Emax
Memory Upgrades
Memory Upgrades
2009-11-07 by dwv1957
Does anyone know where I could get copies of the memory install disks (if they still exist) I have 2 memory expansion boards and a box of ram chips, and would like to upgrade my EmaxII
Re: [emax] Memory Upgrades
2009-11-07 by Laurent/LIFELIKE
Im looking for one of those as well, my Emax lost his memory last week
after a cleaning session, very hard to find ZD413 floppies...
Sent from an iPhone
Re: Memory Upgrades
2009-11-07 by Everett
If I understand correctly, these are special floppies that are basically extinct.  I have a fully loaded EMAXII if there is a way to copy EPROMS I can probably do that for you.  Let me know...
Everett
> Sent from an iPhone
Re: [emax] Re: Memory Upgrades
Hi Everett
If you could do that if would be great, how does this process work ?
Sent from an iPhone
> Thanks,
> Everett
> week
> > Sent from an iPhone
Re: Memory Upgrades
It is quite simple, and should work if the EmaxII writes this info to the eproms, but it may write it to one of the PALs.
The emaxII uses 2-27C64 eproms, I have eprom burners and erasers,and a box full of 27C64's, but I would need a functioning 4/6/8 meg EmaxII to read the eproms from, to test the theory with, or if someone has a 4/6/8 meg machine and an eprom burner, they could read the eproms, and send me the .bin or .hex file, and I could burn them to an eprom, and test it in my machine.
Dave
> Hi Everett
> Sent from an iPhone
> > Thanks,
> > Everett
> > week
> > > Sent from an iPhone
Re: Memory Upgrades
2009-11-07 by esynthesist
I thought these configurations parameters (memory size, calibration settings, ...) are written to the 9306 eeprom instead of the two normal eproms. So I guess the eeproms must be reprogrammed, not the eproms. Am I wrong ?
///E-Synthesist
> Dave
> > Hi Everett
> > Sent from an iPhone
> > > Thanks,
> > > Everett
> > > week
> > > > Sent from an iPhone
2009-11-08 by Laurent/LIFELIKE
Must be that eeprom, because on later E4x models, this eeprom is the
word that appears and that can be reinitialized from the "secret menu"
without that damn floppy.
Lairent
Sent from an iPhone
Le 7 nov. 2009 à 21:18, "esynthesist" <esynthesist@...> a
écrit :
> ///E-Synthesist
> > Dave
> > > Hi Everett
> work ?
> > > Sent from an iPhone
> way to
> > > > Thanks,
> > > > Everett
> last
> > > > week
> > > > > Sent from an iPhone
> install
> boards and a
Re: Memory Upgrades
2009-11-08 by dwv1957
That makes more sense,I have never heard of the 27C64 being reprogrammed in circuit. If anyone has a 6 or 8 meg machine, and can read the eeprom, send me the .bin file, I have a spare 9306 I can reprogram, to test in my machine. If it works, I'll see if I can get a bunch of eeproms, and program them for 4/6/8 meg machines.
> ///E-Synthesist
2009-11-08 by tu@...
The 9306 EEPROM also has a bit (or bits) that determine whether the Emax II has stereo or
mono sampling capability. So you need to match that as well as the memory configuration
bits for each binary image. The Emax II EEPROM should have the SCSI boot ID, headroom
adjust, and wheel and slider calibrations as well, but they are easily re-programmable once
the new EEPROM is installed.
The main problem with reading the EEPROM in a device programmer is it first needs to be
desoldered from the main board. This should not be a huge problem but does risk damage
or corruption of the EPROM data, so take care if you want to try this! Another alternative is
just to probe the EEPROM clock and data pins during boot up with a logic analyzer and
manually program the data that is read into a fresh EEPROM.
Anyone planning to change the EEPROM on their Emax II will need to desolder their old
EEPROM and at that stage it would be a good idea to install a socket so the new EEPROM
can be easily installed and later removed if necessary.
I was actually going to do something like this last year and I got a tube of NOS 9306
EEPROMs but my device programmer would not write to them for some reason. I could
read from them and the analyzer indicated all the right timings were being met for both
read and write operations but they would not store the data. If you find a cheap source
of 9306 I am interested in some too.
/Tristan
> ///E-Synthesist
Re: Memory Upgrades
2009-11-08 by Everett
I can try to do this, but I'm a little nervous about killing my box.  If somebody can do a little more leg work before I crack into the hardware I would feel a little better.  I have an EPROM burner so I would be able to produce a bin file for an 8MB machine.  Let me know which one is needed and if there is a risk of this disabling my machine.
Thanks...
Everett
> > ///E-Synthesist
Re: Memory Upgrades
2009-11-08 by tristanupton
You need the remove 9306 EEPROM, its a small 8 pin chip soldered to the main board and designated IC24. You will need to desolder this chip to read in your burner and then you will need to resolder it back onto the main board. I suggest soldering an 8 pin DIP socket in its place and then just inserting the EEPROM into the socket rather than resoldering it direct to the board.
If you are not 100% sure what you are doing and confident in your soldering skills then I suggest not doing this. You run the risk of damaging the EEPROM and then your Emax II may no longer recognise the full memory or the stereo sampling. It is also possible you could damage something else on the Emax main board during removal or reinsertion of the chip. Also check whether your EPROM burner actually supports 9306 series EEPROMs, some EPROM burners may not.
/Tristan
> Thanks...
