2009-03-22 by JMoore6397@...
Thank You for the response. This is a task for next week -I am on vacation.
Can you guide me to a document which could give an overview of this process
(if one exists)?
Jimmy Moore
In a message dated 3/20/2009 4:36:42 P.M. Eastern Standard Time,
scartattack@... writes:
Hmm, perhaps you need to replace the springs or j-wires (the spring
that makes key contact) in those keys? Have you opened it up? It's
possible that the keys are not seated properly and you may be able to
adjust them. Be careful if you attempt to remove a key as the j-wires
will stretch and bend fairly easily. I do have some extra keys from an
old salvaged Emax key bed that someone gave me a long time ago so it's
possible I might have the keys you mentioned.
-s*
On 20-Mar-09, at 3:04 PM, _JMoore6397@..._ (mailto:JMoore6397@...)
wrote:
> I am so sorry for the inaccurate post. I have 3 keys which has
> lifted above
> the other keys. Somewhat awkward to play and when you press while
> playing a
> thud can be heard.
> It still is a great sounding board though is a great sampler! There is
> an emax II on ebay
> Jimmy Moore
> In a message dated 3/19/2009 2:32:28 P.M. Eastern Standard Time,
> _scartattack@scartatta_ (mailto:scartattack@...) writes:
> You only have 3 keys or you have 3 dead keys?
> -s*
> On Thu, Mar 19, 2009 at 12:22 PM, <__JMoore6397@_JMoore_
(mailto:_JMoore6397@...) _
> (mailto:_JMoore6397@..._ (mailto:JMoore6397@...) ) > wrote:
> > I have 3 keys on my EMAX SE sampler. Can anyone recommend a company
> > which
> > sells parts to rebuild the keyboard?:
> > Jimmy Moore
> > In a message dated 3/16/2009 10:08:39 A.M. Eastern Standard Time,
> > _scartattack@ _scartattack@<WBR>_scartattack@scartatta_
(mailto:scartattack@...) )
> <scartattack%scartattack> writes:
> > Thanks Brian, I will give that a try although, I have no idea
> which OS
> > resides on each of my floppies. Is there any place I can download
> the
> > newest OS or would anyone be willing to mail me a floppy with this
> OS on
> > it? Also, does anyone have a list of compatible Emax II floppy
> drives? If
> > so, could you please send me this list as I would like to try and
> get one
> > or
> > two just in case my floppy drive is also an issue.
> > Thanks!
> > -s*
> > On Mon, Mar 16, 2009 at 8:49 AM, Brian Ronn <__brian_ronn@__brian_r
> (mailto:__brian_ronn@_brian_r_ (mailto:_brian_ronn@...) )
<_brian_ronn%_brian_ron>
> > (mailto:__brian_ronn@_brian_r_ (mailto:_brian_ronn@...) _
(mailto:_brian_ronn@..._ (mailto:brian_ronn@...) )
> <brian_ronn%brian_ronn><W> wrote:
> > > Hi Scartattack
> > > I had the same callibration issue on my Emax II keyboard when
> using a
> > lower
> > > OS than version 2.14. Try and check your OS version on your boot
> disc
> and
> > > make sure you use v2.14
> > > Best regards
> > > Brian
> > > --- Den man 16/3/09 skrev s* <_scartattack@_scartatta
> > (mailto:_scartattac (mailto:_scartatt_scartattack@scartattac_
(mailto:scartattack@gmail..com) )
> <scartattack%scartattack%>
> > > Fra: s* <_scartattack@_scartattack@<WBR>s_scartattas_scartatta<W
> (mailto:_scartattack@scartatta_ (mailto:scartattack@...) )
> > <scartattack%scartattack>>
> > > Emne: [emax] Emax II Rack issues
> > > Til: "Emax List"
<__emax@yahoogroups__emax@yahoogr__emax@yahoogroups._em_ (mailto:_emax@...)
> <_emax%40yahoogroup_emax>_
> > (mailto:__emax@yahoogroups._em_ (mailto:_emax@...) _
(mailto:_emax@..._ (mailto:emax@yahoogroups.com) )
> <emax%40yahoogroupsemax>)
> > <emax%40yahoogroupsemax>>
> > > Dato: mandag 16. marts 2009 01.49
> > > My Emax II rack has started going a bit crazy recently. Every
> time I
> > power
> > > it on, it appears to load the floppy OS but I get a message saying
> > > "Warning! Need to recalibrate" . The Emax seems to load disks fine
> > however,
> > > I cannot seem to completely format a floppy or save to a
> floppy. Also,
> > the
> > > other night while sampling I noticed that when I sampled a sound
> on C2,
> > it
> > > overwrote the same sample (only truncated differently) onto
> C1,D1,E1 &
> > F1.
> > > I fear that my sample ram may be corrupt or that my floppy drive
> is
> > dying.
> > > I tried to get another floppy drive and even thought they appear
> to be
> > able
> > > to set to drive 0, I cannot get the emax to recognise them. The
> machine
> > > seems to save fine via SCSI though. I am working on a project
> with a
> > friend
> > > and he has an emax non SCSI'd so, a floppy drive would be very
> handy
> > right
> > > now.
> > > I'm kind of at a loss what to try now. If anyone has some
> helpful advice,
> > > your suggestions would be greatly appreciated.
> > > Thanks,
> > > -s*
> > > [Non-text portions of this message have been removed]
> > > Find din nye laptop på kelkoo.dk. Se de gode tilbud her -
> > > ___http://dk.yahoo.http://dk.http_ (http://dk.yahoo.http//dk.htt_)
(_http://dk.yahoo.http://dkhtt_ (http://dk.yahoo.http//dk.ht_) )
> (__http://dk.yahoo.http://dk.htt_ (http://dk.yahoo.http//dk.ht_)
(_http://dk.yahoo.http://dk.ht_ (http://dk.yahoo.com/r/pat/mm) ) )
> > ************ ************<WBR>**Great Deals on Dell 15" Lapt
> __http://pr.atwola.http://pr.http://prhttp://pr.atwolht_
(http://pr.atwola.http//pr.atwhttp://pr.atwolahttp://)
> _pr.atwolahttp:pr.atwolahpr.atwolapr.at_
(pr.atwolahttp://pr.http://prhttp://pr_)
(_http://pr.atwola.http://pr.atwhttp://pr.atwolahttp://pr.atwolahttp://pr.http://pr.http_
(http://pr.atwola.com/promoclk/100126575x1220029050x1201385914/aol?redir=http://ad.doub)
> > leclick.net% leclick.net leclick.
> ************ ************<WBR>**A Good Credit Score is 700 or Above.
> 2 easy
> steps!
(_http://pr.atwola.http://pr.atwhttp://pr.atwolahttp://pr.atwolahttp://pr.http://prhttp://pr.atwolahttp://pr.ahttp://pr.atwolhttp://pr.http://prhttp://p_
(http://pr.atwola.com/promoclk/100126575x1219619459x1201345309/aol?redir=http:
//www.freecreditreport.com/pm/default.aspx?sc=668072&hmpgID)
> %3D62%26bcd% %3D62%26bcd
**************A Good Credit Score is 700 or Above. See yours in just 2 easy
steps!
(http://pr.atwola.com/promoclk/100126575x1220685763x1201394209/aol?redir=http:%2F%2Fwww.freecreditreport.com%2Fpm%2Fdefault.aspx%3Fsc%3D668072%26hmpgID
%3D62%26bcd%3DMarchfooterNO62)
