Emax Zip Drive
2010-02-26 by leavesstillgreen
So, my miniscribe hard drive broken in my Emax. I'd like to replace it with an external zip drive. Can I just buy any SCSI zip drive off ebay and hook it up? I haven't found any good instructions for this yet.
2010-02-27 by Ing. Andrés Cortez Acereto
Hi, I have an E-MU EMAX II mod. 2212, and I have like a year using anSCSI IOMEGA 100MB, Mod. Z100S.
http://cgi.ebay.com/Iomega-ZIP100-External-Drive-SCSI_W0QQitemZ220560194293QQcmdZViewItemQQptZPCC_Drives_Storage_Internal?hash=item335a697af5
http://www.amazon.com/Iomega-Z100SI-100MB-Drive-Z100S/dp/B00078V7BQ/ref=sr_1_24?ie=UTF8&s=electronics&qid=1267237938&sr=1-24
http://www.sonicstate.com/synth/_inc/picview.cfm?synthid=262
I hope this will help.
Andres.
De: leavesstillgreen <errorspending@...>
Para: emax@yahoogroups.com
Enviado: viernes, 26 de febrero, 2010 15:50:26
Asunto: [emax] Emax Zip Drive
Encuentra las mejores recetas en Yahoo! Cocina.
http://mx.mujer.yahoo.com/cocina/
[Non-text portions of this message have been removed]2010-02-27 by Dave Sotnick
With the Emax I you must use a ZIP drive that can be set to SCSI ID 0. All external ZIP drives I have come across can only be set to SCSI ID 5 or 6. While Compact Flash (CF) is a better option, if you're going to use ZIP drives, you'll need an INTERNAL SCSI ZIP drive, since they have jumpers that you can set to any SCSI ID (all jumpers off/open sets the drive to the required ID 0). Hope that helps, Dave On Fri, Feb 26, 2010 at 3:50 PM, leavesstillgreen <errorspending@...>wrote: > > > So, my miniscribe hard drive broken in my Emax. I'd like to replace it with > an external zip drive. > Can I just buy any SCSI zip drive off ebay and hook it up? > > I haven't found any good instructions for this yet. > > > [Non-text portions of this message have been removed]
2010-02-27 by jammie
get a zip100 scsi plus drive
To: emax@yahoogroups.com
Sent: Friday, February 26, 2010 11:50 PM
Subject: [emax] Emax Zip Drive
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.5.435 / Virus Database: 271.1.1/2711 - Release Date: 02/26/10 07:34:00
[Non-text portions of this message have been removed]2010-02-27 by RJ Kaufman
Why is compact flash the better option and which drive can you recommend?
On Feb 26, 2010, at 9:24 PM, Dave Sotnick <sotnickd@...> wrote: > With the Emax I you must use a ZIP drive that can be set to SCSI ID > 0. All > external ZIP drives I have come across can only be set to SCSI ID 5 > or 6. > > While Compact Flash (CF) is a better option, if you're going to use > ZIP > drives, you'll need an INTERNAL SCSI ZIP drive, since they have > jumpers that > you can set to any SCSI ID (all jumpers off/open sets the drive to the > required ID 0). > > Hope that helps, > Dave > > On Fri, Feb 26, 2010 at 3:50 PM, leavesstillgreen > <errorspending@...>wrote: > >> >> >> So, my miniscribe hard drive broken in my Emax. I'd like to replace >> it with >> an external zip drive. >> Can I just buy any SCSI zip drive off ebay and hook it up? >> >> I haven't found any good instructions for this yet. >> >> >> > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Emax and Emax II User's Group Website > > http://www.silveriafamily.comYahoo! Groups Links > > >
that if you want to boot from a zip but if you boot from floppy then you can use any of the 5 or 6 scsi id