> Everett
> > > ///E-Synthesist
Re: Memory Upgrades
I'm curious, but maybe not THAT curious.  I can't find those chips anywhere either.  It's only an 8 pin DIP though, so I have plenty of those sockets lying around from various projects.  It's only a 16 x 16 bit array... seems like it wouldn't be able to hold too much information.  I guess they are just placeholders for options installed?  I'll check my programmer for support.  I just have one of those universal SIVAVA boards.
> /Tristan
> > Thanks...
> > Everett
> > > > ///E-Synthesist
Sounds very dangerous to perform that  desoldering.
Maybe we should simply try to enter the Diagnostics submenu 'adjust
features' that contains a kind of challenge code response algorythm
that could be easily decoded. Did somebody tried to check that option?
I wrote down the numbers but cant find any sense, they seem to be
generared randomly, or am i wrong?
On the other hands, there was this online shop "soundlogic usa" in
California that was selling Emax upgrade boards and that floppy back
in the days. The website is still there, but has been rebuilt, you can
still find upgrades for EIII and other brands.
On the news it says that Mike, soundlogic's owner, studios burned with
the big fire in California a couple of years ago, maybe the floppies
died in there, sounds like the Emax malediction :-))
Ok not so funny.
Laurent
Sent from an iPhone
> > /Tristan
> machine.
> > > Thanks...
> > > Everett
> > > > > ///E-Synthesist
2009-11-08 by Ted Summers
Well, I don't have an Emax 2, but I believe i can safely remove and re-
install the 9306
This chip is actually a National Semiconductor 93C06. its current 8
pin direct replacement is the 93C46 which is 30 cents at mouser.
My EEPROM programmer that makes the PALs for the SCSI upgrade has the
93C06 and the 93C46  in the device list.
I have a static safe solder station and a PACE for safe successful
removal of the chip.
If someone with Emax 2 models lives in the Washington / Oregon area I
would be willing to put my skills to use and pull the IC, place the
socket and read the IC.
In preparation, we could get some 93C46 and verify that they actually
work in replacement for the 93C06, though since they are in the Cross-
reference I don't see any reason why they wouldn't.
That being said, anytime you touch a static sensitive device with a
soldering iron there is a *chance* of damage.
But as far as minimizing risk, I am probably one of the people who has
all the equipment to have the most successful outcome.
I just don't have an Emax 2, or I would just test it out
myself.....Emax 2 is on my wish list when I have money. Even a dead
one- I might be able to bring back to life....
Ted
Ok not so funny.
Laurent
Sent from an iPhone
Le 8 nov. 2009 � 16:08, "Everett" <evy_newt@...> a �crit :
 > > /Tristan
 > machine.
 > > > Thanks...
 > > > Everett
 > > > > > ///E-Synthesist
Re: Memory Upgrades
2009-11-08 by esynthesist
Maybe it's the most stupid idea launched on this board (mea culpa) but I was wondering whether an eeprom programmer can be connected to the 9306 on the Emax-II itself by wire instead of desoldering the IC.
If that's possible, these wires could be connected (soldered temporarily) to the Emax-II board (bottom side), or - OK, maybe even more stupid - these wires could be put in the pin holders of an empty 8 pin socket, and this socket could be temporarily put (taped) on top of/around the 9306 IC in such way that it makes contact with the 9306's pins.
Is this nonsense or can this be done ?
(I'm not a hardware guy, but maybe I want to become one :-)
Note: I think we can indeed assume that this 9306 is the only chip containing the crucial data for memory upgrades, stereo upgrades and calibrations.
Here is an extract from the diagnostics guide:
(...)"Adjust Features -
This function allows a technician in the field to restore software
dependent features (such as memory size and stereo sampling) in
cases where the EEPROM has been erased or damaged. If you
have an Emax II that has forgotten what options it has, call the
factory for instructions."(...)
And here's an extract from the service manual:
(...)"There is also a EEPROM which contains important non-volatile information such as calibrations. The EEPROM is interfaced to the main CPU using a bizzare combination of the floppy side select, the MIDI off signal, a chip enable, and the MIDI interrupt lines."(...)
///E-Synthesist
> install the 9306
> Regards,
> Ted
> Ok not so funny.
> Laurent
> Sent from an iPhone
>  > > /Tristan
>  > machine.
>  > > > Thanks...
>  > > > Everett
>  > > > > > ///E-Synthesist
There are clips manufactured for this purpose, actually. My concern
would be whether you would get corrupted data in circuit. and if you
had a bad one, I would expect you would still need to replace the IC.
Regards.
Ted
9306's pins.
calibrations.
///E-Synthesist
re-
 > install the 9306
Cross-
has
 > Regards,
 > Ted
option?
can
with
 > Ok not so funny.
 > Laurent
 > Sent from an iPhone
socket
or
 > > > /Tristan
so
my
 > > machine.
 > > > > Thanks...
 > > > > Everett
can
get
of
 > > > > > > ///E-Synthesist
Re: Memory Upgrades
It's a relief to hear it's not a stupid idea after all :-)
So I googled on "eeprom clip" and yes indeed, there seems to be very handy tools out there (and not that expensive).
What do you mean by "corrupted data in circuit" ?
I mean: if you are just READING out a "good" 9306 on a fully expanded working Emax-II with a clip, could you still destroy this 9306 ??
If so, I understand the concern.
