ground trace is open, this fault uses to happen.
hope it helps.
Best.
Jose
Re: [emax] Re: Five top keys fault
2012-07-09 by jammie
actually i can be the scanner chip iv had it when you can play notes on kewyboard but when pressing buttons its arratic and jumps allover the place
  Sent: Monday, July 09, 2012 2:59 PM
  Subject: [emax] Re: Five top keys fault
  hope it helps.
  Best.
  Jose
Yeah I don't discard it at all, but three 1125's I had to deal with were completely dead when failing. Talking about a failing octave (just that) I would go for traces or diodes (appart from all suggested above). Those keyb pcbs are prone to crack traces .
>   From: emax_dx5
>   hope it helps.
>   Best.
>   Jose
i agree i recon its a diode or the return circuit to the scanner cpu
the scanner cpu gets pulse signals from when a key is pressed0volts to 5volts to zero volts like a half square wave cycle
he says he is getting voltage across the diode 5v when key is pressed
so to me the keys is making a circuit as tested but that siganl is not getting back to the cpu scanner
now its either the wire for that octave is damaged or there is a broken track
he needs to trace the tracks from that octave and see if he is getting continuity to the header cable if he is then its at the mother board end
as the scanner cpu is not recieving the trigger pulses for that octave
  Sent: Monday, July 09, 2012 6:09 PM
  > From: emax_dx5
  > hope it helps.
  > Best.
  > Jose
The maneuver I performed for it working again was to raise the contact spring with a nylon stick while pressing one of five keys on the MIDI master keyboard. Then everything was returning to work.
This must create a bridge between contacts or something similar
Ouuuuk! For the moment I traced the contact ways to contact key and I find a bad solder point....perhaps it's the cause which when I turn upright sampler all faults again.
Tomorrow I ll put a bit solder....I'll tell you something...
THX a lot
>   From: emax_dx5
>   > From: emax_dx5
>   > To: emax@...m
>   > hope it helps.
>   > Best.
>   > Jose
yes a cold solder joint will do it as they are done in banks if one goes the whole octave will go
if it was just one key then i would of said dirt on the spring contact or the spring has snpped or fallen ot which also does happen
  Sent: Monday, July 09, 2012 11:14 PM
  THX a lot
  > From: emax_dx5
  > > From: emax_dx5
  > > hope it helps.
  > > Best.
  > > Jose
The bad solder point corresponds to G#5... I'll tell you something...
>   From: jaumemod
>   THX a lot
>   > From: emax_dx5
>   > > From: emax_dx5
>   > > hope it helps.
>   > > Best.
>   > > Jose
2012-07-10 by jaumemod
REPAIRED!
I was the bad solder point at G#5 contact board.
Thx a lot Jose and Jammie.
> >   From: jaumemod
> >   THX a lot
> >   > From: emax_dx5
> >   > > From: emax_dx5
> >   > > hope it helps.
> >   > > Best.
> >   > > Jose
2012-07-10 by jammie
pleasure to be of help thats what we are here for to keep these machines running as emu is not interested as of  93 for the emax as they only have to support a product after 6 years they can stop providing support and parts
this is the same for all manufacturers
but roland seem to keep a good stock always as for korg after 6 years your out of luck with parts as they just drop them unless its a part thats re used like the jalco phone sockets which are still the same since the korg dss1
  Sent: Tuesday, July 10, 2012 1:14 PM
  REPAIRED!
  > > From: jaumemod
  > > THX a lot
  > > > From: emax_dx5
  > > > > From: emax_dx5
  > > > > hope it helps.
  > > > > Best.
  > > > > Jose
Yeah...I ask myself suddendly what I will do when a motherboard or some chip faults.
You can re-sold a bad solder point, you can change a contact spring (MicroKorg springs are very similar)....But boards tings and chips...bad...bad repair...Prayer to God!
Maybe mod my ESI inside an Emax II lolollol
>   From: jaumemod
>   REPAIRED!
>   > > From: jaumemod
>   > > THX a lot
>   > > > From: emax_dx5
>   > > > > From: emax_dx5
>   > > > > hope it helps.
>   > > > > Best.
>   > > > > Jose
at least we can get replacement scanner cpu for the emax1/2/e3
but the scanner cpu for the ensoniqs which use the same chip but flashed with a different os as its only used for the buttons and controling functions of the vfd display and not the keyboard scanning as ensoniqs use there own scanner chip for that
are not available and a lot of esq1 and sq80 synths have hit the synth graveyard becuase of this im trying to rectify this as im  building an fpga replacement
and might do the same for the emax
  Sent: Tuesday, July 10, 2012 2:10 PM
  > From: jaumemod
  > REPAIRED!
  > > > From: jaumemod
  > > > THX a lot
  > > > > From: emax_dx5
  > > > > > From: emax_dx5
  > > > > > hope it helps.
  > > > > > Best.
  > > > > > Jose
2012-07-17 by cheju_99
i have exactly the same problem, replace the scan chip with a new one with no success, you finally fixed?.
>   From: emax_dx5
>   hope it helps.
>   Best.
>   Jose
2012-07-17 by jammie
check for dry joints on the key contact board and the first diode for that octave
  Sent: Tuesday, July 17, 2012 12:55 PM
  > From: emax_dx5
  > hope it helps.
  > Best.
  > Jose
2012-07-17 by jaumemod
You must read all post, but i recommend you check all solder points in key range board.
Test all contacts wires with tester (polimeter) and diodes of keys overall since the key wich faults to end
> >   From: emax_dx5
> >   hope it helps.
> >   Best.
> >   Jose