----- Original Message ----- From: "Dave Sotnick" <sotnickd@...> To: <emax@yahoogroups.com> Sent: Saturday, February 27, 2010 5:24 AM Subject: Re: [emax] Emax Zip Drive > With the Emax I you must use a ZIP drive that can be set to SCSI ID 0. All > external ZIP drives I have come across can only be set to SCSI ID 5 or 6. > > While Compact Flash (CF) is a better option, if you're going to use ZIP > drives, you'll need an INTERNAL SCSI ZIP drive, since they have jumpers > that > you can set to any SCSI ID (all jumpers off/open sets the drive to the > required ID 0). > > Hope that helps, > Dave > > On Fri, Feb 26, 2010 at 3:50 PM, leavesstillgreen > <errorspending@...>wrote: > >> >> >> So, my miniscribe hard drive broken in my Emax. I'd like to replace it >> with >> an external zip drive. >> Can I just buy any SCSI zip drive off ebay and hook it up? >> >> I haven't found any good instructions for this yet. >> >> >> > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Emax and Emax II User's Group Website > > http://www.silveriafamily.comYahoo! Groups Links > > > -------------------------------------------------------------------------------- No virus found in this incoming message. Checked by AVG - www.avg.com Version: 8.5.435 / Virus Database: 271.1.1/2711 - Release Date: 02/26/10 07:34:00
2010-02-27 by el macaco
yeah, but IIRC, if you boot from floppy then the emax will access the OS from the floppy from then on, and that is slooooow compared to the HD / Zip or Compact Flash. I'd say Compact Flash is the best option, no moving parts, zips fail all the time on people, and CF is fast and silent. To: emax@yahoogroups.com
From: jammie.emma@... Date: Sat, 27 Feb 2010 06:30:01 +0000 Subject: Re: [emax] Emax Zip Drive that if you want to boot from a zip but if you boot from floppy then you can use any of the 5 or 6 scsi id ----- Original Message ----- From: "Dave Sotnick" <sotnickd@...> To: <emax@yahoogroups.com> Sent: Saturday, February 27, 2010 5:24 AM Subject: Re: [emax] Emax Zip Drive > With the Emax I you must use a ZIP drive that can be set to SCSI ID 0. All > external ZIP drives I have come across can only be set to SCSI ID 5 or 6. > > While Compact Flash (CF) is a better option, if you're going to use ZIP > drives, you'll need an INTERNAL SCSI ZIP drive, since they have jumpers > that > you can set to any SCSI ID (all jumpers off/open sets the drive to the > required ID 0). > > Hope that helps, > Dave > > On Fri, Feb 26, 2010 at 3:50 PM, leavesstillgreen > <errorspending@...>wrote: > >> >> >> So, my miniscribe hard drive broken in my Emax. I'd like to replace it >> with >> an external zip drive. >> Can I just buy any SCSI zip drive off ebay and hook it up? >> >> I haven't found any good instructions for this yet. >> >> >> > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Emax and Emax II User's Group Website > > http://www.silveriafamily.comYahoo! Groups Links > > > ---------------------------------------------------------- No virus found in this incoming message. Checked by AVG - www.avg.com Version: 8.5.435 / Virus Database: 271.1.1/2711 - Release Date: 02/26/10 07:34:00 _________________________________________________________________ Hotmail: Trusted email with powerful SPAM protection. http://clk.atdmt.com/GBL/go/201469227/direct/01/ [Non-text portions of this message have been removed]
2010-03-01 by RJ Kaufman
So what's a cheap good cf drive you can recommend. Are the flash cards as cheap as zip disks?
2010-03-01 by jammie
there is no cheap cf drives doing it your self is the cheapest option buy an acard 720u scsi to ide adapter and a ide to cf adapter 32mb cf cards are £3-5 so yes they are as cheap as zip disks plus get a slimfloppy from ted as its easier to format the cf this way
Sent: Monday, March 01, 2010 12:34 AM
> 0. All
> or 6.
> ZIP
> jumpers that
> required ID 0).