If not, then perhaps you can still end up with corrupt readings, but by repeating that a few times one must be able to have the 100 pct correct data, right ?
If the concern is related to WRITING the 9306, I think this is less critical. In the sense that if the original 9306 can not be written with a clip, it can still be replaced by a new one - preferably to be put into a socket on the Emax-II instead of soldering it again.
Or is the biggest concern here that these 9306 eeproms (or equivalent) are really hard to find on the market now ?
I guess the biggest risk/concern in this experiment would be to destroy a perfectly working 9306 containing the data we are all looking for. I can understand that there would not be that many Emax-II owners that want to take the risk to loose their eeprom settings (like Laurent experienced when cleaning his Emax-II...)
The contents of the different flavours of the Emax-II eeproms, that's what we are missing today.
It would be really nice if we could build up a library of BIN files for each of the most popular "extended memory" versions:
- Emax-II MONO 2MB
- Emax-II STEREO 2MB
- Emax-II STEREO 4MB
- Emax-II STEREO 8MB
I have stereo 4 and 8 MB versions, and I know someone who has a 2MB one. I don't have the equipment (yet ?) though. But I could buy these devices next week...
Are there other risks to be mitigated ?
///E-Synthesist
> Regards.
> Ted
> 9306's pins.
> calibrations.
> ///E-Synthesist
> re-
>  > install the 9306
> Cross-
> has
>  > Regards,
>  > Ted
> option?
> can
> with
>  > Ok not so funny.
>  > Laurent
>  > Sent from an iPhone
> socket
> or
>  > > > /Tristan
> so
> my
>  > > machine.
>  > > > > Thanks...
>  > > > > Everett
> can
> get
> of
>  > > > > > > ///E-Synthesist
Re: Memory Upgrades
I see that there are at least 2 "programmed PALs" in each memory board upgrade kit inventory.  Does anyone know what these chips are and what information they contain?
Let's say we perform a mild miracle and successfully clone this 9306 EEPROM.  Wouldn't these chips need to be upgraded (installed?) as well?
Re: Memory Upgrades
A memory upgrade indeed also required sometimes the replacement of the PAL.
But... I think the two most common situations today are:
1/ Someone's Emax-II has the expanded memory board with correct RAM and PAL but for some reason lost the eeprom data
2/ Someone found a second hand or NOS Emax-II memory expansion board for the Emax-II but no installation disk (or a used one) is provided.
I guess in both cases the PALs are already OK because - if I understand it correctly - these PALs are seated on the memory expansion board itself, right ?
If a new memory expansion board has to be developed from scratch, then we would also need the PALs for sure.
Or am I overlooking something ?
///E-Synthesit
2009-11-08 by Julian
oooh, I2C eeprom.
I just looked about and found the Atmel datasheet for their 93c46, and
an old microchip datasheet for their version of the 06/46.
If this is newer atmel part is representative of other modern 93c46
parts, to make the 46 work in place of the 06 you might have to make a
change - pin 6 is now a memory organisation pin, and you'll need to pull
that to VCC in order to make this chip run in x16 memory organisation.
apart from that - reading and writing I2C eeprom is pretty trivial and
works in a standard way across all devices. if worst comes to worst you
can do it with a standard microcontroller dev board and some off the
shelf code....
http://bleepin.com
http://www.fastmail.fm - Same, same, but different...
I am only saying that it might be that you won't get a valid data file
out of it due to it being in the board as opposed to being in the IC
holder on the EEPROM burner.
You might get erroneous data.
I would think you would only damage it if you accidentally shorted the
pins when using the clip.
Or zapped it, plain and simple.
This can be avoided by using static safe equipment during removal and
handling.
This would only work if you already had the upgrade prior, as I agree
with the statements regarding the PALs.
If the PALs come on the memory upgrade board, then it is a non issue-
however if you want to add memory and don't have the board....
So two scenarios- look at the PAL IP#s to see if the same PALs are
used on all the upgrade boards (2,4,8). If the same PAL, then they
aren't locking the memory size, beyond telling the system to address
the expansion board.
If different PALs in every model, we would need PAL binaries, and the
9306 versions from each type....
Maybe Rob at Emulator Archive could sweet talk the guys at E-Mu to get
those PAL binariess too.
If so, then someone could send me the files and I would see if my
resources could (once again) help me to convert the original files to
make new chips.
The Emax 1 SCSI PAL binaries were in a non-standard format...only the
original programmer module could be used with them, and Emu didn't
divulge what the programmer was.....hence the necessary conversion.
What PAL IC are they? are they the same PAL16R4? If so, I got 140 NOS
of them.
But without an Emax 2, I couldn't test / verify them.
Just my thoughts,
Ted
- Emax-II MONO 2MB
///E-Synthesist
 > Regards.
 > Ted
but
 > 9306's pins.
 > calibrations.
main
 > ///E-Synthesist
 > re-
 > > install the 9306
area I
actually
 > Cross-
 > has
 > > Regards,
 > > Ted
 > option?
back
 > can
 > with
floppies
 > > Ok not so funny.
 > > Laurent
 > > Sent from an iPhone
 > > Le 8 nov. 2009 � 16:08, "Everett" <evy_newt@> a �crit :
plenty of
16 x
one of
soldered
resolder
 > socket
your
risk of
 > or
not.
 > > > > /Tristan
killing my
into
 > so
 > my
 > > > machine.
 > > > > > Thanks...
