Emax
Emu Emax 1
Emu Emax 1
2009-07-15 by dmitri
I have an Emu Emax 1 with the HD retrofit.
The hard drive does not work nor does saving to floppy.
i plan to purchase a newer OS disc today in hopes that it will enable me to save presets to floppy.
1. what OS would you recommend ?
2. where should i buy it ?
d
Re: [emax] Emu Emax 1
2009-07-15 by Brooks Mosher
does it currently boot up from the floppy drive?
> d
Re: Emu Emax 1
yes it boots and i am able to sample but not able to save the samples.
the disk says OS 1.1 i think its either corrupt or i may have to disconnect the non working HD ?
d
> > d
2009-07-15 by jammie
download with exmp
  To: emax@yahoogroups.com
  Sent: Wednesday, July 15, 2009 6:42 PM
  Subject: [emax] Emu Emax 1
  d
  No virus found in this incoming message.
  Checked by AVG - www.avg.com
  Version: 8.5.387 / Virus Database: 270.13.15/2239 - Release Date: 07/15/09 06:07:00
yeah just got yourself a new floppy (if it's a 1.4 meg floppy tape off the
copy protect) and download the latest OS found on the archives and copy to
the floppy with EMXP...
On Wed, Jul 15, 2009 at 2:21 PM, jammie <jammie.emma@...>wrote:
> download with exmp
> From: dmitri
> To: emax@yahoogroups.com <emax%40yahoogroups.com>
> d
> 06:07:00
2009-07-15 by Ted Summers
If you can boot from floppy, have you tried formatting another floppy?
Keep in mind, if you do not have DSDD (720Kb) floppy diskettes, only HD
floppy Diskettes (1.44MB), that you must cover the hole (not the write
protect hole, the other one).
If the format fails, and you also cannot save banks, that sounds more like
an hardware issue.
Either the floppy drive is bad (bad head), or bad Floppy Controller IC.
As to OS- if you have a Hard Disk, you must have an Hard Disk OS for
the drive to work.
What is the revision returned by going into Master> Special  ?
With a Hard Disk, you should be running either Emax HD OS 1.1, Emax HD SE OS
1.1 / Plus OS 1.0 (SE Only Emax).
Ted
> d
Re: Emu Emax 1
I can boot from floppy and can format another floppy.
The floppys i am using are the ones specified in the manual double sided. (Radio Shack)
I was using the sliding write protect thing I will try taping off the other hole tonight thank you.
my OS disk said emax OS 1.1 but i am not sure that it is the HD 1.1 because mine is an Emax HD retrofit.
When I go to master I am not able to select "Special" the sticker on the master section says "Special" is peremiter 10 but the Emax will not accept a second digit while in Master mode. That is what makes me think that the OS is not correct for the HD
I do not own a pc or a computer with a floppy drive.
Is there somewhere where i can purchase the HD 1.1 os on a floppy online ?
thank you for your help! im almost there!
d
> an hardware issue.
> the drive to work.
> Regards,
> Ted
> > d
Re: Emu Emax 1
2009-07-16 by Ted Summers
Use the data slider to change the menu choices.
You have  an HD os if you hit master, then 0, then use data slider and
see if you have copy hd (plus OS this is #0), format hd (this is #7)
So basically, write protect holes should be open (slider), density
select (no slider for this hole) should be covered.
True DSDD disks will not have a density select hole.
Ted
online ?
d
floppy?
only HD
write
more like
 > an hardware issue.
IC.
 > the drive to work.
HD SE OS
 > Regards,
 > Ted
enable me to
 > > d
2009-07-16 by jammie
get a dddd floppy as a hd corupt over time they use a higher magnetic field that why theres the hole so that the floppy drive  knows to switch feilds
  Sent: Wednesday, July 15, 2009 8:28 PM
  Subject: Re: [emax] Emu Emax 1
  > download with exmp
  > From: dmitri
  > d
  > 06:07:00
