Emax
Emax 1 storage options
2012-07-02 by John
There is an emax on ebay I'm interested in. It looks like a series 1 with
serial 133.
Question: Are there any higher density data storage options other than the
floppy? There is no scsi connection on the back.
I have a mac SE30 and the connection cable somewhere that connects the emax via
the serial port. But I only have sound designer universal.
So what is possible folks? I sincerely appreciate feedback.
Also is it possible to start a serial number database here where know serial
numbers and history on the unit could be archived? Kinda like car fax for
emaxes/emulators.
Thank you!
John B
http://www.ebay.com/itm/E-MU-Systems-EMAX-Digital-Sampling-Keyboard-first-versio\
n-/120942521769?pt=LH_DefaultDomain_0&hash=item1c28bc6da9#ht_500wt_988
Re: [emax] Emax 1 storage options
2012-07-02 by Ted Summers
Unfortunately, Serial # and model # do not allow one to determine if SCSI
can be added to the unit.
Only looking at the PCB will help with that.
Ask the seller for a pic of the PCB # (for example PCB327 or PC333).
See here:
http://djtbs1.wordpress.com/2010/10/04/scsi-kit-images/#jp-carousel-57
http://djtbs1.wordpress.com/2010/10/04/scsi-kit-images/#jp-carousel-58
Once you have that info, you would know if you can add a PC Card / media
drive to it.
See here:
http://djtbs1.wordpress.com/2010/10/04/some-install-related-pics/#jp-carousel-128
Ted
> serial 133.
> emax via
> serial
> emaxes/emulators.
> Thank you!
> John B
> n-/120942521769?pt=LH_DefaultDomain_0&hash=item1c28bc6da9#ht_500wt_988<http://www.ebay.com/itm/E-MU-Systems-EMAX-Digital-Sampling-Keyboard-first-version-/120942521769?pt=LH_DefaultDomain_0&hash=item1c28bc6da9#ht_500wt_988>