 > > > > > Everett
 > can
 > get
 > of
reprogrammed,
 > > > > > > > ///E-Synthesist
Re: Memory Upgrades
The PALs are on the expansion board, and they are the same for the 4/6/8 meg upgrades, but the 5/7 meg upgrades use different PALs.
I have 2 main boards that I removed the 9306's from and soldered sockets in for them, they are both 4 meg boards. I'll order a few 93C06's or 93C46's and do some experiments.
On a side note, if anyone has an EmaxII they want to sell(working or not), let me know, I have a rack unit that I acquired off Ebay, but it is in pretty rough shape, and I could use another case for it.
Then I could also use the extra parts to set up a unit on the workbench, for experimenting on.
> handling.
> make new chips.
> of them.
> Just my thoughts,
> Ted
2009-11-09 by Ted Summers
I see what you are saying about the pinout, but it looks like there
are parts available on ebay for $1 to $7, so its not that expensive to
get the real deal....
file
 > handling.
get
 > make new chips.
 > of them.
 > Just my thoughts,
 > Ted
Re: Memory Upgrades
2009-11-09 by dwv1957
That's only partially right, there are 3 versions of the 93C46
93C46A is 8 bit
93C46B is 16 bit
93C46C is selectable 8/16 bit, and is the only one that requires the ORG pin.
the 93C46B is a direct replacement for the 93C06
Dave
--- In emax@yahoogroups.com, "Julian" <jujulilianan@...> wrote:
> oooh, I2C eeprom.
> shelf code....
> http://bleepin.com
Re: Memory Upgrades
2009-11-13 by Everett
Alright everybody, I took the plunge... have at it.  I will upload the BIN to the files section.
EMAX II it came from:
Model 2213
SN: 01200659
Main Board: PC360 REV C
SN: 900428
Upgrade Board: PC357 REV B (fully loaded)
Hopefully someone can put this info to good use.  I have ordered a few 9346s and sockets.  I'd be glad to burn a few and send them out if someone needs them.
Everett
> 93C46A is 8 bit
> 93C46B is 16 bit
> Dave
> --- In emax@yahoogroups.com, "Julian" <jujulilianan@> wrote:
> > oooh, I2C eeprom.
> > shelf code....
> > http://bleepin.com
2009-11-14 by tu@...
Does your Emax II have stereo or mono sampling?
/Tristan
> Model 2213
> SN: 01200659
> SN: 900428
> Everett
> > 93C46A is 8 bit
> > 93C46B is 16 bit
> the ORG pin.
> > Dave
> > > oooh, I2C eeprom.
> 93c46, and
> 93c46
> make a
> to pull
> organisation.
> trivial and
> worst you
> the
> > > shelf code....
> > > http://bleepin.com
Re: Memory Upgrades
2009-11-14 by esynthesist
This is great.
Thanks.
Maybe I'll be able to upload some of those bins in the future for 4MB and 2MB versions too (all stereo). I don't have the eeprom reader yet...
We should all be aware of course that this BIN also contains the calibration settings of the "donor" Emax-II, so these might have to be adapted once the BIN has been written to the "target" Emax-II.
Thanks !!
///E-Synthesist
> Model 2213
> SN: 01200659
> SN: 900428
> Everett
> > 93C46A is 8 bit
> > 93C46B is 16 bit
> > Dave
> > > oooh, I2C eeprom.
> > > shelf code....
> > > http://bleepin.com
Re: Memory Upgrades
2009-11-14 by Everett
It has Stereo Sampling.  I thought that was part of the upgrade?
> /Tristan
> > Model 2213
> > SN: 01200659
> > SN: 900428
> > Everett
> > > 93C46A is 8 bit
> > > 93C46B is 16 bit
> > the ORG pin.
> > > Dave
> > > > oooh, I2C eeprom.
> > 93c46, and
> > 93c46
> > make a
> > to pull
> > organisation.
> > trivial and
> > worst you
> > the
> > > > shelf code....
> > > > http://bleepin.com
Re: Memory Upgrades
If you're shopping, I have found that this is a very useful universal burner: http://sivava.com/
It comes from Thailand or something, but it will do quite a few different kinds of chips.  I know there are cheaper ones out there, but I can't speak for the quality of those units.  I actually got another one before this one and it just flat didn't work for old school UV EPROMs.  I think it might work for other things, but I passed it off as junk.  Be sure to power the burner with a healty "wall wort" and not the USB power.  I use a 13.5 VDC connector in the 12V plug to ensure a positive burn.
> This is great.
> Thanks.
> Thanks !!
> ///E-Synthesist
> > Model 2213
> > SN: 01200659
> > SN: 900428
> > Everett
> > > 93C46A is 8 bit
> > > 93C46B is 16 bit
> > > Dave
> > > > oooh, I2C eeprom.
> > > > shelf code....
> > > > http://bleepin.com
2009-11-15 by tu@...
I was just wondering because I have seen many different Emax II configurations. Stereo sampling
upgrades were separate from RAM upgrades and the model number does not always match with
what should be inside.
/Tristan
> > /Tristan
> upload
> > > Model 2213
> > > SN: 01200659
> > > SN: 900428
> a
> out
> > > Everett
> > > > 93C46A is 8 bit
> > > > 93C46B is 16 bit
> requires
> > > the ORG pin.
> > > > Dave
> > > > > oooh, I2C eeprom.
> > > 93c46, and
> modern
> > > 93c46
> to
> > > make a
> need
> > > to pull
> > > organisation.