> Hope that helps,
> Dave
>> it with
Version: 8.5.435 / Virus Database: 271.1.1/2714 - Release Date: 02/28/10 07:34:00
[Non-text portions of this message have been removed]2010-03-01 by RJ
Hmm that seems like a lot to buy...sounds like the internal zip drive is a lot easier. If i buy an internal scsi zip drive I can just plug it right in, right? On Mon, Mar 1, 2010 at 5:41 AM, jammie <jammie.emma@blueyonder.co.uk> wrote: > > > there is no cheap cf drives doing it your self is the cheapest option buy > an acard 720u scsi to ide adapter > > and a ide to cf adapter 32mb cf cards are �3-5 so yes they are as cheap as > zip disks > > plus get a slimfloppy from ted as its easier to format the cf this way > > ----- Original Message ----- > From: RJ Kaufman > To: emax@yahoogroups.com <emax%40yahoogroups.com> > Sent: Monday, March 01, 2010 12:34 AM > Subject: Re: [emax] Emax Zip Drive > > So what's a cheap good cf drive you can recommend. Are the flash cards > as cheap as zip disks? > > On Feb 26, 2010, at 9:24 PM, Dave Sotnick <sotnickd@...<sotnickd%40gmail.com>> > wrote: > > > With the Emax I you must use a ZIP drive that can be set to SCSI ID > > 0. All > > external ZIP drives I have come across can only be set to SCSI ID 5 > > or 6. > > > > While Compact Flash (CF) is a better option, if you're going to use > > ZIP > > drives, you'll need an INTERNAL SCSI ZIP drive, since they have > > jumpers that > > you can set to any SCSI ID (all jumpers off/open sets the drive to the > > required ID 0). > > > > Hope that helps, > > Dave > > > > On Fri, Feb 26, 2010 at 3:50 PM, leavesstillgreen > > <errorspending@... <errorspending%40gmail.com>>wrote: > > > >> > >> > >> So, my miniscribe hard drive broken in my Emax. I'd like to replace > >> it with > >> an external zip drive. > >> Can I just buy any SCSI zip drive off ebay and hook it up? > >> > >> I haven't found any good instructions for this yet. > >> > >> > >> > > > > > > [Non-text portions of this message have been removed] > > > > > > > > ------------------------------------ > > > > Emax and Emax II User's Group Website > > > > http://www.silveriafamily.comYahoo! Groups Links > > > > > > > > ---------------------------------------------------------- > > No virus found in this incoming message. > Checked by AVG - www.avg.com > Version: 8.5.435 / Virus Database: 271.1.1/2714 - Release Date: 02/28/10 > 07:34:00 > > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed]
2010-03-01 by RJ
So if I bought something like this http://cgi.ebay.com/Apple-Iomega-SCSI-Zip-100-MB-Internal-Drive_W0QQitemZ330405695312QQcmdZViewItemQQptZPCC_Drives_Storage_Internal?hash=item4cedb6cf50 Would i be able to just plug it into Emax SE HD and use it? On Mon, Mar 1, 2010 at 5:41 AM, jammie <jammie.emma@...> wrote: > > > there is no cheap cf drives doing it your self is the cheapest option buy > an acard 720u scsi to ide adapter > > and a ide to cf adapter 32mb cf cards are �3-5 so yes they are as cheap as > zip disks > > plus get a slimfloppy from ted as its easier to format the cf this way > > ----- Original Message ----- > From: RJ Kaufman > To: emax@yahoogroups.com <emax%40yahoogroups.com> > Sent: Monday, March 01, 2010 12:34 AM > Subject: Re: [emax] Emax Zip Drive > > So what's a cheap good cf drive you can recommend. Are the flash cards > as cheap as zip disks? > > On Feb 26, 2010, at 9:24 PM, Dave Sotnick <sotnickd@...<sotnickd%40gmail.com>> > wrote: > > > With the Emax I you must use a ZIP drive that can be set to SCSI ID > > 0. All > > external ZIP drives I have come across can only be set to SCSI ID 5 > > or 6. > > > > While Compact Flash (CF) is a better option, if you're going to use > > ZIP > > drives, you'll need an INTERNAL SCSI ZIP drive, since they have > > jumpers that > > you can set to any SCSI ID (all jumpers off/open sets the drive to the > > required ID 0). > > > > Hope that helps, > > Dave > > > > On Fri, Feb 26, 2010 at 3:50 PM, leavesstillgreen > > <errorspending@... <errorspending%40gmail.com>>wrote: > > > >> > >> > >> So, my miniscribe hard drive broken in my Emax. I'd like to replace > >> it with > >> an external zip drive. > >> Can I just buy any SCSI zip drive off ebay and hook it up? > >> > >> I haven't found any good instructions for this yet. > >> > >> > >> > > > > > > [Non-text portions of this message have been removed] > > > > > > > > ------------------------------------ > > > > Emax and Emax II User's Group Website > > > > http://www.silveriafamily.comYahoo! Groups Links > > > > > > > > ---------------------------------------------------------- > > No virus found in this incoming message. > Checked by AVG - www.avg.com > Version: 8.5.435 / Virus Database: 271.1.1/2714 - Release Date: 02/28/10 > 07:34:00 > > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed]
2010-03-01 by Dave Sotnick
Yes, that would work -- and as long as it is SCSI ID#0 you will be able to boot to it without requiring a floppy. -Dave On Mon, Mar 1, 2010 at 12:51 PM, RJ <errorspending@...> wrote: > So if I bought something like this > > http://cgi.ebay.com/Apple-Iomega-SCSI-Zip-100-MB-Internal-Drive_W0QQitemZ330405695312QQcmdZViewItemQQptZPCC_Drives_Storage_Internal?hash=item4cedb6cf50 > > Would i be able to just plug it into Emax SE HD and use it? > > [Non-text portions of this message have been removed]