> > > trivial and
> to
> > > worst you
> off
> > > the
> > > > > shelf code....
> > > > > http://bleepin.com
Re: Memory Upgrades
2009-11-17 by Everett
I'd just like to report a success in using a chip burned with the 93C06N image I uploaded and a 93C46B chip.  At first I was sweating because it gave me a memory error on bootup and only showed me 6 or 7 Megs!  I just went back in and re-seated the memory expansion board and now all is well, whew!  That thing is really not supported too well on the underside of those connectors so you have to push harder than you'd probably like to.
Thanks to all that lead me in the right direction, and I hope someone else can save another EMAX with this.
Everett
> /Tristan
> > > /Tristan
> > upload
> > > > Model 2213
> > > > SN: 01200659
> > > > SN: 900428
> > a
> > out
> > > > Everett
> > > > > 93C46A is 8 bit
> > > > > 93C46B is 16 bit
> > requires
> > > > the ORG pin.
> > > > > Dave
> > > > > > oooh, I2C eeprom.
> > > > 93c46, and
> > modern
> > > > 93c46
> > to
> > > > make a
> > need
> > > > to pull
> > > > organisation.
> > > > trivial and
> > to
> > > > worst you
> > off
> > > > the
> > > > > > shelf code....
> > > > > > http://bleepin.com
2009-11-17 by sanctifiedone@...
Hi, a m I understanding you right that you've installed a memory upgrade WITHOUT that extinct floppy disk?
Sorry if I didn't get everything that was going on in this thread.
I've got 8 Megs awaiting install and a missing floppy.
To: emax@yahoogroups.com
Sent: Monday, November 16, 2009 10:24:31 PM GMT -05:00 US/Canada Eastern
Subject: [emax] Re: Memory Upgrades
Everett
> /Tristan
> > > /Tristan
> > upload
> > > > Model 2213
> > > > SN: 01200659
> > > > SN: 900428
> > a
> > out
> > > > Everett
> > > > > 93C46A is 8 bit
> > > > > 93C46B is 16 bit
> > requires
> > > > the ORG pin.
> > > > > Dave
> > > > > --- In emax@yahoogroups.com , "Julian" <jujulilianan@> wrote:
> > > > > > oooh, I2C eeprom.
> > > > 93c46, and
> > modern
> > > > 93c46
> > to
> > > > make a
> > need
> > > > to pull
> > > > organisation.
> > > > trivial and
> > to
> > > > worst you
> > off
> > > > the
> > > > > > shelf code....
> > > > > > http://bleepin.com
Re: Memory Upgrades
2009-11-18 by Everett
Well, sort of.  I already had a machine with 8MB so I de-soldered the EEPROM from the board, burned it onto another chip and re-installed that chip into a socket soldered where the other chip was.  So far I have not heard if anyone else has tried, so if you do this prepare for it possibly having problems.  If you don't have an EEPROM burner I can supply a few burned chips... I have 4 (with sockets).
> From: "Everett" <evy_newt@...>
> Everett
> > /Tristan
> > > > /Tristan
> > > upload
> > > > > Model 2213
> > > > > SN: 01200659
> > > > > SN: 900428
> > > a
> > > out
> > > > > Everett
> > > > > > 93C46A is 8 bit
> > > > > > 93C46B is 16 bit
> > > requires
> > > > > the ORG pin.
> > > > > > Dave
> > > > > > > oooh, I2C eeprom.
> > > > > 93c46, and
> > > modern
> > > > > 93c46
> > > to
> > > > > make a
> > > need
> > > > > to pull
> > > > > organisation.
> > > > > trivial and
> > > to
> > > > > worst you
> > > off
> > > > > the
> > > > > > > shelf code....
> > > > > > > http://bleepin.com
Re: Memory Upgrades
2009-11-26 by dwv1957
Just a note to let everyone know, you can upgrade the memory of your EmaxII by changing the EEprom.
I took the eeprom out of an 8 meg emaxII read it to a .bin file, and then burned the image to a new eeprom, then I fully populated the memory expansion board in my 4 meg machine and plugged in the new eeprom, and everything works perfectly. I also did images of 4mb and 6mb emaxII's and tested them with different configurations and everything seems to be working fine.
This will only work with 2 meg emax's, the original 1 meg emax's use different PALs, I could probably upgrade the 1 meg machines, but I would need the main board and expansion board to do it.
The biggest problem you will have is finding enough 44256 memory chips to populate the expansion board with.
I can supply the burned eeproms for $10 +shipping, if your not comfortable desoldering the old eeprom, I can do it for you, I don't need the whole machine, just the main board and expansion board, if interested, contact me off list.
Dave
Re: Memory Upgrades
2009-11-26 by thenewyorkcowboy
Are you including the dip socket with your upgrade kit?
Item 190350499284 on Ebay has 50pcs of 44256 for $1.49 each.
> Dave
Re: Memory Upgrades
2009-11-26 by Everett
Cool, looks like we're in business then.  Another person has verified that this works.  If you upload the bin files you have created to the group maybe someone can crack the code by comparing the different files.  I have already put one 8MB stereo file in there.  I assume yours would be almost identical except for some calibration data.
Everett
> Dave
Re: Memory Upgrades
2009-11-27 by Reinaldo
So...
I can download the file and burn a new eprom chip for my emax II.
Then I can buy the memory chips on eBay.
But I need the expansion board!
How do I do without expansion board then?
2009-11-27 by Ted Summers
I believe what the Memory Upgrade people are saying is:
1) If you have "scrambled megs" and your emax 2 doesn't see all your
memory, then they have a fix
2) If you have a expansion board, and it is not full, you now have an
inexpensive way to fill it up the rest of the way and get a chip so
emax2 sees the added memory now.
But I don't think they are saying they are duplicating the Expansion
board at all.... you must already have an expansion board.
On Nov 26, 2009, at 6:36 PM, Reinaldo wrote:
So...
Re: Memory Upgrades
2009-11-27 by thenewyorkcowboy
Yeah I was all hopeful until I opened my Emax II up and saw that I don't have the board, just an empty space where it looks like there are enough places to solder in sockets to get the Emax II up to 12 megs.  I have 4 already (16 chips) and there are 32 spaces available.  Does anyone think that actually soldering in another 16 sockets would be the same as adding an expansion board?
> So...
Re: Memory Upgrades
2009-11-28 by Everett
My expanded EMAX actually only has a portion of the sockets filled on the main board.  I believe the writeup on emulator archive goes through why in more detail.  I believe someone else stated that the PALs are different on the models with the board installed.  The upgrade kit inventory shows these PAL chips in there, so that makes sense.
--- In emax@yahoogroups.com, "thenewyorkcowboy" <thenewyorkcowboy@...> wrote:
> > So...
Re: Memory Upgrades
2009-11-29 by thenewyorkcowboy
Ah!  I finally figured it out.  I did more research and my model, the 2212 is only a 2mb which I verified by Master 4,Y,2, and got 1048488.  Here I had been doing improper math but with the Emax II Diagnostics.pdf I came to this conclusion.  Bad for me!  But now I need to find someone that has a late model 2205 with 8mb and find out if the factory installed all the memory on the mainboard or did they also use two 2208 kits to get to 8mb.  That would provide the solution whether or not the mainboard slots could be populated with sockets and chips.
> > > So...
Re: Memory Upgrades
So I opened up the cover again and did some thorough examination.
I have 16 chips of Samsung KM44C256CP-7 up through IC socket 63.  At 256k per chip I don't initially understand why that only equals 2MB of memory...
Sockets 64-99 are available for soldering, but they are 18 pin slots compared to the 20 pin Samsungs!  What is up with that?
I shone a light onto the PC board and it seems all of the traces on two sides of the processor go through the respective chip sockets all the way to the two expansion board connectors, so that is hopeful that once it can be figured out, we can make our own expansion boards right on the mainboard.
If we can find the right source for 18 pin IC sockets and the right 44256 memory modules (70ns,20ns,130ns) I should be able to upgrade my Emax to 6mb of memory right on the mainboard.
> > > > So...
2009-11-30 by tu@...
Each of the Samsung chips is 256k x 4 bits. So two of them give you 256kB and 8 x 256kB = 2MB.
The 18 pin sockets are for the 4464 DRAM used in the 1MB version of the Emax II and you cannot use them at the same time as the 20 pin sockets, its
either one set of DRAMs or the other. If you want to expand your Emax II to more than 2MB you will need to get the RAM expansion board...
/Tristan
memory...
> > > > So...
Re: Memory Upgrades
2009-11-30 by thenewyorkcowboy
Ah, thanks Tristan, now I understand.  I was a bit lost on what a 4 bit word size meant.
As for acquiring a RAM expansion board, isn't that the holy grail of Emax II ownership?  Or having enough money in the bank at the very moment someone out there wants to sell their 8mb unit outright?
No one yet has found the hidden cache of leftover expansion boards and EMU has never been helpful about their production vs. sales figures, if there are even enough to think that someday someone will run into the warehouse that holds the remaining kits...
Between the member here that just purchased the service manual with schematics, and the various PC board prototype manufacturers, shouldn't there be a way to at least get the PCB re-made?  I have seen companies that charge a one time $50 setup, and then have no minimum order requirements.
Another idea if the schematic allows it would be to solder in the 18 pin sockets, and then piggyback another one or two 18 pin sockets for height and then a 20 pin socket over top of it and simply connect the last two pins in the right way through wire-wrap or other means.  All the traces that end up at the two blue connectors for the expansion board go through all of the 18 pin holes on their way back to the processor.  That of course is a big IF the first 18 pins match up on a 20 pin IC which could be determined quickly either just by following the traces with the mainboard pulled or with the Samsung datasheet and a continuity meter...I know...desperately scatterbrained but I like impossible challenges.
> /Tristan
> memory...
> > > > > So...
2009-11-30 by Ted Summers
My understanding is that the RAM expansion board has PALs that go with it.
Getting the PAL binaries for the SCSI update wasn't easy for Rob at Emulator
Archive.
Even if you duplicated the PCB, you would have to be able to make the PALs
that allow the access to the extra memory.
You would need the original PAL binaries for that.....
Otherwise the Emax wouldn't be able to address the additional memory....
even if it was physically installed.
Someone correct me if I am wrong in my understanding of what was discussed
previous on the thread.
Ted
On Mon, Nov 30, 2009 at 1:17 PM, thenewyorkcowboy <
> size meant.
> > /Tristan
> > memory...
> the
> > --- In emax@yahoogroups.com <emax%40yahoogroups.com>, "thenewyorkcowboy"
> had
> would
> > > --- In emax@yahoogroups.com <emax%40yahoogroups.com>, "Everett"
> these
> think
> an expansion board?
> > > > > --- In emax@yahoogroups.com <emax%40yahoogroups.com>, Ted Summers
> your
> have an
> so
> Expansion
> > > > > > So...
Re: Memory Upgrades
2009-12-01 by dwv1957
You are exactly right Ted, the expansion board has 4 PALs on it plus some 74HCxxx chips on it, it is also a 4 layer board, so the amount of work it would take to duplicate it is just not worth it.
As for "stacking" chips on the motherboard's 18 pin sockets, not a hope in hell of that working (sorry).
The only way to upgrade the Emax2, is to have the original upgrade board, as long as you have that, you can upgrade it to anything you want.
Dave
> Archive.
> Regards,
> Ted
2009-12-01 by Ted Summers
This is another case where, if people find a dead emax 2 it would
possibly still be worth something just to get the expansion board if
the dead unit has one, to put into a working unit.
want.
Dave
with it.
Emulator
 > Archive.
the PALs
memory....
discussed
 > Regards,
 > Ted
2009-12-01 by jammie
if some one is willing to donner there board then duplicating it is not a problem x ray scanning the board and using the scan in eagle is possible as we have done it for asr10 sp3 scsi interface which is a 4 layer board and the production costs for resale worked out at £120 which is cheap as the original was £300 from ensoniq
it can be done and you can use a logic scanner for the functions of the pals its not impossible and thats how manufacturers upgrade there boards with new tech for old industrial computers
it would be nice if we could get the bin files for the pals we would have to ask rob if he could find out if the bin files are still available
  Sent: Tuesday, December 01, 2009 4:38 AM
  Dave
  > Archive.
  > Regards,
  > Ted
Re: Memory Upgrades
That translates to approximately $200 US, then add another $100 (minimum) for the ram, so your looking at a minimum of $300 + associated shipping costs to upgrade your Emax 2.
A fully populated 8 meg Emax 2 is only worth around $250-300 in working condition, my question is, How many people would be willing to pay $300+ for the upgrade, when you can buy another machine for the same, or less, and have a bunch of other spare parts to boot?
Dave
--- In emax@yahoogroups.com, "jammie" <jammie.emma@...> wrote:
> If someone is willing to donate their board, then duplicating it is not a problem, x ray scanning the board and using the scan in eagle is possible, as we have done it for asr10 sp3 scsi interface which is a 4 layer board, and the production costs for resale worked out at £120 which is cheap as the original was £300 from ensoniq
> It can be done and you can use a logic scanner for the functions of the pals, its not impossible, and that's how manufacturers upgrade there boards with new tech for old industrial computers.
> It would be nice if we could get the bin files for the pals, we would have to ask rob if he could find out if the bin files are still available.
>   From: dwv1957
>   Dave
>   > Archive.
>   > Regards,
>   > Ted
who said it was $200
  Sent: Tuesday, December 01, 2009 7:16 PM
  Dave
  > From: dwv1957
  > Dave
  > > Archive.
  > > Regards,
  > > Ted
  No virus found in this incoming message.
  Checked by AVG - www.avg.com
  Version: 8.5.426 / Virus Database: 270.14.88/2538 - Release Date: 12/01/09 07:59:00
Re: Memory Upgrades
2009-12-02 by thenewyorkcowboy
Ah, Ok I guess I've been sniffing too much glue...my head is spinning.
So to be clear, the EPROM programming conversation is only for people who have acquired an expansion board but not the floppy that went along with it, or their unit is not recognizing the memory they already have.
To reverse engineer an expansion board we would have to also program a few PALS as well!
It certainly sounds close to impossible given the groups resources.  If only EMU would be more helpful...
But I'm going to keep probing, so I have another Frankenstein question:
Even though the PCB is 4 layer, would there be a way to reproduce the schematic on say 2 different breadboards connected by jumper wires that would be at least electrically compatible?  Or is one of the chips necessary for the expansion board some kind of TSOP or SMT package?  I am just saying that there is certainly enough room in the EMAX to spread out the components more than the original 4 layer PCB, or to stack them up using additional standoffs.  It wouldn't be the prettiest thing, but if at least it worked...
I found this website that shows a picture of an AZF memory module that looks quite similar to one piece of the puzzle that could be used...
http://www.memoryten.com/pc/003180/FPM-20p-1Mbit/
And they are having $1 shipping so the whole cost is $3.49!!!!
So the breadboard would hold all the non-memory components, and then that board would be jumpered into the AZF board above...
Could someone list the other full chip labels so I can start looking them up on chipdocs.com?  At least I can dream...now where's that glue?
74HCxxx???
>   From: dwv1957
>   Dave
>   > Archive.
>   > Regards,
>   > Ted
Re: Memory Upgrades
True, but how many 8mb units have you seen for sale in the past two years, for example?
I have another keyboard from the same era, a 1986 Korg Poly-800 that now has a new 'kit' out for $100 (about the price of the unit itself) that greatly increases its functionality, etc. the Hawk-800 mod.
I am just trying to exhaust all the DIY angles.  Even the Commodore 64 has new USB to PC adapters for $39 because someone just kept at it.  Maybe someday all the 'codes' will be broken and we can be playing with 32mb EmaxIIs with all new software, etc.  It just takes collaboration, not resignation, and right now it is a question of money.  This guy in France is a great testament to that fact.
http://matthieu.benoit.free.fr/parts_for_Exchange.htm
> Dave
> >   From: dwv1957
> >   Dave
> >   > Archive.
> >   > Regards,
> >   > Ted
Re: Memory Upgrades
2009-12-02 by tristanupton
Actually, in the last few years I have picked up several 8MB Emax II racks for around $50 each plus shipping. You just have to keep watching Ebay etc. Often they come up at silly prices, but week after week they come down to something reasonable. Quite often they sell in the $100-$200 range. Mostly the sellers don't understand what they have or make wildly inaccurate claims in the descriptions, so its not easy to be sure what you are getting. But any Emax II expanded beyond 1MB or 2MB will have the memory expansion board.
Reverse engineering and building a replacement memory expansion board for the Emax II would not be extremely difficult. Anyone with a logic analyzer and sufficient knowledge of digital electronics should be able to do it. The main issue is the amount of work involved. Someone could take it on as a labour of love, but its hard to justify when you can buy an Emax II for the price of a few hours of an engineer's time...
/Tristan
> > Dave
> > >   From: dwv1957
> > >   Dave
> > >   > Archive.
> > >   > Regards,
> > >   > Ted
2009-12-02 by Ted Summers
That is correct.
It took Rob like 2 yrs or more talking with Emu to get them to release the
SCSI upgrade PALs for Emax 1.
for the expansion board some kind of TSOP or SMT package?Could someone list
Those are 4 ICs to each data word/byte, and the emax 2 was using 2 ICs per
each data word/byte.
I believe there would have to be something to re-address the differences
in memory address due to the different memory IC, and you still have to get
around the PALs.
On Wed, Dec 2, 2009 at 5:31 AM, thenewyorkcowboy <thenewyorkcowboy@yahoo.com
> PALS as well!
> 74HCxxx???
> --- In emax@yahoogroups.com <emax%40yahoogroups.com>, "jammie"
> the production costs for resale worked out at �120 which is cheap as the
> original was �300 from ensoniq
> > From: dwv1957
> > To: emax@yahoogroups.com <emax%40yahoogroups.com>
> > Dave
> it.
> Emulator
> > > Archive.
> PALs
> memory....
> discussed
> > > Regards,
> > > Ted
2009-12-02 by Daniel Baum
>condition,
That's quite a bit more than I paid for mine!
D.
Re: Memory Upgrades
2009-12-03 by thenewyorkcowboy
"Several"??  Hey guys we found the hoarder!  LOL.
Yes, I picked up my 2mb for I think $152 if I remember, but wow, getting an 8mb rack for $50?
The irony of all this then is that there is a Yahoo Group dedicated to a $50 piece of equipment, just like all the groups out there for C64s which can be picked up usually for $20....
> /Tristan
> > > Dave
> > > >   From: dwv1957
> > > >   Dave
> > > >   > Archive.
> > > >   > Regards,
> > > >   > Ted
Re: Memory Upgrades
2009-12-04 by John
Are there any memory upgrades I can install in my 2mb Emax 2 keyboard?
> > /Tristan
> > > > Dave
> > > > >   From: dwv1957
> > > > >   Dave
> > > > >   > Archive.
> > > > >   > Regards,
> > > > >   > Ted
Memory Upgrades
2015-10-13 by graham.hunter@...
I have an Emax 2 rack with 4MB of memory and a set of 4MB chips sitting next to me on my desk.
Is the "scrambled megs" code the only thing that will let me unlock the extra 4MB once installed, or are there other ways to get the sampler to recognize the upgrade after the installation?
2015-10-13 by Ted Summers
You have to have the proper PALs installed.
You can verify this by looking at the Emax 2 Memory Uprgade document.
If you have the correct PALs installed, then yes, scrambled megs is all you need (EPR can give you the unlock code).
If you don’t have the correct PALs, then you would not be able to upgrade it.
Although I have been given some PAL binaries (which I can’t program yet) which may enable this in the future….
-T
On Oct 13, 2015, at 7:29 AM, graham.hunter@... [emax] <emax@yahoogroups.com> wrote:
Yes, I do know that I have the correct PALs.
Thinking out loud here, could I theoretically copy the EPROM from a working 8MB Emax 2?
Some have said they have socketed the parameter EEPROM (this is not the BOOT EPROM which is already socketed, parameter EEPROM is an 8pin DIP).
However, when I tried it as a test (took out my existing, read the data in with EPROM programmer, program new IC, put in socket and programmed IC), that didn’t work for me (so put the original back in, and working again), so YMMV.
-T
On Oct 13, 2015, at 10:44 AM, graham.hunter@... [emax] <emax@yahoogroups.com> wrote:
2015-11-01 by mark sherkus
Hi does anyone recall who was reproducing analog oscilators in the UK ala the old modular Emus?Thanks,Mark
On Tue, 10/13/15, Ted Summers djtbs1@... [emax] <emax@yahoogroups.com> wrote:
 Subject: Re: [emax] Memory Upgrades
 Date: Tuesday, October 13, 2015, 9:52 AM
       You have to have the proper PALs installed.You can verify this by looking at
 the Emax 2 Memory Uprgade document.If you have the correct PALs
 give you the unlock code).If you don’t have the correct
 -T
 On Oct 13, 2015, at 7:29 AM, graham.hunter@gmail.com
 desk.
 installation?
 #yiv9669454770 #yiv9669454770 --
